Thanks Thanks:  2
Likes Likes:  34
Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
Thread: what cooling system additives do you guys use in your radiator?
    Folsom, CA
    John it's ok, that's just rich and jeff
    Todd
    I know I'm relatively new here compared to some and I don't know a much as many of you, but what I do know is I hope I never get the point that I feel like I know so much that I can sh*t on people for not doing things exactly the same way I do.
    Some one pi$$ in your cheerios John? I pay you a complement and agree with with what you said, and you act like someone insults you? NO ONE SH-T ON ANYONE
    Sep 2018
    SF Bay Area, CA
    Why do you think I was referring to you?
    Fido!
    Apr 2023
    Solana Beach Ca
    Ive been involved with a lot of road race mustangs. Some with no cooling fans...Water Wetter has been good.
  6. Likes toadster liked this post
  7. #46
    The LBCeeeee
    I tried water wetter and it may have helped 5º. It was only $12 and I needed a top-off anyway. I filled through the overflow tank.
  8. Likes toadster liked this post
  9. #47
    Folsom, CA
    Quote Originally Posted by NiceGuyEddie View Post
    $12 for 5* difference is pretty good!
    Todd
  10. #48
    Salt Lake City, UT
    I would wait and see if the machine runs hot. I remember reading that a long-time land speed racer found that his Ford Windsors ran best at 192 degrees - basically the OEM thermostat temp as far as I know.
    I have no idea if that is true for other engines, but I'd start with the factory thermostat and regular coolant, and if it runs at the recommended temperature, do nothing. I don't see how reducing temps below what the factory determined is a good operating temp would help anything.
  11. Likes toadster liked this post
