Results 1 to 3 of 3
Thread: Lokar emergency brake installation
    Jarrell, Tx
    Hey all,
    I'm working on a Mark II kit (I am not the original builder) that has what appears to me to be a Lokar emergency brake mounted on the transmission tunnel. (Part # 9109041 Lokar XEHB-7000F Floor Mount Hand Emergency Brake/Boot Kit, Black)
    The paperwork I got with the car has instructions on installation the brake cables to the disc brakes, but I have found nothing about mounting the handle.
    I don't believe it is mounted correctly. It binds underneath and I see no toothed "gear" to ratchet the brake tight. It is currently mounted to the 3/4 inch cross member (not the transmission... if that is even an option).
    Does anyone have installation instructions for mounting the brake handle?
    Rich
    Jan 2021
    Fort Lauderdale, FL
    Try this link for the .pdf document
    https://www.factoryfiveparts.com/con...structions.pdf
  3. Thanks bassemir thanked for this post
    Jarrell, Tx
    This is awesome, just what I was looking for. Thanks a ton!
    I was able to correct the brake handle installation. I now have an emergency brake.... just in case of an emergency.
