Thanks Thanks:  4
Likes Likes:  6
Results 1 to 15 of 15
Thread: Door Gaps | Body Work | How did you do it?
    Aug 2020
    All,
    Couple of Questions on Door Gaps:
    How did you gaps your doors/hood/trunk?
    I’ve seen this method:
    Or
    Did you use paint tape and sand them back?
    Last question:
    How big of an edge can you create with Rage Gold?
    -some of the gaps are large and need to build out the edge on a couple of areas of the door
    Matt
    I did mine !!! If you need to add to an edge you need to bevel the area front and back and use HSRF . We call it "door stretching". You don't want regular body filler on the edges... Ad Tab
  3. Likes weendoggy, shmelty liked this post
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    HSRF is impossible to find and 3M isn't quoting delivery dates! Every online/local purchase I've tried has been cancelled due to unavailability.
    Scott Pregont
    My Albums
    O'Fallon, MO
    Maybe fill in the body door frame lip some instead of the door edge?
  6. Thanks GoDadGo thanked for this post
  7. #5
    May 2022
    Outside of Austin, Texas
    O'Fallon, MO
    Yes right product, but you will only use less than a pint
  9. Thanks GoDadGo thanked for this post
  10. #7
    Don't know if it's actually in stock, but a lot less expensive here:
    https://www.explosivepowersports.com...BoC8b4QAvD_BwE
  11. Thanks racingandfishing thanked for this post
  12. #8
    Jun 2018
    North Vancouver, BC, Canada
    Everglass is another option
    Gen 1 '33 Hot Rod #1104
  13. Likes shmelty liked this post
  14. #9
    Aug 2020
    The Kitty Hair Phase has begun:
    Body Work With Rage Gold
    Doors baking in the Sun, probably will wait a day before sanding
  15. #10
    Aug 2020
    Sanded the Kitty Hair down and mounted doors...
    I hope this helps someone in the future...
  16. Likes FF33rod liked this post
  17. #11
    Sep 2018
    Charleston, SC
    on backorder for at least a few weeks . . . i have some on order through them
    F5R #10227 - Forte's 363 EFI, IRS
  18. #12
    Aug 2020
    Door w/ Rage Gold
    Quote Originally Posted by Padawan View Post
    Door w/ Rage Gold
    More to go...but getting closer
  19. Likes FF33rod liked this post
  20. #13
    Quote Originally Posted by Namrups View Post
    YUP! I just got two gallons.....only waited 4 months. It should start showing up on the shelves. They are filling backorders first. In the interim I made my own with vinyl ester resin and a couple different fillers from West System epoxy fillers. Da Bat
  21. Thanks Namrups thanked for this post
    Likes Namrups liked this post
  22. #14
    Mar 2017
    moved to Hebron New Hampshire
    This is helpful. I’m thinking of doing some of the rough filling work myself. Do you need glass on the thick fills ( like the top edge of the doors), or can you use HFRS only ?
    Is there a preferred brand/type of rage gold ?
    Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
  23. #15
    Aug 2020
    I used the kitty hair because it was available and should not chip. HFRS is hard as concrete, works great. Rage Gold is good stuff, recommended by alot of folks here on the forum but I wouldn't use it to build up thick areas or building out edges.
    Is the body shop going to give you a big discount for roughing in the body work? If not and your going to send it off to someone for paint...I would let them do it...they'll know exactly what to do.
    ----------Side note - only send your car to someone whose done several of these cars before...lots of people like Jeff, Ed and others you could reach out to here on the forum for bodywork/paint.
