Thanks Thanks:  2
Results 1 to 11 of 11
Thread: Spinner Set Screw - Supplier or Vendor Info to Replace
    Dec 2018
    Sherwood Park, AB
    Question Spinner Set Screw - Supplier or Vendor Info to Replace
    Wondering if anyone knows the specs or supply for the small socket head set screws for the stock spinners. One of mine is rounded-off. I think it's 10-32, but the end has tip that is not the same as usual set-screws.
    32J
    Dublin, OH
    Conventional wisdom is to throw out those set screws and just thread them correctly. With the spinners on the correct side, the knock offs will only tighten when moving forward. The set screws will only possibly mess up the threads. I might have mine in an extra parts box if you really want them
  3. Thanks 32J thanked for this post
    Dec 2018
    Sherwood Park, AB
    Makes sense. Thought the set screws were there to replace the old safety wire method. Not having them would galling the threads if someone tried to knock off the spinners without knowing about the set screws.
    Yep, throw them away. If you have them on the correct sides of the car forward movement naturally wants to tighten them. Regarding the correct side: Right hand threaded spinner goes on the LH side of the car and left hand thread goes on the RH side of the car. Just remember that when tightening the spinner they rotate towards the rear of the car.
    Sep 2018
    SF Bay Area, CA
    Question - if they were replaced with nylon-tipped set screws like these, would that alleviate the concern about possibly galling the threads, while still giving some added level of security?
    https://www.mcmaster.com/set-screws/...-set-screws-9/
    May 2022
    Fishers, Indiana
    I was considering epoxying the center hub inside the wheel. Has anyone considered this or found another way to fix the center threaded hub inside the rim. I have heard that some use noodles to hold the center in place so you can thread the spinner on
    Dublin, OH
    Noodle behind the center piece and silicon O rings to keep it from moving when unthreading the spinners
    South Australia
    Quote Originally Posted by Malibu46pt View Post
    when I took my wheels to be balanced, the centers needed to be removed to in order to fit the wheel on the balancing machine. Not sure if this is the case for all wheel balancing machines.
    Nigel
    Gen1 Coyote / TKO600 / IRS
  10. #9
    The provided set screws are nylon tipped and I’ve still encountered lots of boogered threads. Install them at your own peril…
  11. Thanks JohnK thanked for this post
  12. #10
    Edmonton Alberta
    You may need to clean up the threads on the hub to get the spinners to screw on smoothly, I gave them a light clean up with emery cloth. I also use dry graphite to lubricate the threads.
    David W
    Mkll 4874 built in 2004
  13. #11
    Dublin, OH
    I just remember "tight a$$" when it comes to which direction to tighten/loosen the spinners. turning towards the rear will tighten the spinners when placed on the correct side.
