neilkuy
Sorry, I don't have good reference with the solid axle as I am not using one/considered my design to allow for it. Right now, the driveshaft and the two pipes form a "triangle" when looking down the transmission tunnel. There isn't much clearance. I don't see how you could get a solid axle through the space with any vertical driveshaft/suspension movement without hitting the pipes. Maybe if the exhaust pipes were all the way into the corners, it maybe sufficient, but again it would hard to conclusively say without mocking it up. Once clear of the rear tunnel lower cross member (right below the differential pinion flange) I would imagine there would be space to drop the pipes below the solid axle, but I cant say whether this would impact the ground clearance.
