Thanks Thanks:  113
Likes Likes:  416
Page 14 of 30 FirstFirst ... 4121314151624 ... LastLast
Results 521 to 560 of 1180
Thread: The race is on - Namrups 65 Daytona Coupe build
  1. #521
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Had a member of the Upstate Cobra Club stop by. As I noted the diff was at a -.8 degree angle. We raised the transmission until the transmission and cross brace lined up. Needed 3/8" worth of washers between the cross brace and the transmission mount. This gave me a +.8 on the drive shaft angle and a +2.4 degrees on the transmission. Locked it down there.
    Mounted the wheels and dropped it off the jack stands. Officially a roller!!
    Scott Pregont
    My Albums
  2. Likes rhk118 liked this post
  3. #522
    Jul 2021
    Another option would be engine drop mounts. Mounts that drop the engine 3/4" after common parts. In your case it would help the situation, and also help your soon to be hood clearance issue. Potential exhaust fitment issues unknown.
  4. #523
    May 2021
    Fort Worth, Texas
    You want the transmission output shaft angle and the differential yoke to be parallel to each other with a slight angle (2 degrees is good enough for this short driveshaft) of the drive shaft. The drive shaft angle can be in any direction.
  5. #524
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by GT_Rich View Post
    Dropping the engine would create different issues. My oil pan and the bottom of the transmission would then be below the frame.
    Scott Pregont
    My Albums
  6. #525
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by Skuzzy View Post
    I am not the first to use a SBF in this car. I would guess I'm not the first to use the TKX either. There is simply no way to line up the shafts . There is a very small box of adjustments available to install and make everything fit. FF confirmed that I have the right parts. If there were major issue with the fitment of this combination the way I have it I'm sure it would have been noted long ago. These are FF parts not donor parts so I now have faith that it is a non issue now that everything fits except for the parallel shafts. Local builders have looked at it and have given it their blessing. Given the fact that the diff is fixed in place and can't move I'm still not convinced that they have to be. Once it's on the road I will know if I have any vibration or not. I know the TKX is new but from what I've been told it's the same, dimension wise, to the TKO when it comes to mounting. If anyone else out there has used a 351 with the TKX please chime in and let us know what you did.
    Scott Pregont
    My Albums
  7. #526
    Jul 2021
    I am somewhat close to installing my 427/TKX combo. I have the same Champ pan that you have. I bought the pan and drop mounts from Gordon Levy and he promised the pan would sit about the frame rails. Would you mind putting a straight edge across the bottom of your chassis and measure up to the pan with standard mounts in place?
    I think your compromise on angles is pretty good.
  8. #527
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    As my engine sits right now the clearance on the pan is 3/8".
    The clearance on the spacer plate for the tranny is 1/8".
    Scott Pregont
    My Albums
  9. Thanks rhk118 thanked for this post
  10. #528
    Jul 2021
    Thanks for the pics! That is not the result Gordon advertised to me when he sold me these parts. It looks like I will need to either shim up the solid drop mounts or go to the FFR provided option.
  11. #529
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Day 112 progress walk around
    112 days post delivery. Working to get to a point I can attempt first start. Biggest holdup is headers. No word on these. Wiring is 70% laid out. Sniper is laid out. Radiator mocked up and plumbed. (Love the look of the cool tubes) Mike Forte sent the power steering reservoir. Should be here tomorrow. Laid out switch location on the dash.
    https://youtu.be/GxkdGbnaNwQ
    Scott Pregont
    My Albums
  12. #530
    Looking good. You're doing a great job. I know some of your wiring and such isn't finalized. But one observation. Make sure to get that front crossover convolute further away from your upper radiator tube. That tube gets very hot of course, and some convolute has a (disappointingly IMO) low melting point. Good luck with the upcoming first start. It's a huge milestone and quite exciting.
  13. #531
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Added a pressure gauge to the fuel feed line.
    I have a couple of questions....
    The RT fan wiring connection did not fit the fan connection. I rewired it with a weatherproof connector. There was also a third wire labeled "fan thermo sw". I believe this is a water temp sensor. The Sniper already has a temp sensor so do I need this one? I terminated it but left it in place. My next question is can I tap into the Sniper temp sensor to run my water temperature gauge or do I have to have a second separate sensor for the temp gauge?
    On the Ididit headlight dimmer unit, can someone verify for me that the yellow wire, labeled "headlight switch, needs to be mated to the brown dimmer switch wire. The RT diagrams do not show it that way but the diagram I downloaded for the Ididit site does.
    Last question for today... I feel silly asking but ... How do I get the shaft to pull out of the headlight switch so that I can mount the switch? I tried pressing the spring button but nothing happened. I tried to undo the set screw but that didn't help either. I didn't want to put to much force on either not knowing the right procedure.
    Scott Pregont
    My Albums
  14. #532
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thanks for that little tid-bit! Will fix that.
    Scott Pregont
    My Albums
  15. #533
    Mar 2021
    Ohio
    Quote Originally Posted by Namrups View Post
    I had the same question about the temp sensor, I am running an Atomic 2 efi
  16. #534
    Scott,
    Pressing the little tab/button with the spring will allow you to pull the knob and shaft from the switch---but they aren't exactly a precision piece of machinery so it may take some wiggling and colorful language along with button pushing.
    Use that fuel pressure gauge for your initial setup and tuning but please don't leave it in place long term. Those things are notorious for rupturing and have been responsible for a whole bunch of cars (including more than one FFR) burning to the ground.
    Sep 2018
    SF Bay Area, CA
    This video from Ron Francis may be helpful for the headlight switch. They're definitely not a precision piece of equipment and will require some creative wiggling/swearing to take apart.
  18. #536
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Scott,
    Thanks Jeff. I will keep trying. Thanks for reminding me about the gauge. I had read that somewhere. At my "advanced" age it's always good to get the memory banks tickled. I will note it on my white board.
    Scott Pregont
    My Albums
  19. #537
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by JohnK View Post
    Helpful video! Thanks John.
    Scott Pregont
    My Albums
  20. #538
    Can't answer a specific Sniper question (haven't installed one) but the "fan thermo sw" wire in the RF harness when grounded activates the fan relay in the RF panel which in turn powers the +12V feed to the cooling fan. Most temp senders close to ground when they reach their rated temperature, which turns on the fan.
    For the Ididit headlight relay, that yellow wire has to go to a +12V feed from your headlight switch that's on when the headlight switch is on. Per my build notes, I wired to the RF harness LT BLUE HDLT SW -> DIM SW wire. It's purpose is to tell the module the headlight switch is on, so power the headlights on all the time and the dimmer signal switches from low to high. As opposed to no +12V on the yellow wire, which means the headlight switch is off and pressing the dimmer button activates the flash-to-pass function.
  21. #539
    Jul 2021
    Just watched your walk around video. Looking good. A couple questions related to aluminum panels. I thought the tall panels in the back corner of the cockpit had to be installed after the body was in place? You have them riveted now. Have you trialed that? Other question is related to the back aluminum upright panels (on the right side, it has the recess for fuel fill)...do people rivet thse to the down tubes on the chassis? If not, does the body pull them away from the tubes or does some type of gasket material need to go between tubes and panel?
  22. #540
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Two very good questions. I do not know the "right" answer for either one. All of these panels were in the car when it arrived and the body was removed with them in place. I am figuring that if I could remove the body with them in place I can replace the body with them in place. It may mean more than one try to mount the body if there is any trimming involved. Only time will tell.
    I did not rivet the side panels to the down tube. There will be bulb seal on the top edge that should conform to the body so the body will dictate how the panels fit along the top edge.
    I ask any previous builders to chime in here and give us both a heads up on how this all works.
    Scott Pregont
    My Albums
  23. #541
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thanks for your info on the Ididit switch. As for the fan thermo switch, if i'm understanding this, it needs to be attached to a temperature sensor located in the radiator so when the temperature of the water in the radiator reaches a certain level the fan comes on. I need to figure out how to wire that so that it works with the fan control of the Sniper. Any Sniper experts out there?
    Scott Pregont
    My Albums
  24. #542
    Jul 2021
    Thanks for the reply. I follow your logic and my logic has been similar. However, my kit arrived without the cockpit corner panels. Apparently FFR installs those after the body is mounted and on mine they forgot. Had to ship them separately. So, I guess just something to be aware of. Maybe seasoned veterans will chime in.
  25. Likes Namrups liked this post
  26. #543
    Mar 2021
    Ohio
    Scott,
    I have an Atomic 2, which is similar to a Sniper. It uses the temperature sender in my engine block, since it is a Cleveland, but I believe yours is in your manifold. You then use the Sniper interface to set at what temperature your fan comes on. There is a fan output wire that comes from your Sniper harness and goes to your fan relay to turn it on.
  27. #544
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by burchfieldb View Post
    Scott,
    Lying in bed last night I thought that might work. (I do that a lot... who needs sleep! ) Thanks for verifying. Do you know if there is any way to tap that signal and use it for the dash temperature gauge? There are two fan output wires. Maybe I can use fan output #2???
    Scott Pregont
    My Albums
  28. #545
    Mar 2021
    Ohio
    I called Holley and they highly recommend that we do not tap into the coolant sensor gauge wires for the efi. They would recommend using another sensor placed some where in the block for the dash gauge. I have my gauge on one of the extra water pump ports right now, but it always reads a lot hotter. I'm thinking of maybe using one of the coolant drain ports or figuring out a way to tap into the efi system, since they have seperate gauges available.
  29. #546
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    What about adding a "T" in the location of the Holly sensor for the second sensor? That should give the same reading for both sensors.
    Scott Pregont
    My Albums
  30. #547
    Mar 2021
    Ohio
    Yeah, I was just thinking the same thing.
  31. Likes Namrups liked this post
  32. #548
    Oct 2020
    Albany, NY
    Scott, don't do this. I tried it and here is what happens. Both sensors read cool. They have to be in the coolant flow to read accurately. What will happen (I promise) is your engine will not run right because temperature and O2 concentration are your only engine feedback sensors. If one is off so is the Sniper. If you want to control the fan with the Sniper (this is what I did) simply wire it in to "fan 1" and set the sniper to whatever you want the coolant temp upper and lower to be. The other option is to use the ground switch that came with the plug and either put it in the radiator or change your thermostat housing. Sniper is the easiest bet honestly.
    Also, I have a spare set of Jpipes. I can come by this weekend.
    Build 1 MK4 #10008 - Delivered 03/03/21, Graduated 7/20/22 - Sold 6/6/24 Build Thread #1 https://shorturl.at/K9fuy
    Build 2 MK4 #11061- Delivered 08/24/24 Build Thread #2 https://shorturl.at/OZowi
    Build 3 35 Pickup #329 - Delivered 10/28/25 Build Thread #3 https://shorturl.at/Ty4QQ
  33. #549
    Mar 2021
    Ohio
    So it would be best to put the dash temperature gauge sending unit in another port on the block or the manifold?
  34. #550
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Would love to have you stop by this weekend.
    Scott Pregont
    My Albums
  35. #551
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    When you tried this did you make sure all of the air was out of the "T" fitting? The reason I ask is I heat my house with hot water in the old cast iron radiators. I had an issue one winter where the circulator pump died. I was unable to get a replacement pump for a couple of days. The boiler continued to heat the water and the hot water went thru out the house (both floors). It took longer for the upstairs to heat up but it did. If the "T" was full of water I can't see why it would not be at the same temp as the surrounding water was. Maybe I'm missing something.
    The "J" pipes would at least let me do a first start when I'm ready. They won't fit my side pipes though.
    Scott Pregont
    My Albums
  36. #552
    Scott,
    The probe end of the sensors really need to be in the flow of moving coolant and I think most times when a T is incorporated one or both can wind up in “deadheaded” coolant that isn’t moving which renders them inaccurate.
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Scott,
    My only other choice is in the thermostat housing. Am I mistaken thinking that wont read anywhere close to the other one until after the thermostat opens?
    Scott Pregont
    My Albums
  38. #554
    Oct 2020
    Albany, NY
    That's right, but if its to control your fan who cares the fan shouldn't come on until the thermostat is open anyway. If you use the sniper to control the fan it uses the same sensor as the sniper does. there is a wire in the main harness you tap the green fan switch wire to, no extra sensor is required. That completes the circuit. I also wired in a bypass switch that goes to the dash so I can force my fan on if there was ever a problem. Not required though. If you are stuck give me a call. I can swing out if you need me to before this weekend.
  39. #555
    Oct 2020
    Albany, NY
    Yes, both my sensors (one for the Sniper and one for the gauge) are in my intake manifold. I have 2 ports and on ones sensor in each. Both read the same give or take a degree. I use the Sniper to control the fan so no switch is needed. If I did use a switch I would have put it in the thermostat housing.
  40. #556
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    34 degrees when I got up today!!! No kerosine available locally. Chilly day in the garage. Still managed to get a couple of things done.
    My power steering pump needed a remote reservoir. I was able to get one from Mike Forte. It arrived over the weekend. The biggest issue is the steering shaft is trying to take up the same space as the power steering lines need!
    I think using a 90 degree fitting on top of the pump ...
    And mounting the reservoir here ...
    I can use the two FF supplied hoses. That would only leave the reservoir feed hose with the 10an fittings that I will have to source. That line will have to snake around the steering shaft. Maybe using 45 degree fittings will help.
    I did work out a "T" setup for the water temperature sensors but given the recent recommendations I will undo it.
    Scott Pregont
    My Albums
  41. #557
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Also made up a mounting plate for the overflow reservoir using 1/8" aluminum.
    This looks like a good spot to put it.
    Scott Pregont
    My Albums
  42. #558
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Steering rack question
    The steering rack has two plugs. One blue and one red. Can anyone confirm, for me, that the red is the high pressure port from the pump and the blue is the low pressure port back to the reservoir. Thanks!
    Scott Pregont
    My Albums
  43. #559
    The lower (smaller) connection is the inlet. Upper connection (larger) is the outlet.
  44. #560
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thanks Paul!
    Scott Pregont
    My Albums
