Results 1 to 2 of 2
Thread: Wiper High Speed Not Working
    Dec 2018
    Sherwood Park, AB
    Question Wiper High Speed Not Working
    Hi All,
    For my FFR supplied wipers, I used the roadster wiper wiring instructions as per
    https://www.factoryfive.com/wp-conte...ster-rev-P.pdf
    But when I try the wipers with the key in the Run position, I only get the low speed to work (mid-position of switch). When I put the switch to the top position, the motor cuts out.
    Has anyone run across this before? Do I need to move the brown (high speed) wire to a different terminal on the switch, such as to 1 or 7? (Instructions show it to terminal 8).
    32J
    Be sure that the wires aren't reversed. The diagram is from the perspective of either the plug or the motor, can't recall. It's easy to wire a mirror image.
  3. Thanks 32J thanked for this post
