Thread: Oil TEMPERATURE Sender Location for SpeedHut Gauge on Coyote
    Dec 2018
    Sherwood Park, AB
    Question Oil TEMPERATURE Sender Location for SpeedHut Gauge on Coyote
    Hi - I've installed the Oil PRESSURE sender for my SpeedHut gauge pack, using the tee-method described in the Coyote Fitment manual. There is no mention of the Oil TEMPERATURE connection point. Question for folks: is preferred location one of the available oil bungs on the Moroso oil pan, or, would it be on what seems to be an available bung on the oil filter manifold (center of following picture, it takes an H10 allen key)?
    Suggestions?
    Thanks!
    32J
    My preference is to measure in the sump.
  3. Thanks 32J thanked for this post
    Likes weendoggy liked this post
    mcwho's Avatar
    DeBary - Florida
    I just retested and notice that there is a MEGOHM reading between each terminal and the shell, there was no reading on the VOM between 3 connector pins and shell.
    Baghdad Bob
    Nov 2016
    "The i.e." SoCal
    T-sump of the oil pan.
    Nov 2016
    "The i.e." SoCal
    Quote Originally Posted by mcwho View Post
    Oil temp is 2 wire.
    Aug 2012
    Grand Rapids, MI
    Sump but I've also measured on the return line from the cooler. I believe that the sump provides the temps closest to bearing temps. The return line shows what is being fed to the bearings.
    My current build plan is one gauge, two senders and measure in the sump and return lines, changing with a switch.
    Jim
