23
522
Originally Posted by
progmgr1
Batteries under the floor are what I've been thinking about for my possible future project. Are you going to have access after the car is built? Making the floorboards removeable or something? All in all, great progress on an exciting build!
Keith HR #894
You were thinking about converting a Woody right? That would be really cool. Have you thought more about which motor?
Mine will be accessible from the bottom. I'll design enclosures for each side with 4 packs per. They will be under 100lb each so fairly easy to lift up in to place. Flanges in the bottom plate for each pack will bolt to the chassis rails. They need to be sealed up pretty good to keep debris and water out but I'll have access panels on each end for HV cable connection.
