Results 1 to 4 of 4
Thread: Rear Brake Specifications
    Hello all - I started my MK IV kit in 2019 and have finally got the car across the finish line but still solving minor issues. I have the standard FF 11.65 rear brake kit installed but wanted to consider some different brake pads. From what I can glean from the forum the rear brake calipers are probably from the 1987-88 Thunderbird but I'm not sure if this is correct. Can anybody clarify what I have and what brake pads would be a correct replacement. Sorry if this is a very basic question but I can't find any part number references and the 99-04 Cobra/Mach1 pads don't match the caliper. Thanks for any help.
    Dublin, OH
    My MK4 is from the same vintage and yes, 87-88 tbird. Post a pic of the pads you currently have
    Thanks - looks like the pads for the Thunderbird as well. The rotor is almost 26mm thick (1.01 in), the 83 - 84 cobra/mach1 match identified in the brake kit are are thinner at 18 mm (.709 in). Any ideas on what the rotor supplied with the kit came from?
  5. Likes BamaFord liked this post
