Thread: Aluminum washer fluid tank
    Long Island
    A while ago Shane was making a really nice washer fluid tank for the GTM. Unfortunately it was beautiful but difficult to produce. A few lucky guys got one. They are no longer for sale.
    At minimum I wanted a tank that would tuck into an unused portion of the under hood area. The cut out of the FFR kit wiper motor mount is begging for a tank to be built into it so this is what I did.
    Sadly I like the way it looks from the bottom more then the top, but oh well. Ill drill a hole and mount the washer pump from the tank supplied with the kit. Its overkill for a washer tank but it was fun to make and nothing says motorsports to me more then lots of one of a kind aluminum parts.
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
    Cabo Rojo,PR. USA
    WOW!!!! Very nice job John. As usual on your work the craftsmanship on it is of the charts.
    GenII GTM #354
    Delivered (02/09/11)
    XTF #23
    Delivered (03/14/25)
    John-
    Terrific work! I agree that it looks better from the bottom. You could always make some kind of fill from the bottom jig if you need to, then hang it upside down... ;-o)
    I think it will look super in your engine compartment. Very nice craftsmanship!!
    cobra Handler
    That's pretty TIG welding! I want to be able to lay a bead like that for Xmas. WEK.
    Freeport, ME
    What did you use for aluminum stock? .050 or so thick? Nice welds
    Central, FL
    Cool
    John,
    Your skills are outstanding.
    Sun shine, low 80s...
    R/s
    Vidal
    CURRENT STATUS: Interior Rework and Bodywork.
    GenII GTM #331. Delivered (23/9/10)
    BUILD LOG AND WEBSITE:
    http://gtmbuild.weebly.com/ .
    Long Island
    Ha that's funny Vidal. I am sure in the next few months ill be down in your neck of the woods. We can make a quick trip to the indy racing experience at Disney. Rip around the oval then do some GTM building. Sounds like a dream vacation to me.
    I don't think the airline will allow my welder as checked baggage however.
    XTF #2
    GTM # 344
    Long Island
    I used .125 3003. Easy to bend and not so thin that I would have trouble welding it to the thicker top plate.
    Sure I could have gone with a little thinner but when you compare the weight difference, add an extra cup of fluid to the lighter tank and the weight difference is gone.
    I have been thinking of welding up a gas tank and was thinking of using .125 so this was a practice run.
    Bottom line .125 is easier to weld. I'm only a beginner when it comes to TIG welding and I need all the help I can get.
    XTF #2
    GTM # 344
