Thanks Thanks:  3
Thread: TKX Wiring for Coyote
    Dec 2018
    Sherwood Park, AB
    Question TKX Wiring for Coyote
    Would anyone have a schematic or advice on connecting the clutch safety sensor and the reverse brake lights on the Tremec TKX? Connecting the speedo was easy because the Ron Francis rear harness already had the plug. In the pedal box, I already connect the clutch safety wires to the cylinder plunger switch, per instructions. But I can't find any instructions or wiring diagrams that talk about the clutch safety switch at the transmission itself. Same for reverse brake lights.
    32J
    The clutch safety switch interrupts the starter and doesn't go to or through the transmission. For the backup light, there is a plug on the trans. You can buy the pigtails/plug connector from various sources.
    https://www.cjponyparts.com/modern-d...xoCFswQAvD_BwE
    Dec 2018
    Sherwood Park, AB
    Question
    For the clutch safety connector on the trans, would you suggest that I just terminate the wires or tape it off (or shunt the wires if it's a normally open switch)?
    Thanks!
    Are you talking about the neutral safety switch? I just left that plug on the harness and zip tied it to keep it out of the way.
  5. Thanks 32J thanked for this post
    Just to make sure it's clear, the Coyote control pack harness comes with a clutch safety switch. Doesn't involve the Ron Francis blue start wire or the transmission. Just wire it like the Ford and FF instructions show. Tie the blue RF wire intended for the safety switch out of the way or remove. Doesn't matter if the two ends (where the switch would normally go) are tied together or not. They're not in the circuit when the Coyote switch is used.
  7. Thanks 32J thanked for this post
  8. #6
    Thanks, Paul. I didn't realize that. Sorry for giving bad info.
    Jun 2017
    Quote Originally Posted by 32J View Post
    32J
    I am pretty sure the reverse light is just a normally open switch, right? (I didn't use it)
    You just run your lead though it and when its not in reverse the contact isn't made and no current passes through then when you are in reverse it competes the circuit.
    Michael aka @my_cobra_build on Instagram
    Base MK IV Roadster with several options. Body is Lamborghini Grigio Lynx w/ Audi Vesuvius Gray stripes. 25th Anniversary FFR wheels. Seats and interior by Intatrim.
    Gen1 Coyote w/ Comp Cams & Cobrajet manifold. Tremec TKO 600 w/ a midshift kit. 2015 IRS w/ 3.73 Torsen diff. FFR Headers, Gas N Pipes, Power steering & power brakes.
  10. Thanks 32J thanked for this post
  11. #8
    Dec 2018
    Sherwood Park, AB
    Thanks, everyone!
    32J
