5
Jeff Kleiner
Good to go.
Thank you, Jeff!
Until I figure out the pinion/driveline angles to determine the transmission mount spacer, I'll hold off from obsessing about the oil pan clearance. However, right now looks flushed. Maybe 1/16'' sticking out on the driver side?
