Thanks Thanks:  11
Results 1 to 24 of 24
Thread: Inventory parts list
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Since FF has initiated their new inventory software there has been posts about the confusion there is around what nuts and bolts are in the kit and where they are used. I purchased the Daytona Complete Kit before the software changeover. Based on the recent posts, I believe my inventory list may be helpful in defining where specific nuts and bolts are used. I will be posting my inventory in multiple posts (as I go thru them and copy them here) to help anyone cross reference what hardware gets used where. Keep in mind this listing is for the Coupe but I'm sure a lot of the same hardware gets used in the same locations for both the coupe and roadster. This list will show an assembly and what is part of that assembly. For example in this first list one assembly is Fuel Strap Fasteners. Under that assembly heading it lists the 4 bolts and nuts used to mount the fuel straps. I have also put into parentheses the inventory number that is on my sheets. I do not know if these same inventory numbers have been carried over to the new software or not. I have not noted which box these lists correspond to as my guess is they won't be the same. Hope this helps.
    Secondary Body Fasteners (60307)
    10 Small hood rubber bumper (11061)
    10 Large hood rubber bumper (10701)
    1 - 10 ½ ft roll of 1/16” x 1” adhesive backed weatherstrip (60814)
    1 – 10 ½ ft roll of bulb-on-side push on trim (80813)
    1 Piece of foam weatherstrip (13712)
    1 – 38 ft roll of 3/4” end rubber push-on-trim (16909)
    1 – 31 ft roll of 1/2” moon weatherstrip (60812)
    2 – 3/4” x 3/4” plastic end caps (14161)
    2 – 1” x 1” plastic end caps (80307)
    2 – 1 1/2” x 1 1/2” plastic end caps (60340)
    20 - #8 x 3/4” screws (10983)
    8 – 5/16” - 18 x 1” bolt (11024)
    8 – 5/16” - 18 nylon locknuts (13963)
    20 – 5/16” washers (11005)
    4 - #6 x 1/2” screws (12962)
    1 – 7ft roll of 3/16” channel rubber weatherstrip (60614)
    Rivet package (16189)
    500 - 1/8” short
    300 – 1/8” long
    20 – 3/16” short
    80 – 3/16” long
    Battery tray components (60521)
    1 – Aluminum battery tray (25200)
    1 – Center mount cross bar hold down (14821)
    4 – 1/4” - 20 x 1 3/4” bolts (33696)
    2 – 1/4” - 20 x 2 1/4” bolts (60519)
    6 – 1/4” lock nuts (10802)
    2 – 1/4” - 20 x 8” bolts (60520)
    8 – Washers (11088)
    1 – 42” Battery cable (60514)
    Fuel strap fasteners (60388)
    4 – 3/8” - 16 x 2 1/4” bolts
    4 – 3/8” - 16 flanged nylon locknuts
    Insulated clip hardware pack (11029)
    45 – 1/4” insulated clips (10970)
    30 – 5/8” insulated clips (10971)
    1 – Bag of 100 8” cable ties (13328)
    1 – Bag of 100 4” cable ties (15380)
    Misc. electrical components (60620)
    1 – 10 ft roll of 3/4” flexible wire loom (16912)
    1 – 10 ft roll of 1/2” flexible wire loom (16913)
    2 – 8 ft rolls of 16 GA blue wire (16908)
    30 – Red butt connectors
    1 Foot of 1/32” edge trim (16911)
    3 Expandable grommets (15079)
    2 – 5 way 48” male/female connectors (60619)
    2 - Led flashers (33530)
    Scott Pregont
    My Albums
  2. Thanks racingandfishing, jamminj, ajhandy thanked for this post
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Wiring harness mounting hardware (11070)
    7 - #14 x 1/2” screws (10984)
    8 - #8 x 3/4” screws with countersunk washers (13979)
    2 - #10 x 1” screws for inertia cut-off switch (10995)
    2 - #14 x 1 1/2” screws for vacuum controls (10851)
    1 – 16 GA blue ring connector for computer ground (11217)
    Dash electrical components
    4 - #10 self tapping screws (10995)
    4 ft of wire extension for turn signal indicator (14824)
    2 – Blue 1/4” female blade connectors (11180)
    1 - Blue light high beam indicator (10817)
    1 - Green light turn signal indicator (10816)
    1 - Red light warning indicator (10815)
    1 - 3 prong flasher (11288)
    2 - On/off switches (10596)
    1 - Horn button (11053)
    Fuel filler cap components (60448)
    1 – 2” ID x 90 degree filler hose (33968)
    1 – Plastic fill cap (14617)
    1 – ground strap (13978)
    2 – 1 9/16” - 2 1/2” hose clamps (14191)
    Aston LeMans Cap (14651)
    LeMans aluminum cap
    LeMans cap to body gasket
    5 - #8 x 3/4” screws
    1 - #8 – 32 x 1” bolt
    1 - #8 x 32 locknut
    1 - #14 x 1/2” screw
    1 – ground strap washer
    Fuel line components (14652)
    1 – 1/4” union (14745)
    2 – 1/4” barb fittings (14844)
    1 – 5/16” union (14747)
    2 – 5/16” barb fittings (14748)
    5 – 1/4” fuel line hose clamps (10855)
    5 – 5/16” fuel line hose clamps (11138)
    1 – 3 foot roll of 1/4” ID high pressure flexible fuel line (16725)
    1 - 3 foot roll of 5/16” ID high pressure flexible fuel line (16914)
    3 - #14 x 1/2” fuel filter mounting screws (10984)
    Brake line components (60456)
    3 - #14 x 1/2” donor brake line bracket screws (10984)
    2 – 1/8” steel brake line mounting brackets (13653)
    4 - #6 x 1/2” brake line mounting bracket screws (12962)
    2 – 3/16” brake line unions (13743)
    1 – Brake line “T” adapter – 2 female 1 male (25507)
    1 – 10mm brake line metric adapter (25502)
    1 – 1/4” brake line adapter (12409)
    1 – Brake line “T” adapter – 3 female
    Scott Pregont
    My Albums
  4. Thanks racingandfishing, ajhandy thanked for this post
  5. #3
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Gen 3 Coupe 2015 IRS parts (60380)
    10 – M10 x 25mm socket head bolts (15961)
    4 – M10 x 20mm socket head bolts (16040)
    1 – Automatic driveshaft adapter (15946)
    1 – Left CV Axle (15924)
    1 – Right CV axle (15948)
    10 – Rear wheel studs (16422)
    2 – COUPE e-brake cables (60419)
    Rear brake line components (14754)
    2 – Brake line mounting clips (14709)
    2 – Braided brake line mounts (14689)
    2 – 10mm x 1.5mm banjo bolts (14691)
    20” brake hose components (16741)
    2 – 20” stainless braided 35 degree banjo brake line (14945)
    2 – 3an to 3/8” straight female fittings (25505)
    4 – crush washers (25820)
    Differential mounting components (15941)
    4 – Outside rear upper bushings (12232)
    2 – Pivot sleeves (13953)
    4 – Bushings (13137)
    2 – Pivot sleeves (12257)
    2 – M14-2.0 x 100mm flange head bolts (15962)
    4 – M16-2.0 deformed thread flanged locknuts (14515)
    2 – M16–2.0 x 130mm flange head bolts (15963)
    1 foot of 5/16” ID fuel line (14823)
    IRS upper control arm components (15899)
    2 – 5/8”-11 x 4 1/4” bolts (16242)
    2 – 5/8”-11 locknuts (15216)
    2 – 7/8” misalignment spacers (16239)
    2 – 5/8” washers (12387)
    4 – M16–2.0 x 110mm flange head bolts (14925)
    2 – Angled mount adapters (15857)
    2 – 7/8” rod end – left hand thread (15890)
    2 – 7/8” jam nuts (15900)
    2 – 7/8” x 1 1/4” adjuster bung (15889)
    2 – 1 1/4” jam nuts (15901)
    1 – IRS right upper arm (17119)
    1 – IRS left upper arm (17118)
    IRS toe adjustment arm components (15902)
    2 – Right hand threaded rod ends (12348)
    2 – Right hand threaded jam nuts (12380)
    2 – Left hand threaded jam nuts (13166)
    2 – Linkage adjusters (33388)
    2 – M14–2.0 flanged lock nuts (14759)
    2 – M14–2.0 x 80mm bolts (15936)
    2 – 5/8”-11 x 2 1/4” bolts (15937)
    2 – 5/8”-11 lock nuts (15216)
    2 – Rod end spacers (12896)
    2 – 1/4” rod end spacers (33240)
    Scott Pregont
    My Albums
  6. Thanks racingandfishing, ajhandy thanked for this post
  7. #4
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Coupe complete kit IFS components (15344)
    2 – Adjustable front upper control arms (15501)
    2 – Upper ball joints (14897)
    4 – 1/2”-20 x 1 3/4” flanged head bolts (15138)
    4 – 1/2”-20 lock nuts (12218)
    2 – 1/2”-13 x 3 1/4” coil-over upper mounting bolts (12386)
    2 – 1/2”-13 x 2 3/4” coil-over lower mounting bolts (10842)
    4 – 1/2”-13 nylon lock nuts (10834)
    10 – 1.2” SAE washers (13976)
    4 - .675” top front coil-over spacers (15387)
    4 - .43” bottom front coil-over spacers (15388)
    Koni front coil-over kit (14676)
    2 – Koni 30-1720 dampers (14622)
    2 – 2 1/2” Koni spring hats (25621)
    2 – 2 1/2” Koni threaded spring seats (25622)
    2 – 2 1/2” Koni threaded damper sleeves (25623)
    2 – 500 lb springs – 2 1/2” ID x 8” long
    2 – 1.875” internal snap rings (16687)
    2 – Delrin spring washers (16701)
    2 – 1/4” soft tip screws (16702)
    Steering system hardware (60774)
    2 – 1/2” washers (13976)
    2 – 1/2”-13 x 4” bolts (12332)
    2 – 1/2”-13 nylon lock nuts (10834)
    2 – Tie rod end cotter pins (10937)
    2 – 2.45” spacers (15514)
    1 pair – Power steering rack extension (14687)
    1 – 3/4” x 20.31” DD shaft (60736)
    1 – 3/4”-36 spline x 3/4” DD u-joint (15839)
    1 – 3/4” x 1” DD u-joint (15840)
    1 – 1” x 17” DD tube (12642)
    1 – Upper steering shaft (13695)
    1 – 5/16” washer (11005)
    1 – 3/8”-16 x 1” bolt (10520)
    2 – 1/4” spring washers (13860)
    Steering wheel hardware (11071)
    1 – Aluminum steering wheel boss (11008)
    6 – M6-1.0 x 30mm screws (12338)
    6 – M6-1.0 nuts (12339)
    1 – Aluminum center section (14657)
    1 – Leather wrapped 14” steering wheel (12451)
    Steering bearings / hardware (60323)
    1 – 1” flange bearing (12640)
    2 – 5/16”-18 x 1 button head bolts (11024)
    2 – 5/16”-18 x 1 1/2” button head bolts (12776)
    4 – 5/16”-18 nylon lock nuts (13963)
    1 – 3/4” pillow block (10577)
    2 – 5/16” USS washers (11005)
    2 – upper steering bearing spacers (x0103)
    Transmission mounting components (60402)
    1 – Transmission mounting plate (60399)
    4 – 1/2” x 1 1/4” carriage bolts (25590)
    Scott Pregont
    My Albums
  8. Thanks racingandfishing, ajhandy thanked for this post
  9. #5
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Tubular front lower control arms (12066)
    2 - Front lower A-arms (16640)
    4 – M16-2.0 x 110mm front lower control arm bolts (14925)
    4 – M16-2.0 front lower control arm nuts (14515)
    4 – 5/8” washers (12387)
    2 – Castle nuts (should be shipped with ball joints) (14158)
    2 – Ball joint boots (should be shipped with ball joints) (14159)
    2 – Cotter pins (should be shipped with ball joints) (10937)
    2 – 5/8” countersunk washers (15803)
    Front spindles (14850)
    2 – front spindles (33048)
    2 – Front hubs (14510)
    2 – Front hub nuts (14511)
    2 – Front hub nut dust covers (14512)
    4 – M12-1.75 x 50mm bolts (33704)
    4 – M12-1.75 flanged nylon lock nuts (25995)
    4 – 12 point M12-1.75 x 35mm caliper to spindle bolts (33539)
    Steering arm set (14851)
    1 – LH steering arm (14848)
    1 – RH steering arm (14849)
    IRS lower control arm components (15906)
    6 – M16-2.0 deformed thread flanged lock nuts (14515)
    2 – M16-2.0 x 90mm flanged head bolts (15909)
    4 – M16-2.0 x 110mm flanged head bolts (14925)
    1 – IRS left lower control arm (17116)
    1 – IRS right lower control arm (17117)
    2 – IRS toe arms (16620)
    Koni 2015 IRS shock set (15995)
    2 – Koni 30-1720 shocks (14622)
    2 – Koni spring hats (25621)
    2 – Koni spring collars (25622)
    2 – Koni coil-over threaded sleeves (25623)10802
    2 – 400 pound springs (33976)
    2 – 1/4” soft tip set screws (16702)
    IRS shock mounting components (15935)
    6 – 1.09” spacers (33238)
    2 - .43” spacers (15388)
    2 – 1/2”-13 x 3 1/4” bolts (12386)
    Brake reservoir components (34168)
    1 – Brake reservoir (34152)
    1 – Brake reservoir gasket (34169)
    2 – 1/4” nylon lock nuts (10802)
    1 – 1/8” NPT to 1/4” elbow barb (34112)
    2 – 1/4” fuel line hose clamps (10855)
    1 – 1/4” nylon bulkhead adapter (34148)
    1 – 1/4” nylon hex nut (34149)
    Scott Pregont
    My Albums
  10. #6
    Feb 2022
    Granbury, TX
    Thanks for posting this. I'm guessing much of this would apply to the Roadster kit as well. Or at least a good start.
  11. #7
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by OB6 View Post
    Yes. The IRS and most of the front suspension is the same if buying the complete kits. If going with donor parts things may be different.
    Scott Pregont
    My Albums
  12. #8
    Oct 2021
    Sarasota, FL
    Interesting information here and how you set to pool the sub assemblies together. Will noodle on it a while as I am months away from getting my build.
    Bill
  13. #9
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by maclonchas View Post
    Bill
    Just copying what's on my inventory sheets in no particular order. This is the way it was listed before the software change. Each box had it's own inventory sheet(s). I didn't list the box numbers because I didn't copy them in order and they may not be the same with the new system.
    More to come.
    Scott Pregont
    My Albums
  14. #10
    Aug 2021
    This is awesome Scott, thanks. To add my part, here’s the inventory for the Coupe fastener pack (#60859) that I received from FFR:
    Coupe Fastener Pack Inventory
  15. Thanks ajhandy thanked for this post
  16. #11
    Jan 2022
    Thanks for posting. I will be bookmarking this. Also building a Gen 3 coupe, though I went with a base kit +options. My kit finish date was 10/8/22 I took delivery 10/22/22. Mine was delivered with the new hardware/inventory system. So I have the "coupe fastener pack" bag o' bolts. Still waiting on the IRS fastener pack. Interestingly there are a few places where the hardware is packed with the sub assembly, but not all. I'm sure there's a reason somewhere.
  17. #12
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by bjblock View Post
    Those with a list like yours should be able to find those bolt/nuts/screws in my list and then see where they are used. I also noted that they are using the same FF inventory part number for each item. I will continue to add to my listing.
    Scott Pregont
    My Albums
  18. #13
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Headlamp components (14671)
    Following included in above part #
    2 – Mounting gaskets
    4 - #8 x 3/4” screws
    2 – Black plastic buckets
    10 - #8 x 1/2” screws
    2 – Chrome retainer rings
    6 – Retainer ring clips
    6 - Retainer ring clip screws
    4 – Adjustment screws
    2 – Chrome outer trim rings
    2 – Trim ring retaining clips
    2 – Trim ring screws
    2 – Grommets
    2 – Wiring pigtails
    2 – Halogen headlights (13545)
    Shifter handle components (10888)
    1 – Shifter rod
    2 – Shifter rod bolts
    1 – Shifter Boot
    1 – Polished stainless shifter ring
    1 – Shifter knob
    1 – Shifter knob base
    Rearview mirrors (12837)
    1 – 8” rearview mirror (25558)
    1 – Chrome sideview mirror (15834)
    License light/bracket components (12835)
    1 – License plate light (12765)
    2 – washers (10635)
    1 – Bracket (14097)
    2 – Nuts (13774)
    2 - #14 x 1/2” screws (10984)
    2 - #8-32 x 1” screws (14464)
    2 - #8-32 lock nuts (14465)
    Front turn signals and hardware (15847)
    4 – Front amber turn signal light (15848)
    4 – Stainless steel grommet cover (15849)
    Tail-light components (60417)
    4 – Red tail-light lens (60291)
    4 – Tail-light trim ring (60292)
    4 – Inside tail-light gasket (60290)
    4 – 3” internal retaining rings (60415)
    12 - #10-32 Stainless nylon lock nuts (12768)
    4 – Tail-light gaskets (60289)
    4 – Tail-light mounting rings (60418)
    Coupe pressed mesh (60305)
    2 – Pressed nose side mesh (60302)
    1 – Pressed left rear mesh (60303)
    1 – Pressed right rear mesh (60304)
    Scott Pregont
    My Albums
  19. #14
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Headlight covers/fasteners (60313)
    1 – LH headlight cover (60140)
    1 – RH headlight cover (60141)
    8 – Mounting tabs (15486)
    8 - #6 x 1/2” screws (12780)
    Nose fasteners (60346)
    2 – Nose hinge bracket assembly (60391)
    2 – Nose latch (12763)
    14 - #10-32 x 5/8” Black button head socket screws (80837)
    14 - #10-32 stainless steel washers (12156)
    2 – Nose latch mounting brackets (12895)
    4 – Rod end jam nuts (12380)
    4 – 3/8” Rod end spacers (33239)
    2 – Gas struts (25462)
    4 – Flat short gas strut brackets (12207)
    2 – Nose latch strikers (60617)
    4 – 3/8”-16 Jam nuts (14725)
    4 – 3/8”-16 Flanged nylon lock nuts (60381)
    2 – 5/8”-11 x 3” Bolts (12382)
    2 – 5/8”-11 Nylon lock nuts (12383)
    2 – 5/16”-18 x 1” Button head bolts (11024)
    2 – 5/16”-18 Nylon lock nuts (13963)
    2 – Bullett head locator pins (60758)
    2 – Nose side locating plates (60698)
    2 – 1/4” Fender washers (12337)
    2 – 1/4” Nylon lock nuts (10802)
    Rear quarter side windows (12828)
    1 – LH rear quarter side window (12637)
    1 – RH rear quarter side window (12638)
    1 – 9/64” 60 plastic drill
    18 - #6 x 1/2” stainless screws (12780)
    Seat harness (13024)
    2 – 5 point seat harness (12528)
    Seat harness fastener pack (14959)
    10 – 1/2”-13 x 1 1/4” Bolts (10833)
    20 – 1/2” SAE washers (13976)
    10 – 1/2”-13 Nylon lock nuts (10834)
    351W Stainless steel ball-collector headers (16745)
    1 – 351W Left side header (16746)
    1 – 351W Right side header (16767
    2 – Header to side exhaust ball collector (16682)
    16 – 3/8”-16 x 1” Header bolts (no part number listed)
    6 – 3/8”-16 x 2 1/2” flange head bolts (34087)
    6 – 3/8”-16 deformed thread lock nuts
    Scott Pregont
    My Albums
  20. #15
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Ancillary Components (60341)
    1 – Conical air filter (10789)
    1 – Six rib serpentine belt (10781)
    Seat mounting hardware (15140)
    16 – 5/16” washers (11005)
    8 – 5/16”-18 x 2 1/2” bolts (15391)
    8 – 5/16”-18 nylon lock nuts (13963)
    Alternate drive pulley components (11080)
    1 – Pulley wheel to replace A/C (10775)
    1 – Machined aluminum pulley spacer (10952)
    1 – 1/2”-13 x 3 1/4” bolt (12386)
    1- 1/2”-13 lock nut (10834)
    2 – 1/2” SAE washers (13976)
    Stainless radiator hose kit (13883)
    7 ft of corrugated metal hose (16916)
    4 – radiator hose adapter sets with clamps (13930)
    Included in above part number
    Reinforced 2 1/2” long rubber hose
    small rubber hose adapter
    large rubber hose adapter
    2 hose clamps
    Radiator mount components (60336)
    2 – 5/16”-18 x 1 1/5” upper radiator mounting screws (12776)
    4 – 5/16” USS washers (12908)
    2 – 5/16”-18 nylon lock nuts (13963)
    1 ft of 5/16” ID high pressure hose (14823)
    1 – Radiator top mounting bracket (60335)
    1 – lower radiator hose (60342)
    Fan mounting components (60463)
    2 - 8 ft rolls of 16 GA blue wire (16908)
    6 – Blue butt connectors (10941)
    2 – Blue ring connectors (11217)
    2 - #14 x 1/2” ground screws (10984)
    1 – Fan relay (12455)
    1 – Relay socket (25839)
    1 – 16” 2170 CFM radiator fan (34389)
    E-brake handle mounting hardware (15183)
    1 – Fixed gear (15167)
    2 – 5/16”-18 x 3/4” bolts (60518)
    2 – Handle to ratchet mount (15168)
    1 – Ratchet tooth (15169)
    2 – E-brake mounting bracket (15170)
    1 – Lower handle assembly (15176)
    1 – Upper handle (15173)
    1 – Hand brake button (15174)
    Scott Pregont
    My Albums
  21. #16
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Door frames (60349)
    1 – Left door frame (60351)
    1 – Right door frame (60352)
    Interior door handle components (13790)
    2 – Door handle cables (15371)
    2 – Black interior door handles (60800)
    2 – Door handle clevis's (14607)
    4 – 1/4”-28 jam nuts (15377)
    2 – Cable mounting tabs (13771)
    2 – 1/4”-20 x 5/8” Philips head screws (12777)
    2 – 1/4”-20 lock nuts
    4 - #6 x 1/2” oval head screws (60801)
    Door latch/hinge components (60382)
    8 – 5/16”-18 x 1 1/2” button head bolts (12776)
    18 – 5/16”-18 nylon lock nuts (13963)
    18 – 5/16” washers (11005)
    4 – 3/8”-16 x 1 1/4” carriage bolts (60343)
    8 – 3/8”-16 flanged nylon lock nuts (60381)
    4 – 5/16”-18 x 2” shoulder bolts (13564)
    8 – Hinge bushings (13183)
    6 – 1/4”-20 x 1” flanged bolts (33524)
    2 – 7/16”-14 nylon lock nuts (13965)
    6 – 7/16” door striker mounting washers (12909)
    1 – DS single claw door latch (14180)
    1 – PS single claw door latch (14181)
    2 – Door latch strikers (60429)
    4 – 5/16”-18 x 3/4” carriage bolts (25562)
    1 – Left door strike mounting plate (60434)
    1 – Right door strike mounting plate (60435)
    2 – Leather check straps (12408)
    1 – Left hinge arm assembly (60347)
    1 – Right hinge arm assembly (60348)
    1 – Hinge adjuster plate (13565)
    Stainless steel ball flange side exhaust (60791)
    1 – Left side stainless steel ball flange side pipe (60788)
    1 – Right side stainless steel ball flange side pipe (60789)
    Exhaust hardware (60809)
    2 – Side exhaust hangers (60799)
    2 – Exhaust frame mounting assembly (13551)
    4 – Rubber exhaust mounts (13778)
    4 – 5/16”-18 x 1/2” button head bolts (60589)
    2 - 5/16”-18 x 1 button head bolts (11024)
    6 – 5/16”-18 nylon lock nuts (13963)
    4 – 5/16” washers (11005)
    Driving light parts (60824)
    2 – Driving lights (60823)
    20 ft of 16 GA red wire (60829)
    10 ft of 16 GA black wire (26003)
    6 – 1/4” female terminals (11180)
    1 – 10 GA 5/16” stud ring connector (33842)
    1 - #14 x 1/2” screw (10984)
    1 - On-off switch (10596)
    Scott Pregont
    My Albums
  22. #17
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Hard lines (60773)
    3 – 3/16” OD x 60” brake lines (13738)
    1 – 3/16” OD x 20” brake line (13740)
    1 – 3/16” OD x 8” brake line (14692)
    2 - 1/4” OD x 60” fuel lines (14751)
    2 – 5/16” OD x 60” fuel lines (14752)
    Interior trim (60358)
    2 – Roll bar padding (25772)
    8 – Dash mounting screws (12962)
    1 – Headliner (60318)
    1 – E-brake boot (14923)
    1 – E-brake boot ring (60725)
    4 - #8 x 3/4” screws (10983)
    Accelerator pedal components (14481) (For SBF with EFI)
    1 – Accelerator pedal (14486)
    Included in above part #
    Accelerator pedal
    Allen wrench
    1 – Ball stud retainer (13975)
    Stud retainer
    Ball stud
    Lock nut
    Power steering rack assembly (16104)
    1 – 15:1 power steering rack (16105)
    4 – Steering rack bushings (16482)
    2 – Outer tie rod ends (15378)
    Power steering stainless hose kit (16471)
    1 – Straight 6AN to 16mm-1.5 fitting (16472)
    1 – 6AN male x 9/16”-18 adapter fitting (16452)
    1 – 6AN male x 5/8”-18 adapter fitting (16453)
    1 – 6AN male to 6AN female 90 degree fitting (16464)
    1 – 6AN male to 3/8” barb fitting (16951)
    1 – 3/8” x 6” power steering return hose (16952)
    2 – 3/8” fuel line hose clamp (12739)
    2 – 36” SS braided PS pressure line (16466)
    2015 IRS double adjustable shock set (16481) (these are the upgraded shocks)
    4 – Koni double adjustable shocks (8212 1417 BB) (33965)
    2 – 2.5” ID 8” 500# black front coil over springs (14626)
    2 - 2.5” ID 8” 400# black rear coil over springs (33976)
    GPS gauge set (60311)
    1 – GPS speedometer (16034)
    1 – Tachometer (15704)
    1 – Oil pressure gauge (15705)
    1 – Water Temperature gauge (15706)
    1 – Fuel level gauge (15707)
    1 – Voltmeter (15708)
    1 – GPS gauge panel (60761)
    Scott Pregont
    My Albums
  23. #18
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Pedal box components (60337)
    2 – Brake light/clutch switches (16283)
    4 – 1/2”-20 pal nuts (16284)
    1 - 3/8”-16 x 1 1/4” socket head bolts (11040)
    1 – 3/8”-16 nylon lock nut (13964)
    4 – 1/4” female terminal connectors (11180)
    2 - #10-32 x 5/8” philips head screws (80414)
    2 - #10-32 SS nylon lock nuts (12768)
    1 – 1/4” nylon “Y” (16253)
    4 – 1/4”-20 x 1/2” flange button head screws (33688)
    1 – Pedal box with forged pedals (15206)
    2 – 3/4” master cylinders (16255)
    4 – 1/4”-20 x 1 1/4” bolts (15638)
    2 – 1/4”-20 x 3/4” bolts (80539)
    6 – 1/4”-20 nylon lock nuts (10802)
    4 – 5/16”-18 x 1” button head bolts (11024)
    1 – Pedal box top mount (60193)
    2 – Steel brake light switch mounts (14788)
    Accelerator cable components (13777)
    1 – Accelerator pedal capture (13774)
    1 – Accelerator cable (13775)
    1 – 5/16”-24 lock nut (11212)
    1 – Ball stud retainer with ball stud (13975)
    1 – Throttle return spring (13974)
    E-brake handle fastener pack (15210)
    1 – 1/4”-20 x 10” “L” bolt (15166)
    1 – 3/16” x 5/8” spring pin (15178)
    4 – 5/16” x 3/4” carriage bolts (25562)
    7 – 5/16”-18 nylon lock nuts (13963)
    1 - Shoulder bolt (13325)
    1 – 1” nylon spacer
    1 – 1/2” nylon spacer (10597)
    1 – 1/4”-20 x 1 1/2” screws (12336)
    1 – 1/4”-20 x 1” flange button head screw (25461)
    2 – E-brake cable clevis (15181)
    1 – 2 5/8” compression spring (15179)
    2 – Nylon bushings (15165)
    1 – 1/4” male rod end (15177)
    1 – 1/4” female rod end (15180)
    2 - #10 washers (10635)
    Wilwood 2015 IRS Gen 3 coupe brake line parts (60752)
    2 – Wilwood IRS e-brake cable adapter (16031)
    2 – 5/16”-18 x 1” button head bolt (11024)
    4 – Brake line mounting clips (14709)
    4 – Braided line brake line mount (14689)
    1 – Brake line “T” - 2 female 1 male (25507)
    2 – E-brake cable (60419)
    Scott Pregont
    My Albums
  24. #19
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Hydraulic clutch master cylinder kit (34158)
    1 – 3/4” master cylinder kit (16255)
    Fluid reservoir components (34168)
    1 – Fluid reservoir (34152)
    1 – Reservoir gasket (34169)
    1 – 1/8” NPT thread to 1/4” elbow barb (34112)
    OEM fuel tank components (14472)
    1 - Fuel tank (14469)
    2 - Fuel tank straps (one left one right) (14624)
    1 – Fuel tank cover (14470)
    1 – Fuel filler neck (14476)
    1 – Filler neck retaining ring (14738)
    4 – Retaining ring bolts (25460)
    4 – Retaining ring lock nuts (10802)
    1 – Fuel filler gasket (14474)
    1 – Fuel tank vent (15719)
    1 – Vent bushing (15205)
    2 – 1/4” ID high pressure flexable fuel line (15120)
    1 – 1/4” fuel line hose clamp (10855)
    1 – Fuel tank vent gasket (33973)
    2 – Fuel level/sender o-ring (16360)
    1 – Fuel pick-up with lock ring (14468)
    1 – Fuel level sending unit with lock ring (14467)
    1 – Fuel filter (14471)
    1 – Fuel filter bracket (14495)
    1 – Hose clamp (13699)
    1 – 3/8” - 5/16” fuel line connector (14504)
    1 – 1/4” straight fuel line connector (14961)
    1 – Tank to filter fuel line assembly
    Cooling system (14614)
    1 – Roadster aluminum radiator (14031)
    2 – 1/4” female terminal connector (11180)
    4 – 1/4” x 3/4” elevator bolts (16779)
    4 - 1/4” nylon lock nuts (10802)
    4 – Fan mounting straps (16750)
    4 - #10-32 x 5/8” black button head socket screws (80837)
    4 - #10 washers (10635)
    4 - #10-32 SS nylon lock nuts (12768)
    1 – 180 degree thermostat switch (13127)
    1 – Inline filler neck with cap (16460)
    Coolant overflow tank kit (16576)
    1 – Coolant overflow tank (16391)
    4 – 1/4” nylon lock nuts (10802)
    2 – 7/16” - 25/32” narrow hose clamps (60655)
    1 - 5 feet of coolant hose
    4 - #8 x 1/2” self tapping screws (14627)
    1 – Coolant overflow drop mount (16788)
    Scott Pregont
    My Albums
  25. #20
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Rear glass hatch components (60326)
    4 – Large button stud (15242)
    8 – 1.32” OD rubber washers (15243)
    2 – Small button studs (15265)
    2 - .813” OD rubber washers (15266)
    2 - .922” OD rubber washers (15267)
    2 – 7/16” black washers (15244)
    6 – 7/16”-20 jam-nuts (15245)
    2 – Threaded ball studs (15246)
    1 – Hatch latch (80959)
    1 – Hatch glass (60153)
    8 – Nylon bushings (15165)
    2 – 35# gas struts (60689)
    2 – 1/4” ball studs (81136)
    2 – 1 5/8” tube collar with threaded hole (60687)
    1 – Rear window weatherstrip (60860)
    2 – Frame side rear hatch hinge arms (60685)
    1 – Driver hatch side rear hatch hinge arm (60825)
    1 – Passenger side rear hatch hinge arm (60826)
    2 – Shoulder bolts (13325)
    2 – 5/16” washers (11005)
    1 – Left side hatch hinge mount (60525)
    1 – Right side hatch hinge mount (60526)
    1 – Hatch catch spacer (60629)
    Coupe side window components (60371) (kit upgrade)
    1 – 10 foot of side window gasket (60724)
    1 – Weatherstrip closing tool (25890)
    2 – Left side window mounting brackets (60720)
    2 – Right side window mounting brackets (60721)
    1 – Right side window frame (60722)
    1 – Left side window frame (60732)
    Laser cut side window parts (60811)
    2 – Inner quarter window (60714)
    2 – Main windows (60707)
    4 – Side supports (60708)
    4 – Top/bottom slides (60710)
    4 – Side spacers (60711)
    2 – Sliding windows (70712)
    4 – Handles (12939)
    1 – Side window fasteners (60807)
    Coupe floor-mats (60831)
    1 – Driver side logo floor-mat (60832)
    1 – Passenger side floor-mat (60833)
    Speedometer sending unit (14727)
    1 – Speedometer sending unit (14661)
    1 – 3.73 speedometer gear (14936)
    1 – Gear spring clip (14612)
    1 – 1/4” x 5/8” button head socket screw (16486)
    1 - Battery cut-off switch (12543) (upgrade)
    1 – 31 spline 10 1/5” drive shaft (60175)
    Scott Pregont
    My Albums
  26. #21
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    302/351W A/C kit (60377)
    302/351 A/C compressor assembly (13253)
    1 – A/C compressor (13277)
    2 – M8-1.25 x 25mm bolts (10601)
    1 - #10 compressor adapter (60610)
    1 - #8 compressor adapter (60611)
    1 – Front bracket (13251)
    1 – Rear Bracket (13252)
    2 – 5/16”-18 x 2 3/4” bracket to bracket bolts (12591)
    2 – 5/16-18 nylon lock nuts (13963)
    2 – M8 x 100mm bracket to compressor bolts (13264)
    2 – 3/8”-16 nylon lock nuts (13964)
    4 – Bracket mount shims (12908)
    1 – Head mount bolt (13290)1 – Head mount washer (12909)
    A/C bracket tubing (60630)
    2 – Compressor rear mount spacers (60631)
    2 – Compressor front mount spacers (60632)
    2 – Bracket spacers (60633)
    1 – Rear head mount spacer (60634)
    1 – Front head mount spacer (60635)
    A/C components (60385)
    2 - #8 x 1/2” self tapping screws (14627)
    3 - #10 x 1” screws (10995)
    1 – Heat/A/C main unit (60587)
    1 – Trinary switch (60594)
    5 – 7/16” - 25/32” narrow hose clamp (60655)
    1 – 3 ft of 1/8” insulation (60772)
    1 - .83 ft of 3/4” rubber pipe insulation (60771)
    A/C electrial components (60793)
    1 – Lighted on/off switch (60639)
    1 – A/C faceplate (60638)
    1 – Faceplate mount (60658)
    1 – A/C wiring harness (60781)
    9 – Blue connectors (10941)
    A/C condenser components (60678)
    2 – 1/4”-20 x 1” flange button head screws (25461)
    2 – 1/4”-20 x 1/2” flange button head screws (33688)
    4 – 1/4”-20 nylon lock nuts (10802)
    2 – 1/2” nylon spacers (10597)
    2 - #10-32 x 1” black button head socket screws (60345)
    2 - #10 SS washers (12156)
    2 - #10-32 SS nylon lock nuts (12768)1 – A/C condenser (60383)
    2 – Lower condenser mounts (60650)
    A/c drier mounting components (60785)
    1 – Drierr mounting bracket (60651)
    1 – Drier frame bracket (60652)
    2 – 3/16” long rivets (11291)
    Scott Pregont
    My Albums
  27. #22
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    A/C hoses, fittings and drier (60786)
    1 – A/C hose and fittings (60782,60783,60784)
    1 – Straight #10 to 7/8”-18 beadlok fitting (60667)
    1 – Straight #6 to 5/8”-18 beadlok fitting (60668)
    1 – Streamline 2 way A/C bulkhead (60664)
    A/C duct components (60602)
    20 – 11” cable ties (60666)
    1 – 9 ft of 2 ½” vent duct (60603)
    1 – 3 ft of 2” vent duct (60820)
    2 – Defroster ducts (60605)
    2 – Defroster grills (60757)
    4 - #6 x 1/2” truss head screws (12780)
    2 – 2 1/2” “Y” hose adapters (60608)
    2 – 2 1/2” to 2” hose adapters (60609)
    4 – Louver spacers (60657)
    2 – Dash vent assembly's
    Heater control components (60794)
    6 – 3/16” short rivets (25799)
    1 – 4 port electronic heater control valve (60596)
    1 – Heater control valve mounting bracket (60654)
    1 – Heater control valve module (60597)
    1 – Rotary heater valve switch (60598)
    1 – 4 position rotary fan switch (60599)
    2 – Knobs (60600)
    1 – 10 ft of 5/8” heater hose (33656)
    12 – 9/16” - 1 1/16” hose clamps (33760)
    1 – Streamline 2 way heater bulkhead (60665)
    2 - #8-32 x 1/2” button head socket screws (15787)
    2 - #8-32 nylon lock nuts (14465)
    Electrical system components (no inventory number)
    1 - Custom fit chassis wiring harness (14503)
    1 – Headlight switch (12354)
    1 – 3 position turn signal switch – on-off-on (11128)
    1 – 2 position high/low beam switch – on-on (12454)
    1 – 2 position hazard switch – on-on DPDT (14954)
    1 – Engine ground strap (25542)
    1 – Battery ground strap (14544)
    2 – 5/16”-18 x 1” bolts (11024)
    1 – Set of horns (15859)
    2 – 1/4” female terminal connectors (11180)
    2 - #14 x 1/2” horn mounting screws (10984)
    1 – Green turn signal indicator light (10816)
    1 – Led underdash light strip (15256)
    Ignition switch components (16982)
    1 – Ignition switch with 2 keys (16983)
    1 – Ring connector gauge wiring (12223)
    4 – Ring connector gauge wiring (14087)
    Scott Pregont
    My Albums
  28. Thanks maclonchas thanked for this post
  29. #23
    Western Mass
    Thanks Scott, this is helpful!
    We just received our kit over the weekend and will start inventory soon. My daughter is really excited to help with that part, she loves sorting and organizing.
    I'll start a build thread soon.
    Jon
  30. #24
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Great news Jon! Looking forward to following along with the build! My list was before the system change at FF. Not sure how much it will help. I don't believe they give an actual manual anymore. Make sure you download the digital version. I printed it out and put it in a binder. Use it to do your inventory. Having it on a laptop can make it easier to search also. Take your time. Note what part is in what box. Makes finding the part you need much easier. Organization is key to a build like this. Have fun my friend!!!
    Scott
    Scott Pregont
    My Albums
