What size tires? Unlikely an issue, but part of the equation. Many others have reported this concern during the build and it always worked out once on the ground, at ride height, and the alignment dialed in. You can flip the shocks if you want. The red Konis can go either direction. But for the silver Konis (what I have on two IRS builds) they have to go body down (the way you have yours) and clearance while close wasn't a problem.
