Door Gaps | Body Work | How did you do it?
All,
Couple of Questions on Door Gaps:
How did you gaps your doors/hood/trunk?
I’ve seen this method:
Or
Did you use paint tape and sand them back?
Last question:
How big of an edge can you create with Rage Gold?
-some of the gaps are large and need to build out the edge on a couple of areas of the door
Matt
I did mine !!! If you need to add to an edge you need to bevel the area front and back and use HSRF . We call it "door stretching". You don't want regular body filler on the edges... Ad Tab
HSRF is impossible to find and 3M isn't quoting delivery dates! Every online/local purchase I've tried has been cancelled due to unavailability.
Maybe fill in the body door frame lip some instead of the door edge?
Yes right product, but you will only use less than a pint
Don't know if it's actually in stock, but a lot less expensive here:
https://www.explosivepowersports.com...BoC8b4QAvD_BwE
Everglass is another option
Gen 1 '33 Hot Rod #1104
Sanded the Kitty Hair down and mounted doors...
I hope this helps someone in the future...
Papa
on backorder for at least a few weeks . . . i have some on order through them
F5R #10227 - Forte's 363 EFI, IRS
Door w/ Rage Gold
Padawan
Door w/ Rage Gold
More to go...but getting closer
Namrups
YUP! I just got two gallons.....only waited 4 months. It should start showing up on the shelves. They are filling backorders first. In the interim I made my own with vinyl ester resin and a couple different fillers from West System epoxy fillers. Da Bat
This is helpful. I’m thinking of doing some of the rough filling work myself. Do you need glass on the thick fills ( like the top edge of the doors), or can you use HFRS only ?
Is there a preferred brand/type of rage gold ?
Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
I used the kitty hair because it was available and should not chip. HFRS is hard as concrete, works great. Rage Gold is good stuff, recommended by alot of folks here on the forum but I wouldn't use it to build up thick areas or building out edges.
Is the body shop going to give you a big discount for roughing in the body work? If not and your going to send it off to someone for paint...I would let them do it...they'll know exactly what to do.
----------Side note - only send your car to someone whose done several of these cars before...lots of people like Jeff, Ed and others you could reach out to here on the forum for bodywork/paint.
