Results 1 to 10 of 10
Thread: Coyote EFI Harness Fusel Panel Bracket - Logo Reversed???
    Dec 2018
    Sherwood Park, AB
    Question Coyote EFI Harness Fusel Panel Bracket - Logo Reversed???
    Just wondering if anyone else has had this same 'cosmetic' problem. The Coyote Fitment instructions are simple enough: locate the fuse panel mounting bracket with the logo, and mount to the passenger side footbox:
    Screenshot 2022-05-23 123438.pngScreenshot 2022-05-23 123513.pngScreenshot 2022-05-23 123525.png
    The problem? This is what I received in my kit:
    Was this just a bending error with the bracket (i.e. bent it the wrong way), so now the logo is backwards? Or, did they intend that the bracket be turned 180° so that the panel mounts further back, like this?:
    I have a heater at the firewall so I can only get the box so close. Don't want to start drilling until I know the harness will reach all the right spots.
    32J
    Aug 2021
    Moyock, NC (OBX/Hampton Roads)
    Yes yours is bent backwards. I have one I’m not using, I mounted mine to the firewall. It has a light coat of black vht paint on it but you’re welcome to it for shipping.
    MK4 Complete Kit #10315 / Coyote G3 / TKX / 427 HardTop
    Build Thread Production Date: 2/26/22, Registered 5/19/22, Graduated 3/1/2023
    May 2020
    Yarmouth, Maine
    Yours was bent the wrong way, I had the same issue. I mounted the control box to the firewall and then modified the bracket as a mount for my brake/clutch reservoirs (Scott’s Hotrod Triple).
  4. Thanks 32J thanked for this post
    Nov 2018
    CT
    I also mounted mine to the firewall and used that bracket to support the heater bypass.
    Dec 2018
    Sherwood Park, AB
    Thanks, but I think I'll try and come up with a work-around. Showing the logo is not high on my wish list.
    Dec 2018
    Sherwood Park, AB
    Do you have wiper motor as well? I'd be interested to see where you placed the EFI fuse box in relation to the heater fan and the wiper motor. Thanks!
    May 2020
    Yarmouth, Maine
    Quote Originally Posted by Lidodrip View Post
    Here is how I repurposed my bracket:
    Dec 2018
    Sherwood Park, AB
    Would you have a picture of where you mounted the Coyote fuse box? I have a wiper motor and heater as well. Thanks.
  10. #9
    May 2020
    Yarmouth, Maine
    Quote Originally Posted by 32J View Post
    I mounted my fuse box on the firewall/driver's side. I attached it to the cross beam after tapping some holes. It seems to work well there, plenty of clearance and the cables are long enough to reach the PCM. I have wipers (Specialty Power Windows), but do not have a heater. I don't think this location would interfere with either. I am not using a master power cut off switch, but I think this location would work well if one did decided to use a switch.
    Good luck,
  11. #10
    Aug 2021
    I have a heater, wipers, and coyote and mounted mine similar to James, just a little higher up.
