23
522
The chassis and 32 other parts are at the powder coater. They said 3-4 weeks, maybe sooner. So I'm back in idle mode again. Once it's back though I'll have nothing holding me back and no shortage of things to do.
I finally took a close look at the windshield frame. I had read up a bit on it so I was expecting a less than perfect surface condition on the cast aluminum - it lives up to expectations. I knew polishing wouldn't be a good option with the voids and seams, and the CA government with its undeniable logic and wisdom has made chrome plating nearly impossible (cost prohibitive at best) anywhere near me. I took a shot at glass bead blasting the frame to see how it looks. Most areas looked great but the weld seams were still really visible and there were too many small voids. I'll just go with the same aluminum looking powder coating I'm doing on the firewall I think. The place is going to spray out a few test plates for me to help decide the exact color and sheen.
