Likes Likes:  4
Results 1 to 10 of 10
Thread: Roadster Go-kart Walk-around Video
    Oct 2021
    Before I put the rest of the aluminum panels on my Factory Five MK4 Roadster, I thought I'd do a video walk-around to get a better view of things before it's all covered.
    A big thank you to everyone here for all your posts and advice. It's been invaluable. What a great community!
    Here's the video if anyone is interested - https://youtu.be/yyX_zarRwJE. Feedback always welcome and appreciated.
  2. Thanks GT53 thanked for this post
    Likes danmas, MB750 liked this post
    Jan 2020
    State of Jefferson
    Nice build and some really nice upgrades you have selected. One thing I noticed was your Canton overflow, it looks like it is going to be very close if it clears the body. I am running the same overflow, you can see where mine is mounted for reference.
    Lots of good work there and a nice build. The more common use of the walkaround videos is a good trend. Several things I noticed:
    The GPS receiver works fine on the windshield mount. Never seen one at the front like that.
    Recommended to have two return springs on the throttle hook-up.
    Overflow tank height may be an issue. But more importantly directly in the path of the gas shocks and maybe even the hinges for the hood.
    Reservoirs on the other side might be close to the gas shocks as well. General recommendation is to leave 12" from the front of the foot box at the 3/4 top square tube. Something to check.
    Temporary location for the inertia switch? Needs to be somewhere that’s reasonably accessible.
  5. Likes nucjd19 liked this post
  6. #4
    Looks very nice! As has been mentioned, the tank isn’t going to work in that location with FFR hood hinges.
    Oct 2021
    Thanks Fman. The pictures really help. I was worried about that when I made the mount. I actually made it so I could lower it a few inches if needed. Looks like I should go ahead and do that. Appreciate the advice! Beautiful engine bay BTW.
  8. Likes Fman liked this post
  9. #6
    Oct 2021
    Thanks edwardb. Glad I posted the video. Great feedback. Exactly what I was hoping for. I'll look into all of those. Good to know the GPS receiver works fine on the windshield mount. I was concerned there might be too much interference in that area.
    And good catch on the inertia switch. That is temporary. I had it where the manual recommends but that was in the way of the underdash filler so I pulled it and haven't remounted that yet. On the ever growing list...
  10. #7
    Oct 2021
    Thanks Jeff. BTW - Reviewing your posts from over the years has been super helpful during my build. Thanks for all you and the other active contributors do to support the community.
  11. #8
    Oct 2021
    Fman - Did you mount the overflow tank directly to the f-panel? And for the MC reservoirs, do you have a bracket mounted on the outside of the 3/4" square frame tube or how are your reservoirs mounted? It's clear the body won't clear the brackets I built. Easy to fix now...hard later. Thanks again!
  12. #9
    Jan 2020
    State of Jefferson
    Quote Originally Posted by Boula View Post
    Yes, Canton is mounted directly to the F panel with some spacers/washers, along with stainless bolts and nylock nuts. Has been holding fine now for two years, 4900 miles. The MC reservoirs are mounted to a small aluminum plate that is bolted to the side of the frame rail.
  13. #10
    Oct 2021
    Thanks Fman! Very helpful.
