07-07-2022, 05:12 PM
#361
Namrups
Like many others I have never attempted a project like this and am grateful to to other builders that have detailed their builds. I am paying it forward by detailing my build as well in the hopes it will help anyone else.
I am also very grateful for the amount of time everyone in this community takes to detail things out for others to learn and plan to pay it forward as well, once I recieve my coupe in Octoberish time frame.
On an unrelated note, what is everyone's thoughts on Mustang style gas tank vs something like a Fuel Safe fuel cell?
07-07-2022, 08:12 PM
#362
Using a fuel cell never crossed my mind. I am going with the kit supplied tank and possibly a drop trunk. Haven't decided on that one yet. This might be a good question to start a fresh link on.
07-08-2022, 09:38 AM
#363
burchfieldb
My understanding on fuel cells is they need bladder replacement every X number of years and are $$$, and if you're tracking then great do it, but if not tracking then nothing better then old reliable gas tank.
07-11-2022, 08:17 AM
#364
07-11-2022, 08:24 AM
#365
07-12-2022, 02:50 PM
#366
Looking great Scott! Like your method of "fitting" the trick flow there. Did you need to flatten the seams/tabs on the gas tank to install (I think they are in the back?)?
07-12-2022, 08:47 PM
#367
rhk118
Yes I did have to flatten the edges. Two in the back and one in the front. I also agree with what Paul did and ordered some 1/8" foam to put between the tank and the frame to keep it from possibly rattling or scraping. I will apply that when I put the tank in for good.
07-13-2022, 10:27 PM
#368
07-13-2022, 10:36 PM
#369
07-13-2022, 10:41 PM
#370
Gen1 Coyote / TKO600 / IRS
07-13-2022, 10:45 PM
#371
07-14-2022, 11:51 AM
#372
07-14-2022, 02:48 PM
#373
After a very long wait I received my harness today!
Spending the next ten days on a staycation with my daughter. Not sure what kind of progress I'll have.
07-15-2022, 08:32 PM
#374
You are trucking along Scott! You go - looking fantastic!
07-15-2022, 09:44 PM
#375
cgundermann
Thanks Chris!
07-18-2022, 09:01 PM
#376
07-18-2022, 09:17 PM
#377
07-18-2022, 09:51 PM
#378
Looking very clean and tidy. As an old friend liked to say, "that's the kind of leadership we're looking for."
07-22-2022, 10:20 AM
#379
First major screw-up!
I was sitting in the garage in 90 degree heat painting my rear hubs and spindles when all of a sudden that light in my head lit up and almost blinded me! I had gone thru the process of changing the studs in the hubs and cutting them down to fit the 1" spacer. Measuring multiple times and picturing everything in my head because I was missing brake parts so I couldn't actually mock it up. Thought I was good to go. Wrong! Because I didn't have the Wilwood brakes I totally forgot that they would be between the hub and the spacer. I cut the studs too short!!!
Will have to order new studs and repeat that process again.
07-22-2022, 10:32 AM
#380
07-22-2022, 10:46 AM
#381
Not a waxer
You're doing good Scott!
07-22-2022, 11:32 AM
#382
Jeff Kleiner
Thanks Jeff. Moral support is always welcome.
07-22-2022, 01:57 PM
#383
Namrups
I did that kind of thing so many times
Good news is the second time you will really be great at it.
07-22-2022, 03:59 PM
#384
Blitzboy54
Simple screw up. I know I will probably make more. Hopefully nothing too costly.
07-23-2022, 10:20 AM
#385
Day 30
Ready to continue on the front end. Latest update on brakes is October so this will then go on the "to be completed" list.
07-24-2022, 07:07 AM
#386
07-24-2022, 07:09 AM
#387
Wishfull
I love the red.
More to come .....
07-24-2022, 11:23 AM
#388
07-25-2022, 08:10 PM
#389
07-26-2022, 11:24 AM
#390
Day 33
Now that the diff is in and torqued I wanted to lay out and prep the rest of the rear suspension.
Most everything is there except on the upper control arms. I'm missing the 1 1/4" lock nuts and the 4 1/2" mounting bolts that attach the UCA to the spindle.
Also waiting on the CV axles.
07-28-2022, 07:11 PM
#391
07-28-2022, 07:13 PM
#392
07-29-2022, 06:45 AM
#393
Wow! Tremendous progress Scott, nice work!
Type 65 Daytona Coupe Complete Kit ordered 11/2021, delivered 7/25/2022....the fun has begun!
07-29-2022, 10:43 AM
#394
Received my wheels today.
07-31-2022, 08:36 AM
#395
Day 38
Finished installing the rear suspension including the sway bar. Had issues with the sway bar that I will explain later. Still missing a few parts so it's not all torqued down yet.
Next up is fuel and brake lines.
07-31-2022, 09:06 AM
#396
07-31-2022, 08:27 PM
#397
Namrups
A BIG HEADS UP!!
I'm am not sure if this is a heads up for the roadster as well but if you are building the coupe with IRS and rear sway bar pay attention!!
What I did..... on page 134 of the manual is the installation of the Toe Adjustment Bar commonly referred to as the toe link. The manual states that "If using the sway bar option, pass the bolt through the frame mount bracket when installing the toe arms". The picture shows the bracket in place. I am using the sway bar so I dug out the brackets and installed them as shown. I was not planning on removing the toe link so I torqued it to spec. After I had completed installing the rest of the suspension I decided to also install the sway bars even though I was missing the rod ends for both front and rear. Those are out in the open and can be added later. The manual does not have the install instructions for the sway bars but I was able to find them on the FF site listed under the roadster section. After pulling everything out of the sway bar box I noticed that in the bag of hardware for the rear sway bar there were 5/8" bolts. When I installed the toe link I did notice that because of the added sway bar bracket the bolt looked a little short but not having read any issues about it nor seeing anything in the manual I accepted it as ok. Lesson learned. The new bolts are longer and allow the nut to seat as it should so they had to be replaced. As you can see, by the following 2 pics of the replaced bolt, there is very little room with the rest of the suspension installed! It was a bear getting the original bolts out and the new ones in and torqued. One to two clicks on the ratchet was the max.
WHEN ADDING A SWAY BAR TO IRS, MOUNT THE SWAY BAR BRACKET WITH THE NEW LONGER BOLTS WHEN INSTALLING THE TOE LINK! Don't do what I did....not fun.
Good caution. Agree, easy to miss. The Factory Five instructions website (https://www.factoryfiveparts.com/instructions/) is a good source and should always be checked. Especially for options not typically shown in the build manual. I've frequently found what I needed there. Although to be fair, the IRS sway bar instructions you found on the website, in addition to showing the longer bolts on the exploded diagram, does say "Use the new included 5/8 ”x 2.50” bolt for the Toe link." Hate to point it out, and not being critical. We've all missed things. And paid frequently with extra work. Part of the experience, right? Your build is looking great. The red suspension is cool.
Build Thread and
Video.
Build Thread.
Build 5: 35 Hot Rod Truck #138.
Build Thread. Sold 11/9/2023.
Build 6: Mk5 Roadster 30th Anniversary #11,258.
Build Thread.
07-31-2022, 10:25 PM
#398
edwardb
https://www.factoryfiveparts.com/instructions/) is a good source and should always be checked. Especially for options not typically shown in the build manual. I've frequently found what I needed there. Although to be fair, the IRS sway bar instructions you found on the website, in addition to showing the longer bolts on the exploded diagram, does say "Use the new included 5/8 ”x 2.50” bolt for the Toe link." Hate to point it out, and not being critical. We've all missed things. And paid frequently with extra work. Part of the experience, right? You're build is looking great. The red suspension is cool.
Thanks for the encouragement Paul. I really appreciate it. The red has come out even better than I had envisioned. Building these is like a chess match. You always need to be thinking moves ahead trying not to miss things like this. Even after reading your thread along with many others multiple times it's still easy for a first time builder, like myself, to miss stuff.
07-31-2022, 10:38 PM
#399
08-01-2022, 05:43 AM
#400
Namrups
Played around with the brake and clutch reservoirs today.
Option 1
Option 2
I'm leaning towards option 2. If anyone sees any issues with either option or has an option 3 please speak up!
Even with your SBF 427 (as opposed to the Coyote in mine, where neither option would work) anything on the outside of that frame rail will probably need to be moved out of the way to get the engine in and out. Plus (maybe) kind of in the way for maintenance, e.g. headers, spark plugs, etc. You wouldn't regret having them all inside the two frame rails and out of the engine compartment. But probably not possible with those individual mounts. Hopefully other non-Coyote builders can provide some feedback.
Build Thread and
Video.
Build Thread.
Build Thread.
