Thanks Thanks:  34
Likes Likes:  93
Results 1 to 40 of 322
Thread: North Florida 289 Build, #10306
Threaded View
  1. #11
    May 2020
    St. Johns, FL
    Soooooo, I was working on installing the Russ Thompson turn signal hardware and opening up the steering shaft hole in the dash. After doing so, I realized that the FIA 289 dash won't work as it is cut from FFR. When centered on the pre-cut hole, the larger steering shaft hole makes the dash sit too high on the DS, such that the tach and left-most gauge won't fit under the hoop. The turn signal/high beam indicators are now sitting in the hoop. Also, the bezels for the gauges and the RT mod interfere, so I can't open up the hole any more in the vertical. The speedo fit was marginal with the hoop already, so I can't move that side up. At least part of this is on me, for sure, as I didn't imagine things would be this far out of whack.
    I can see where things need to move, so I'll be calling FFR for a blank dash here shortly. Yeehaw.
    Jack
    289 Roadster complete kit ordered 8/2/21. Delivered 3/14/2022. Chassis #10306. 17"x9" Halibrands, 3.55 IRS, PS, Wilwood brakes, BPE 306 with Edelbrock ProFlo4 EFI and close ratio TKX. First start 7/20/2023. First go-kart 9/25/2023. Registered in FL 11/17/2025
    Build thread - https://thefactoryfiveforum.com/show...rida-289-Build
