Hi - Getting ready for go-kart rattle test. I have Coyote with the Tremec TKX and a hydraulic clutch throw-out bearing (Ram, I think). Pretty sure I bled the clutch line properly. The reservoir is still full.
Here's the issue: when I depress the clutch all the way and put the car into 1st, it starts rolling. And when I release the clutch, it stops. I thought the ports on the bearing were interchangeable. Is it possible to get the these lines reversed so that that the clutch is engaged with pedal all the way up, and disengaged when you actually press the pedal down???
32J
