08-16-2022, 11:49 AM
#361
Nice job with the aluminum fab! I think about the joys that would come with a box brake every time I have those two bends in a corner. Took an approach similar to yours and in the end works out fine. Todd's right about the additional time / pain associated with any wanders away from the standard build components. But, seems worth it in terms of getting a truly custom car.
Hadn't thought about making the console box a floating box - that's cool. I'm still puzzling through exactly how I'm gonna fasten mine to the 'A frame' and tranny top. Thanks for sharing your approach.
Meandering, leisurely build thread is
here
08-18-2022, 05:24 PM
#362
Inside the Coyote Throttle Pedal
This is a revision of post #180 where I modified and installed the coyote gas pedal. When trimming pedal to make it fit the footbox I had accidentally trimmed it a bit too much such that the red rotating part of the pedal was showing a little. I did some research online and apparently I wasn't the only one that did this. Although it didn't seem like a big deal at the time it's always been on the back of my mind. To settle this once and for all I decided to figure out exactly how the pedal works. I couldn't find diagrams of the pedal assembly anywhere so purchased another pedal just to take it apart and see what's inside it.
While the pedal itself isn't very expensive I still wanted to take it apart without damaging it. Try as I may I could not unclip the tabs that held it together so I ended up pretty much destroying every single one of them. I swear I tried my best, ok? It's worth it... for science.
Mechanically the pedal was really quite simple. There's a big rotating assembly with a large spring pushing on the other side of the fulcrum. The red part that was exposed is just a part of the rotating shaft. Probably a coating to reduce friction.
On the rotating shaft is a metal target plate used by the RF inductive rotary position sensor. The sensor itself is completely sealed on the other half of the pedal housing.
The part that I "trimmed too much" is the housing that holds the shaft in place. That part is well reinforced on the inside as well so I've determined my accidental mishap is fine. The assembly still rotates smoothly and I see no possible way for the pedal to be "stuck" in some position. The sensor itself is on the other side and complete sealed so there's no chance of that being damaged either. RF inductive rotary position sensors are very accurate and "dust and waterproof" since the sensor itself doesn't actually contact with the metal target plate. It makes sense that Ford uses it given that the pedal housing itself isn't airtight.
So that settles it. No more worrying on my end!
P.S. I'm NOT suggesting that one should feel free to over-trim the pedal housing. It's just that if you did by accident then I think you're okay as long as the rotating part still moves freely with good integrity.
08-28-2022, 03:23 AM
#363
Misc updates: Trunk electronics.
In post #352 we made a trunk cubby for extra cockpit-accessible storage. I planned to add extra accessory and USB power outlets to the cubby so I can charge by phone / power some accessories from it.
The most time was spent on deciding where the fuse-panel should be. I wanted to mount it to the driver side cubby panel facing the trunk, but after some mock-ups I didn't like it because it left very little space for working on the roll-bars and the fuse-panel would be very hard to access from the trunk. I ended up mounting it to the rear facing cubby panel. It'll be openly visible with an open trunk, but that's okay. I had another fuse-panel lying around so I hooked that one up to the switched-battery power wire. That wire is much thicker and can carry a lot more current so if I want to add any heavier duty accessories in the future I can add some relays and power it from that instead. Right now it's just sitting there not connected to anything. I understanding that trying to "future-proof" the project is kinda like trying to future-proof your computer (in that it's pretty futile) but might as well try right?
I bought some daisy-chained white LEDs that can also be powered individually. I used two of them to light the trunk and the cubby. The 6-way fuse box was super handy and made connecting the lights super easy. I'm very happy about that purchase.
With all the cables and stuff exposed I figured I should cover it up with a flap of some kind. Don't want random thing rolling around back there with the wires. Did a mock-up with cardboard and will one day turn that into aluminum attached via piano-hinge.
I also used cardboard to mock-up a glove-box cover. It looks a little high in the pictures but IRL it feels fine. I got some foam-backed felt from amazon I'd like to try. The plan is to cut the shape out of sheet aluminum and wrap it in the felt material. I wonder what a different texture for glove-box would look like. Looks good in my imagination... but we'll have to see.
09-24-2022, 12:05 AM
#364
Safety, Front Lights, and the Last Box
Was talking with the lady of the house about go-karting around. She's the worrying type, and absolutely thinks the car is too dangerous. She's... not wrong, but I didn't build this thing to leave it in the garage.
A few months ago on a warm summer evening stroll we saw a cobra that looked like it wrapped itself around a fire hydrant and then rolled over a few times just off the local main road. The way the roll-bars were mounted looked like it's a Superformance cobra not a factory five, but that's besides the point. A week later on my way to work I saw flowers placed around the new fire hydrant; the old one, like the cobra driver, didn't make it out alive. I couldn't find much about the incident on the forum. Rumors on the local neighbourhood forums said the driver was an old man who indeed did not make it out alive. I've heard at least 5 people tell me in person that mishandling a cobra is attempted suicide. None of them hit me as hard as seeing it happen right around the corner. I think about the scene from time to time. The road stained with oil and radiator fluid, the flowers, and the roll bar that's been bent out of shape. It would be me if I'm not careful.
We had several long conversations about the safety of driving on public roads, and in the end we agreed that while low back seats look cool, they expose the head too much. The low back seats also don't have a hole for the submarine belt. I know there are mods that "add" the hole, but this combined with other safety factors made racing bucket seats a much more attractive option. We went to the race shop at Sonoma Raceway and purchased a set of Sparco Pro 2000 bucket-seats. I sat in a bunch of them at the shop and these felt the best. I plan to use these in the roadster instead of the factory five provided low-back seats.
You'd think the low back seats are gonna be wasted right? Turns out they are excellent floor seats! Now I watch TV sitting on my low-back seats on the floor. They feel great! Haha!
We also purchased an open-face helmet and a hans-device. I made sure to purchase a hans-device with a high degree of neck rotational freedom so I can check my blind spots and look around when I need to. The open-face helmet, too, was chosen such that it barely blocks my peripheral vision. The idea here is that if I ever go on a medium-long trip that involves a lot of traffic or the highway, I should wear it. If I get T-boned I'm gonna be toast, but a bit of confidence in other situations help. Safety is a topic of never-ending opinions. Some say why build a cobra if you're gonna be so scared? Some say why drive a cobra without a flame suit? I'm sure some of you would snicker at a guy who wears a helmet and hans on a public road. Just don't tell me you did. That way I won't mind.
She and I also agreed that I won't go-kart the car until I have all the lights installed. That way at least the cars around me will know if I'm braking or turning. That's not a bad idea. So I decided to get the lights onto the car. Before that I tidied the dashboard wires to a state that's more "plug-and-play"-able. I just don't like the look of messy wires dangling around. It's nothing like John or Paul's clean wire bundles, but at least it ain't flopping left to right.
The body won't be anywhere in sight for a while, so I gotta mount it another way. I had some oriented strand board lying around doin nothin, so I made temporary mounting boards for the lights. Made appropriate holes for the headlights and turning signals then spray painted it black.
It actually looks pretty cool from a distance!
I gotta figure out the rear light converter so the rear lights will go on later. I've read quite a few threads about it and it all makes sense. I just gotta do it. I WILL say tho, I WISH I did the converter install before sealing up my trunk aluminum. The firewall is already a mess and I'm not looking forward to complicating it more with a converter dangling in there.
The next morning I did my routine mental inventory work of the FFR shipment boxes. I was pleasantly surprised to find that there's only ONE more box to open! I remember the day I piled the mountain of boxes in the shed wondering when I'll ever get through them. Today's the day! The contents of Box 7A saw the light of day for the first time since its time at FFR. It's a bittersweet moment moment opening up that last box. Hehe.
Lord knows this ain't the last car-related box I'll open.
09-24-2022, 06:02 AM
#365
Totally understand and applaud your concern about safety. Especially when something bad happens that close to you. Had something similar in our area a couple years ago. A real wake-up call. But a couple of comments if you don't mind. While there are many what I consider alarming posts about these cars, it's still ultimately about the driver and not as much about the car IMO. Granted, that doesn't take into account other drivers and the harm they can dish out. Defensive driving is critically important no matter what you drive (seems especially where I live, but I think it's a universal problem...) but even more so in one of these because you have fewer protections. But at the end of the day, I think you're going to be surprised how well the car drives and how stable it is when driven within reason. Save the crazy stuff, if that's you, for autocross, the track, etc. and drive within reason on the street and I think you'll be very pleased and no reason to drive scared. Yes the car will bite you if you don't respect it. But that's true of every car at some level. You don't know the circumstances of what happened with the accident by you. It might be related to the car. Or it might not. The recent accident by me (also fatal, sadly) was excessive speed on a freeway in cold temps compounded by early morning and a slightly wet road surface. Yes, the car may have encouraged the behavior. But ultimately it was the driver's fault.
Regarding your go-kart. This is a somewhat sensitive subject for me and I've posted my opinion about it multiple times. The go-kart step is a rite of passage during these builds that everyone seems to go for. Which I understand and do myself. It's the first chance to experience a running chassis that moves, brakes, shifts, steers, etc. under its own power. Definitely a motivator for the build! But IMO it's not a replacement for an actual test drive and shakedown once the car is actually finished, titled, licensed, insured, etc. I see videos and descriptions of guys running at full speed, in traffic, sometimes doing crazy stuff IMO (donuts, etc.) and makes me very nervous. My personal go-karts are going up and down my neighborhood street in first and maybe second a couple times and that's it. There's almost always no other cars. That's enough safety and legal exposure for me, confirms all is working, and gets me ready for the next build steps. No complaints about you making sure you have lights, etc. But maybe scope the process down a bit to where that and other steps aren't as critical.
OK, off my soapbox. Good luck. Enjoy the build and look forward to great fun cruising when it's done. That's what it's about.
Build Thread and
Video.
Build Thread.
Build 5: 35 Hot Rod Truck #138.
Build Thread. Sold 11/9/2023.
Build 6: Mk5 Roadster 30th Anniversary #11,258.
Build Thread.
09-24-2022, 08:10 AM
#366
Not a waxer
So you're planning to use a helmet and HANS and make all of the lights function so that you can go-cart in traffic? Might I suggest that your put your efforts into getting the car finished, properly registered, licensed and insured instead. Like my friend Paul I don't don't look at go-carting as any more than an initial functional check. All the cars that I've built have never racked up more than a mile or two on my seldom traveled country road in go-cart form. I don't get the guys who tell us about hitting 50 or 100 miles as a go-cart like it's some sort of a badge of honor or accomplishment---to be blunt I think it's foolish. But you do you, and I'll get off of my soapbox too.
09-24-2022, 09:42 PM
#367
Thanks for the words of caution Paul and Jeff. I assure you I'm NOT go-karting on the main road. I'm go-karting around my local block back and forth. Only 2 miles on the speedo so far. I suppose I made it sound like I'm doing all the safety stuff just for go-karting. It's a more general consideration for the build.
09-26-2022, 10:27 PM
#368
Trunk Carpet Fitting & Dash Mounting Tabs
Decided to fit the carpet and upholstery around my trunk cubby box. I want to install the rear cockpit panel soon, but fitting the carpet then would be more difficult so we're doing it now. Before doing too much I layed out some of the carpet. Gotta say, they are cut a lot better than I thought they'd be. Fits like a glove everywhere I tried! Kudos to FFR.
I bought some foam-backed suede fabric material for the insides of the cubby. The walls of the cubby will have the suede on all surfaces visible from the cubby/trunk. The carpet's cut to fit the area taken up by the cubby as well as the driver side of the cubby. That area I'm leaving open as that's where I'll put all my trunk electronics and I'll put an access door so stuff in the trunk won't roll into it. The access door is mocked up with cardboard in the first picture below.
I decided to also glue on the cubby panel fabric. The carpet can be glued down later.
Pretty slick eh? The outer vertical edges of the cubby has exposed foam material. I purchased some plastic trims which I'll glue onto the edge to cover it up. I took a candid picture of the trunk in progress one afternoon and loved the lighting. Thought I might share:
Circling back to the front for a bit; I replaced the hacked-up flimsy dash-mounting holes with stronger aluminum tabs with rivnuts installed. Now they ALWAYS point forward and I can secure my dash with screws instead of clecos. Yay!
You can also see that I've started fitting the under-dash carpet for my ignition control panel box. That's next.
09-28-2022, 09:37 PM
#369
09-30-2022, 01:27 PM
#370
I love seeing builders fab items from scratch. You've got yours in the most visible possible area on the car and it looks great. Nice job.
here
10-05-2022, 11:59 PM
#371
Colour and Paint
Alright, I got some questions about paint. As much as I’d like to leave it as a surprise the utility of this forum cannot be understated. The colour I've decided on is a deep emerald green. Ideally BMW’s Isle of Man Green, or whatever closest thing to it I can get.
My question is, if I have the paint code, am I sure to get that colour and "glow" effect of the paint? What I like about it is the way it reflects light. It's a hollow-ish kind of glow. Is there some special painting technique required to do that, or is it just paint magic? If I get the BMW paint code, is that enough?
As for the stripes... I saw a picture of someone’s cobra on instagram and I fell in love with the way the stripes looked. It looked like bright metallic silver underneath a coat of high polish clear coat. Combined with the emerald green color of the paint it glows under the light in different ways depending on the angle you’re looking at it. (if this is your car I'm sorry I stole your pic. I couldn't find the post again.)
instagram_shots1.jpg instagram_shots2.jpg instagram_shots3.jpg instagram_shots4.jpg
I don't know how to get the paint code for the grey. I'll spend a day going around my local dealerships and look at their shades of silver/grey. Hopefully I'll find what I'm looking for.
10-06-2022, 06:03 AM
#372
awesome choice. reminds me of a michigan state football helmet. I'm sure some of the master builders/painters will chime in on the paint.
10-06-2022, 06:53 AM
#373
Question, have you gone to a BMW dealer and seen it in person? I found that many times I looked at pictures it was very different once I saw it in person.
10-06-2022, 08:00 AM
#374
Not a waxer
That looks like it may be a 3 stage. If so you’re gonna’ need to talk with Miller because he usually won’t do tri-coats.
10-06-2022, 10:35 AM
#375
I'm not a fan of green cars but that could change my mind! You could park that car in a hundred green cars and say "Mine is the green one" and everyone would know which car is yours.
10-07-2022, 01:19 AM
#376
Yes! I wanted the colour because I saw it in person one day and couldn't take my eyes off of it. It looked SO good under sun light.
#377
Jeff Kleiner
Thanks Jeff, I'll shoot Miller a message.
10-07-2022, 01:48 PM
#378
Side pipe heat-shields installed!
Received by side-pipe heat shields from cobra stuff. I opted for the ceramic coated version. It's not as shiny as the chrome one, but it will deal with the heat a lot better. I had some trouble mounting the shields onto the exhaust clamps though. The heat shield doesn't curve enough towards the ends of the wrap:
I emailed Alex at cobrastuff and he replied saying I need to loosen the bolts a bit and really squeeze. I wasn't a fan of that because if I squeeze the sides the middle will bulge out and have an awkward cigar-shape. Luckily I had my sheet metal brakes that were large enough to fit the shields. I protected the shields with some towel to prevent scratching as well as softening the bend and bent the edges incrementally bit by bit.
...and now it fits like a glove!
10-07-2022, 05:32 PM
#379
Thanks for the heads-up, Dan. I'm making a note, as I'm going to eventually order from this vendor as well, but ceramic coated black.
Coupe complete kit. Index. Delivered: 4/22/24.
Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
MK4 Complete kit.
Build Thread Index. Delivered: 10/15/2020. Legal: 7/25/23. Coyote Gen3. TKO600 (0.64 OD). IRS w/3.55. PS. Wilwoods. Sway bars. This build is dedicated to my son, Benjamin.
Build Thread.
10-09-2022, 02:26 PM
#380
10-09-2022, 04:14 PM
#381
The difference between Wisdom and Experience:
Experience is what you learn by doing it yourself.
Wisdom is learning from someone else's experience.
10-10-2022, 01:10 PM
#382
Take a grinder to my bell housing
Noticed that my bell-housing lower lip is extended pretty far under the main tube frames. There are no bolts there nor does it look like it's holding anything together. Does anyone have any words of caution before I take a grinder to it and flatten it out?
10-10-2022, 01:33 PM
#383
facultyofmusic
yup, that's going to need some cutting.
10-10-2022, 02:07 PM
#384
Couple of thoughts. Yes, it could use a little trimming, but be careful how much you trim off. I didn't want to trim off so much that I expose the bell housing cavity to debris entering, so that means that you can really only trim off the mounting flange of the bell housing. Also, while it's lower than the 4" frame member, it's not that much lower than the oil pan. If I had to chose what makes contact, I'd much rather the hardened steel bell housing be the thing that takes a blow vs. the oil pan.
What I did was to lay a straightedge along the oil pan and scribe a line on the bell housing block off plate. I then double-checked to make sure I wasn't going to trim off so much that I opened up a hole into the bell housing cavity. This is how much I ended up trimming off. Keep in mind that the bell housing is some pretty hard steel.
MkIV Roadster build: Gen 2 Coyote, IRS, TKO600. Ordered 10/24/18. Delivered 1/29/19. Engine installed 8/8/21. First start 9/12/21. First go-kart 9/17/21. Off to paint 4/11/22. Back from paint 12/30/22.
Build thread here.
10-10-2022, 02:32 PM
#385
JohnK
Thanks for the straight edge idea! I didn't think of that. And yeah I agree with the oil pan vs bell housing point. :P
10-10-2022, 08:47 PM
#386
I had the same issue. I drew a line basically from the bottom of each of the two bolt holes, eliminating the bottom bolt hole. That worked pretty well. I only lost one bolt in the process. Yes, the steel there is quite hard, and it was challenging to get a straight line with an angle grinder. The good news it that no one will see your work unless the car is on a lift! My best advice is to wear a full face shield when you do it. Goggles alone won't offer you all that much protection.
10-14-2022, 12:04 AM
#387
God damn I didn't know they made steel this tough!
Spent a good hour shaving off the bottom of the bell housing. What can I say except HOLY **** IS THAT STEEL TOUGH. Initially I tried using a flap disc and it made a tiny dent in the bell housing after a few good seconds of grinding. At that point I knew I wasn't getting anywhere with a flap disc. Like Al_C said, I made a cut that connected to two side holes, eliminating the middle hole.
It doesn't look pretty at all, but I'm at a point where I'm completely okay with it looking like that until I put this thing on a real lift. I've had enough of laying under the car with sparking flying all over my work suit. It still sticks below the frame by less than half an inch, but it's a lot better than what it was before. I'll grind the rest off some other day.
I also spent some time yesterday installing the wilwood brake bias adjuster. It's been covered many times on other build threads and the optimal location seems to be next to the fuse-panel in the driver footbox. I copied the tried and true solution. See this thread for a more detailed discussion: https://thefactoryfiveforum.com/show...-location-work
PXL_20221009_233615313.jpg PXL_20221009_235721135.jpg PXL_20221009_235801378.jpg
Two things to note:
- First, the tilton right angle coupler's cable end hole isn't big enough wilwood's cable. You'll have to enlarge it a tiny bit.
- Second, I've seen some builders use the 3/8-24 collar nut provided by wilwood, the one used to "lock" the bar in place for those who don't plan to adjust brake bias after it's dialed in. Do not use that nut to secure the tilton coupler's bias-bar end. The collar can get caught on the clevis knuckle and there's no way to free it unless you pull it up a little by hand. Use a 3/8-24 jam-nut instead. You can turn the collar nut into a jam-nut by grinding off the collar if you want. I just had a jam-nut laying around.
10-24-2022, 07:36 PM
#388
Body On! Part 1: Starting California Registration
Boy it's been a while since the last update! I've been so busy wrenching and cranking it out that I barely had time to take pictures! Let's catch up.
Like many other topics, this one has had many detailed threads on it. I'm not going to repeat the general registration process. What I hope to do here is to provide some information that may help folks specifically around my area. If you're looking for general information on CA registration, here are a few fantastic threads that I consulted:
https://thefactoryfiveforum.com/show...0-Registration
https://thefactoryfiveforum.com/show...cess-for-SB100
I went to the DMV on Tuesday morning of last week. I specifically chose to go to the DMV in Los Gatos. Wisdom from the builders in the area points towards that DMV because they've simply seen more SPCNS and SB100 processes. This is super important has SB100 is a process that most DMV employees never see. A DMV location with employees who've done this before saves a ton of headaches. If you're in the Bay Area, I recommend the Los Gatos DMV. This DMV is also less crowded, which, I can verify as I went 30 mins early and was already the 6th in line.
I was placed at window #10. I said "I would like to register a self-built car." The lady at the desk (her name was Jill) asked me if I had a VIN number. I said no. She then immediately told me they can't do anything if a car doesn't have a VIN. It's important at this moment to quickly tell them that you are applying for the very forms and permits to allow you to get a VIN; that and show her the STATEMENT OF CONSTRUCTION. When I did this she immediately realized what's happening and started the process for me. I waited there as she went through all my documents.
Moments later she called me up again to discuss the COST OF CONSTRUCTION. On my form, I listed everything I could find and brought all my receipts. She went through every single one with me again and crossed off a bunch of misc. items such as the battery and some construction bits and bobs because they weren't "Cost of construction". She also crossed out "self labor" and specifically told me they do not take self labor into account. So on your statement of construction, just leave it blank. She made a point to circle the FFR kit receipt and the engine receipt. If I could do it again, I'd circle the kit and engine costs in big circles because that's what she looked for the most. I paid the taxes on the construction and waited there again as she processed further paperwork.
When she returned all my documents she did NOT give me a temporary permit. I got her attention and pleaded that "I cannot complete the next steps if I can't drive my car to these places you've listed." She was very sympathetic and came back a moment later with a temporary permit that allowed me to drive my car until November 30th. MAKE SURE YOU GET A TEMP PERMIT. THE FORM THEY GIVE YOU IS NOT A PERMIT.
The overall process took only 30 mins. That's a LOT better than I expected. I walked out that day with a temp permit and instructions on the next steps: CHP VIN Verification and Smog.
If you're reading this and will be heading to the DMV, see if you can go on Tuesday morning and ask for Jill. She'll probably remember and it will be much quicker for you.
JohnK thanked for this post
10-24-2022, 07:54 PM
#389
Hopefully right behind you. I'll be calling you to pick your brain when I get to that point.
Build thread here.
10-25-2022, 12:26 PM
#390
I had to get a Brake & Light inspection, and the VIN verification at the CHP was the easiest for me. They used my stamped frame number from FFR as the VIN. Then I had to contact a BAR "virtual Rep" by phone. He wanted copies of all the documents, pictures of the car, and pictures of the engine bay showing the closed loop PCV system emailed to him. Once he approves it, he will provide the phone number for the BAR station that you decide to go to. The good thing about sending all the documents and pictures was that I was pre-approved, and the inspection was only a formality. Was in and out of the BAR station in less than a half hour. Then it's on to the DMV to pick up your plates. Just as a note, unless things go extremely well during all this, the temporary may not give you enough time to complete everything. Worst case you can get one day passes that you don't fill in the day until you are actually going to use them. I hope everything goes well for you guys. They ran me around because of the stack injection, and it created a number of issues for me.
Rick
Post Thanks / Like - 2 Thanks, 0 Likes
10-25-2022, 02:37 PM
#391
EZ$
Thanks Rick! Did you have any trouble requesting for an SB100 sequence number at all? I know that I can only get it after the CHP gives me my VIN, so I plan to return to the DMV the day after I get my VIN. Do you recall what you said to request for your SB100 sequence number?
10-25-2022, 03:10 PM
#392
Forgot that minor item! I explained when I first went to DMV that I wanted to receive an SB100 number, and they told me I needed the VIN number from the CHP, and a brake and light inspection. Luckily my mechanic shop where I take my DD is also a brake and light inspection station. I believe once I had those items and took that paperwork back to DMV that they called for my sequence number. Hopefully your DMV agent is not dyslexic like mine was. She wrote #504 on all my paperwork even though I tried to tell her that there were only 500 number. Turns out my number was 54. Anyhow, once they tell you what you sequence number is they'll give you the phone number to call the BAR, but you can't get an appointment till the virtual agent gets all the requested information. Then, and only then, they'll give you the phone number of the BAR station you want to go to, and you have to call for an appointment. Sometimes they're busy and it'll put you out a month or so. You could get lucky like me and get an appointment the following week. Sorry for the disjointed info. My process was interrupted by my appointment with my painter, which took one year, and caused a few issues that I had to work through.
By the way, when my family came to California, we lived in Sunnyvale off of Mary and Evelyn. I graduated from Sunnyvale High School in '68. Crap am I old!
Rick
10-25-2022, 04:32 PM
#393
EZ$
Thanks for the valuable info! I actually live right around Mary and Evelyn!
If you ever visit Sunnyvale please feel free to stop by!
10-26-2022, 01:11 AM
#394
Body On! Part 2: Windshield Mounting
I purchased Mike Forte's windshield mounting brackets. I was convinced after seeing both Dave (SJDave) and John (JohnK) had them on their build and looked like it would save a ton of time. To find the correct orientation of the brackets I used spacers made by Dave. They slide snug into the brackets with protrusions that fit into the original mounting holes. It's a super quick and straightforward!
PXL_20221014_054143337.jpg PXL_20221014_054146978.jpg PXL_20221014_054200360.jpg PXL_20221014_054209550.jpg
I purchased some 5/16-18 flange head nuts and bolts to secure the brackets once I had it aligned with Dave's spacers.
The windshield posts were a little tricky to put on. No pictures here... just don't screw the first one all the way in. Screw all the screws in a little to make sure they all catch and then fasten it down. When inserting the posts into the brackets I noticed the posts were cut quite rough, so I chamfered the post where it inserts into the brackets and it slid in super easily. I gotta say, I was expecting one hell of a time getting the windshield to slide in. I mean... it's a huge thin piece of glass... with brass posts that attaches with a few screws... you'd expect to need some twisting and fitting no?
Anyway, IT'S ON! I haven't drilled the windshield posts yet because I don't yet know how high the body will prop it up. I plan to drill the holes after final mount and paint at Jeff's.
I taped my temp operating permit on the top passenger side of the windshield. I'll call it a day here!
After I took that picture of the car I sank into a bittersweet mood. Tomorrow Dave, Kevin, and Herman will stop by to install the body. By the end of tomorrow the car won't look like this anymore. It feels like the "build" part of the car has come to an end. No more installing of major drivetrain components, no more figuring out how to make the car run. I understand that there's still a lot of work left to do, but once the body goes on everything else just feels like aesthetics. I really do like the way it looks right now and I almost wish I can just drive it like this forever.
The first start was a few months ago, and tomorrow will be the next big milestone. I'm excited!
10-26-2022, 11:35 AM
#395
facultyofmusic
Oh, man, I've been building so long I didn't anticipate this. Maybe the cake's baked, but the frosting's not on. Who doesn't like frosting?
here
10-28-2022, 02:15 AM
#396
Body On! Part 3: Better With Friends!
A while ago I scheduled with Dave and Thomas to help me with installing the body. Dave got Kevin and Herman too and we all decided to meet on Saturday bright and early. Once again I couldn't really sleep the night before
Before that, I spent some time doing "frame alignment" where I make sure the front quick jack holes are exactly 30 inches apart and that the center of the left and right quick jacks lines up exactly with the center of the front wheels. Was pretty easy to do. I transformed a stepped drill bit into a plumb bob using a string and some tape then used it to cast 4 points onto the floor. 2 points for left and right front suspension top bolt, 2 points for left and right quick jack holes. My quick jack holes were 30 1/2in apart and biased to the driver's side by about 3/8in. Used my dead-blow hammer and whacked it until everything lined up like Jeff suggested. Didn't take long at all! Now I know my front wheels will line up with the body just right.
I opened my garage door to find everyone already there waiting. How I didn't hear them coming in their cobras I have no idea. Must've been microwaving or something. Anyway we got our gloves and lifted body off the buck, around the house, and onto the front lawn. Boy that fiberglass body sure is light when you have 5 people carrying it! The guys then took out their sanders and grinders and went to town on the body. When I planned this with Dave he said "see the reason why it's a lot faster with other guys helping you is because we'll take a grinder to your body no problem while you'll be all paranoid and ****". He's right. I don't think I'd work with as much "gusto" as the guys did
Within 30mins the edges were all sanded and trimmed back a little. We added the rest of the bulb seal onto the rear panels, put masking tape on the bulb seals (to avoid scratching it up since I'll be taking it off at Jeff's anyway), and lifted the body high into the air. 2 guys at the back, 1 on each side, and 1 on the front. We tilted the front down first to attach the front quick jack posts, then lowered the rear as the sides were pulled outwards around the body. Quick and easy! The guys were surprised at just how well the body fitted onto the frame! The rear panels lined up perfectly with the curves of the body. The front-wheels aligned perfectly with the wheels well. The rolled edge on top of the dashboard sat high and didn't cover the whole dash, but I've read about this issue and should see it get better as I "cook" the body in the hot Californian sun. In hindsight I should have taken more pictures... but I was busy holding up the body so whoever's reading this remember to get an assistant photographer!
Kevin brought his Milwaukee Fuel M12 right angle die-grinder and it was the SINGLE MOST USEFUL TOOL OF THE DAY. That die-grinder with a carbide router bit chewed through the fiberglass body with smooth and controlled sweeps. Enlarging the roll-bar and windshield post holes were no problem at all. Pretty much every hole needed to be enlarged on the body, so do be prepared to do that even if you got the body with cutouts from FFR.
Kevin and Thomas had to leave early so Dave, Herman, and I went to get lunch at the local Black-Bear Diner. Always loved to hear the older cobra guys talk about cars and fun stories of the past. After lunch we went back and called it a day after trimming the side-pipe holes and mounted the side-pipes. Dave can confirm that no matter how many times you take the side-pipes off they are always a massive PITA. It was a massive PITA. I dread the day where I have to replace them. Good thing the windshield slided in pain-free. I think I only have enough patience for one of the two.
(oh, and I will have to replace the side-pipes, because the passenger side side-pipe is already rattling on the inside.)
The next day I spent the whole day installing my lights. Nothing special here, just center stuff and enlarge the holes!
Super happy with the weekend's work. It ACTUALLY LOOKS LIKE A COBRA NOW!
A funny note: That evening I wanted to put the car back on jack stands before I go to sleep. To do that I need to first drive it onto some short ramps so my jack can reach under it. I gave it a bit too much throttle and the ramps FLEW OUT from underneath the rear wheels, skidded along my driveway, and ended up equidistant from the car, LOL! I guess physics does work.
Now that I have my temp permit, my lights, and my windshield, I have everything I need to drive it around! I plan to drive it to work this week. So excited!
Post Thanks / Like - 0 Thanks, 3 Likes
10-30-2022, 07:03 PM
#397
Congrats on getting the body on, Dan. I can't believe you get to drive it to work. That's awesome!
Thanks for the tips on the body fitment. I'm going to be putting the body on mine before too long, so this info. is timely.
MK4 Complete kit.
Build Thread.
11-11-2022, 02:38 AM
#398
VIN Verification, SB100 number, and driving the thing around!
Continuing from where we left off in post #388 I booked appointments with the local CHP office about 2 weeks after my initial DMV visit. The office I went to is the one at 2020 Junction Avenue, San Jose , CA 95131.
I drove the cobra to the CHP office and arrived super early. I took a route that avoids highways and major intersections since I'm still not fully confident in the car not breaking down
I'm sure that gets better with time! Officer Troy Elder came out 15mins early to meet us to walk through the process. He was super knowledgeable about Factory Five kit cars and said if he was in my position, he'd rivet the serial number plate to the chassis, and then show that to him so he can use that serial number as the VIN. He said that was possible because it was known to him that FFR issued an unique serial number with each chassis. What a cool guy! I showed him the serial number that's already etched into the frame. He confirmed that it matched the serial number on my certificate of origin from FFR, took my paperwork, and a few mins later came out with a filled out VIN verification form. The whole process didn't take more than 30mins.
Since I was ahead of schedule, I drove by a brake and lamp inspection station just 5mins away to get my brakes and lights inspected. I didn't know if I needed it because the list of requirements on my DMV printout didn't mention brake or lights inspection, but I've read about it so many time I thought I might as well do it just in case. The inspection costed me $150 in total. The guy doing the inspection wasn't the friendliest fella either.
It was around 2pm when I realized that I COULD just swing by the Los Gatos DMV again to get my SB100 number. I have completed everything required for that step. Why not? To my surprise when I arrived at the DMV there was no line! What a lucky feeling. I carefully explained to the lady at the window that I have returned to the DMV after completing steps requested by them and I'd like to CONTINUE my registration process. I also made sure to tell them that I need an SB100 number. Overall the process went smoothly with the branch manager's help and I walked out of the DMV with my number written on a piece of paper. Sacramento will mail me an official document with the number, but nevertheless I have obtained it!
Oh, and they didn't bother with my brake and lamp inspection certificate. I'm not sure if they'll eventually ask for it so I won't claim it's useless yet. I hope I didn't waste $150.
Another takeaway from this is to go on a weekday around a time when everyone else is at work. I took a day off for this and I think it's super worth it.
Now all I have to do is wait for that letter from sacramento and book my smog appointment with BAR. Soon I'll have my license plate! Woohoo!
11-16-2022, 09:56 PM
#399
facultyofmusic
Hi Dan. These suggestions from Jeff, are they in a post? If so, would you mind sharing the link? Also, what are the most helpful body fitment threads you've found? I would like to do all of the body fitment myself, as I plan to license and drive in gel coat for a while. As I search the forum, I'm finding good nuggets, and trying to patch them together into an overall plan. I believe sequence is important (e.g. don't locate the hood scoop until the body is positioned), so looking for recommended threads to point me in the right direction. (I also PM'd Jeff K. to see if he has any recommended body fitment links at his fingertips--especially ones he wrote). Thanks in advance for any recommends you can share.
MK4 Complete kit.
Build Thread.
11-17-2022, 02:03 AM
#400
460.465USMC
Here's the post I was referring to: https://thefactoryfiveforum.com/show...l=1#post317923 That overall thread is probably the most helpful one I've found. Here's another one on about the same topics: https://thefactoryfiveforum.com/show...s-re-front-end My assessment of the whole situation after reading a bunch of threads was that it's really not that complex. Center the front quickjack attachment holes, the body lip at the door strikers should be about 1/4in in front of the metal, and that's really it. I didn't even bother with the hood scoop. I just brought it with me to Jeff's.
