Thanks Thanks:  34
Likes Likes:  93
Page 2 of 9 FirstFirst 1234 ... LastLast
Results 41 to 80 of 322
Thread: North Florida 289 Build, #10306
    May 2020
    St. Johns, FL
    Slow going as I'm still missing parts here and there and work/landscaping getting in the way. Ready to install the diff/IRS hardware when I return from a work trip to west Texas.
    Jack
    289 Roadster complete kit ordered 8/2/21. Delivered 3/14/2022. Chassis #10306. 17"x9" Halibrands, 3.55 IRS, PS, Wilwood brakes, BPE 306 with Edelbrock ProFlo4 EFI and close ratio TKX. First start 7/20/2023. First go-kart 9/25/2023. Registered in FL 11/17/2025
    Build thread - https://thefactoryfiveforum.com/show...rida-289-Build
  2. Likes Zach Bohn liked this post
  3. #42
    May 2020
    St. Johns, FL
    Slow progress as I was away on work travel and we had family in town for a week after that. How hard can one crank down on the brass outlet fittings on the master cylinders? I know they need to be pointed up, but I’m not sure they’re in tight enough.
    Jack
  4. Likes Zach Bohn liked this post
  5. #43
    Michigan
    If you can figure out the type of pipe thread it is, then you can simply look on a chart to find what that joint is designed to be torqued to.
    Example NPT (National Pipe Thread) torque chart:
    https://www.engineersedge.com/hardwa...tion_13424.htm
  6. Thanks Chainsaw thanked for this post
  7. #44
    May 2020
    St. Johns, FL
    A little more progress, but stuck on this task awaiting parts.
    Also, having a tough time getting the last bolt in on the IRS diff installation (aft passenger side bolt into the diff housing). It’s off just enough that that I can’t get the threads started. Still working on it.
    Jack
  8. Likes Zach Bohn liked this post
  9. #45
    May 2020
    St. Johns, FL
    So after letting the car sit for 5 days, I come back, clean up the PS rear mounting hole threads on the diff, and the bolt goes right in. Diff installed and most of the suspension, but missing 2 bolts to allow me to finish*. That’s the story of this car and my POL wait list. I can’t finish much as there is a bolt missing for that assembly, a part for the other assembly, etc. I did receive the electrical harness and driveshaft this weekend, but not anywhere close to the point that I can even consider installing those. I will get one of the rear uprights/hubs installed today and then steering shaft, but I’ll have to switch to full-time aluminum body panel prep here shortly.
    *Does anyone know where on-line I can buy M16x2.00 110mm bolts without having to buy a pack of 25? I’ve not had any luck tracking those down. I only need 2 to finish the IRS installation less shocks (no springs yet).
    Jack
  10. #46
    Dec 2021
    I bought a 5 pack from McMaster. They’re a different finish than the others but were stronger.
    Mk4 Roadster, Complete Kit, 302 Carb. Blueprint, T5, IRS, Power Steering, Hydraulic Clutch, Wilwoods, 15" Halibrands, Ordered August 2021, Completion March 2022, First Start 6/22/22, First Drive 6/26/22
  11. Thanks Chainsaw, WIS89 thanked for this post
  12. #47
    May 2020
    St. Johns, FL
    I looked there and could only find 100mm length and regular hex head vs the flange head. I don't care about the finish. I'll look again. Thanks.
    Jack
  13. #48
    Aug 2021
    Moyock, NC (OBX/Hampton Roads)
    Quote Originally Posted by sam_sturdy View Post
    edit - replied to wrong message.
    MK4 Complete Kit #10315 / Coyote G3 / TKX / 427 HardTop
    Build Thread Production Date: 2/26/22, Registered 5/19/22, Graduated 3/1/2023
  14. #49
    Aug 2021
    Quote Originally Posted by Chainsaw View Post
    Not sure if you have 'Do it Center' hardware stores around, but my local mom and pop place had every grade 8 bolt that you could possibly imagine. I was able to find everything on my POL list for about 50$ and kept right on moving. I would imagine an Ace hardware might be similar, but the smaller places surprisingly have a crazy selection vs HD or Lowes.
  15. Thanks WIS89 thanked for this post
  16. #50
    May 2020
    St. Johns, FL
    The Ace Hardware I went to already didn’t have the flange head bolts that long. I have another close by that I’ll check.
    Jack
  17. #51
    May 2020
    St. Johns, FL
    Some progress on the rear end. Did the passenger side IRS install.
    Still a few things to work on that I can complete (sway bars, tank installation, steering shaft, body panels.) Fun times.
    Jack
  18. #52
    May 2020
    St. Johns, FL
    Finished the IRS installation with the sway bars, but still don’t have the rear springs to finish the shock build up and installation. Thanks to FFR in expediting the 2 missing M16x110mm bolts to me.
    Re-centered the power steering rack and cleaned up the installation.
    Installed the steering shafts/knuckles. Everything seemed to go together pretty well (which frightens me and makes me think I screwed it up somehow.)
    Will start installing the fuel tank and several body panels next.
    Jack
  19. #53
    Ottawa, Canada
    I'm also building mine loosely on 2557. I may go with a lighter color but I'm planning on attempting the dash layout/interior.
    I was able to get speedhut to print my speedo and tach with SW logos. I went with a 3 3/8 speedo and 4" tach.
    The center dash gauges are larger than the standard FFR gauge package.
    oil temp, oil pressure, water temp and amps gauges are 2 5/8 SW and the fuel is a 2 1/8 SW.
    3D printing my glovebox and will machine a glovebox latch as close as I can muster to the originals.
    I have just about everything I need to start building other than Control Arms which Gordon Levy has for me sitting in a box somewhere between his shop in Arizona and my house in Ontario Canada.
    10 years after my roadster build....
    289 FIA (pickup 28/08/20 if covid permits)
    currently building a 289 and accumulating parts needed to finish a Canadian Kit.
  20. Likes Chainsaw liked this post
  21. #54
    May 2020
    St. Johns, FL
    Working on body panels. Fuel tank next.
    As some have stated on the forum, the instructions can be a little vague. Sorting out what extra steps you have to do is part of the fun, I guess.
    Jack
  22. #55
    Apr 2022
    Try Belmetric. They sell individual bolts.
    https://belmetric.com/bolts/?Diamete...&Length=110mm&
  23. #56
    May 2020
    St. Johns, FL
    Taking a couple of days away from the project. Got the floor and footbox panels mounted. Now waiting on parts and working my consulting gig (=making some money for more parts.)
    Jack
  24. #57
    Ottawa, Canada
    You're already ahead of me. Awaiting control arms all around, somewhere between Levy's shop and my home?
    Things are looking great on your build. The brushed aluminum looks really good.
  25. Thanks Chainsaw thanked for this post
  26. #58
    May 2020
    St. Johns, FL
    Quote Originally Posted by OttawaFFRer View Post
    Thanks. It helps to be mostly retired.
    The Scotchbrite scrub really works out, but it can be tedious. Thanks to whoever came up with that one. I'm still waiting on front upper control arms and the Wilwood brakes to finish up the corners. POL stuff is coming in slowly, but coming in. Got my windshield last week.
    Ready to install the fuel tank next, then hook up the MCs and run some brake lines. Buying plenty of stuff from Breeze, Russ T, Period Correct, etc. to try to keep the parts coming in to stay on track.
    Jack
  27. Likes Ted G liked this post
  28. #59
    May 2020
    St. Johns, FL
    Made a little progress. Assembled a 255 lph Walbro pump and ProM hangar and installed in the tank. The pump is overkill for my project, but if I go with more power later, I didn’t want to have to redo the pump/hanger. Tank ready to install as soon as I tighten up the coupler nuts on the “Kleiner mod”. Waiting for the POR15 on the couplers to dry.
    Made a bracket from some unused body panel material and installed the Scotts Hotdods triple reservoirs. I think the unit positioned okay, but please advise if I should consider moving it. Still need a grommet for front of the foot box for the three hoses running to the MCs.
    AED714DC-92FA-43FA-B179-3EF105E7D667.jpg74CB6C17-5425-4157-AB66-A886E912BB68.jpg3206C035-5B2A-4143-9D30-58DF2800AA33.jpg
    I’m going to redo the reservoir bracket with some .063” 6061. The .040 stuff is probably okay, but I don’t like the flex I’m seeing even with the hoses attached.
    Jack
  29. #60
    May 2020
    St. Johns, FL
    Jack
  30. #61
    May 2020
    St. Johns, FL
    Received the front UCAs yesterday and worked on them today. I think I did things correctly, but it was a long wrestling match today to get the IFS completed. I still have to torque the hub nuts.
    Still waiting on Wilwood brakes.
    Jack
  31. #62
    May 2020
    St. Johns, FL
    Got on the list with Spotlight Customs for paint/body. Lead time is roughly 6 months. Should match up good with my pace (if I get a move-on.)
    Jack
  32. Likes cnutting, RFracer liked this post
  33. #63
    May 2020
    St. Johns, FL
    Finished the Breeze engine compartment battery box installation. Had to break out the HF pneumo rivet gun to install those SS rivets. I didn't have enough lead in my pencil to do those manually.
    Ran the front brake lines. The NiCop line is pretty easy to use overall, but getting it straight seems to be a challenge for me. My engineering and QA tendencies were definitely triggered, but I had to get past that.
    Moved on to running the rear brake line. Made several minor errors that eventually caused me to realize I needed to "rip" all that out and start over, but I learned a lot. That was another humbling experience in this long series of humbling experiences.
    I did get some help which may have distracted me.
    Jack
  34. Likes GoDadGo, Rocket Rob liked this post
  35. #64
    May 2020
    St. Johns, FL
    I want to add some lower bracing to the dash. Are there any strong opinions regarding using Mike Everson's under dash panel vs the Breeze support brackets?
    Jack
  36. #65
    May 2020
    St. Johns, FL
    Re: the above, I ordered Mike Everson's under dash filler panel.
    For any owners in hot-n-humid areas, do I need to go with a larger coolant expansion tank than what's provided by FFR? My ride will be mostly a cruiser, but I will do some autocross and maybe some HPDE runs on a track. I'd rather bite the bullet now than try to redo the system later.
    Jack
  37. #66
    Best Helper You Could Ever Get!
    ....Wrench On Chainsaw, Wrench On!
  38. Likes Chainsaw liked this post
  39. #67
    Northern Virginia
    I'm in Virginia, not as hot as you, but it gets pretty warm and humid in the summer. I used a larger tank, with my 302 it was difficult to get the right level in the FFR supplied tank. I found one on Jegs that was similar in style to the FFR expansion tank. My notes say it was this one (Jegs 52oz 3x16 inch stainless coolant overflow tank):
    https://www.jegs.com/i/JEGS/555/511036/10002/-1
    OF course there are many choices, I just liked the look of the FFR tank and decided to find one of a similar size.
    FFR MKIV 8309, FMS 306 Crate w/Edelbrock EFI, T5, 3.55 Three Link, Wilwood Brakes
  40. Thanks Chainsaw thanked for this post
  41. #68
    May 2020
    St. Johns, FL
    My grandson acted like he knew what he was doing which is more than I can say about my work.
    Jack
  42. #69
    May 2020
    St. Johns, FL
    Quote Originally Posted by Chopper View Post
    Going with the JEGS tank. Thanks for the recommendation.
    Jack
  43. Likes Chopper liked this post
  44. #70
    May 2020
    St. Johns, FL
    POL stuff coming in after a dry spell. Roll bar assembly came in today. Some fastener hardware and rear springs on the way.
    Got the brake lines done (UGLY, but functional.) Still fighting with fuel lines. I also got the TrickFlow fuel filter located and mounted (similar to Mr. Borror's 20 Anniv build).
    Received some Fragola hose end fittings yesterday and found out today that I ordered the wrong ones. Ordered the right fittings today and sending the wrong ones back.
    Got the DS elephant ear temporarily mounted before I ran out of time. Will do the PS on tomorrow. I should have done this when I installed the F-panel. Lesson-learned.
    Jack
  45. #71
    May 2020
    St. Johns, FL
    Got the fuel hard lines fitted in yesterday. They look far better than I expected. Now to work on building the hoses.
    Rear springs showed up on my doorstep today. Built up the rear shocks and then couldn't find the 4" bolts for the top shock mount. They must've walked away, so I made yet another trip to Ace and secured 2x. Too hot to work in the garage this afternoon (feels like 130F in there), so I'll finish the shock installs next week.
    Jack
  46. #72
    May 2020
    St. Johns, FL
    Another POL shipment due today and my wheels are supposed to arrive this coming week. I’m trying to keep the outflow of boxes at least equal to the inflow of new boxes.
    Jack
  47. #73
    Sep 2015
    Beachside
    While I didn't have the POL issue, I had to manage boxes coming in from other parts/tool suppliers to keep them under my wife's RADAR....
    FFR #8833 289 FIA 3-link
    Picked up 3/5/2016, First start 4/22/2017, MA legal 7/11/2018, Sold 8/2025
  48. Likes Chainsaw liked this post
  49. #74
    May 2020
    St. Johns, FL
    Quote Originally Posted by cnutting View Post
    Oh, yeah. My wife keeps wondering why there’s still so many boxes stacked up in the garage since so many parts are on the car and I’ve thrown away or recycled many boxes already. “Gee, I don’t know, honey.”
    Jack
  50. Likes cnutting liked this post
  51. #75
    May 2020
    St. Johns, FL
    Big screw-up yesterday. I was cutting the 3" hole for the DS blast gate using an adjustable hole saw. Just as the saw was cutting through the adjustable part decided it wanted to adjust itself right then and there (set screw unset) causing some significant spiral scratching on the foot box front face. Not structurally significant, but quite ugly. It won't buff out without removing significant material. I'll pass.
    So I ordered some .040 6061 sheet stock to attempt to make a bezel for the front face of the foot box and bought some real hole saws.
    While I wait, I'll read up on and start on the electrical harness install.
    Jack
  52. #76
    May 2020
    St. Johns, FL
    The Before with scratches and the mis-drilled holes due to a drill template that didn’t exactly match what needed to be drilled.
    And the After with the new bezel to cover the hideous stuff in the picture above.
    Fun times.
    Jack
  53. Likes cnutting, RFracer liked this post
  54. #77
    May 2020
    St. Johns, FL
    On to the PS vent and how it should looked installed.
    I'm not doing the final install as I assume I'll need to punch this through the carpet and insulation first.
    Wheels arrived today, but 2 of them are 17x10.5. Not that I wouldn't want them, but per everyone they're too wide for the 289 Roadster. Waiting for FFR to contact me back about a swap for the correct 17x9.0 versions.
    Jack
  55. Likes Chopper liked this post
  56. #78
    May 2020
    St. Johns, FL
    Question on the installation of the blast gates. I really don't want to mount the blast gate on the outside of the footbox, but I'm not sure I'll have enough thread engagement on the outside of the box after pushing this through the insulation and carpet. Does anyone have any guidance and/or recommendations on this?
    Jack
  57. #79
    Jan 2020
    State of Jefferson
    I am a little confused by what you are asking, thread engagement? It looks like you already have the gate mounted and would just cut the insulation/carpet around the gate on the inside of the footbox. You just need to use a hose clamp to affix the hose to the lip sticking out of the gate. On the inside I ended up using a choke cable attached to the gate to manually open and close mine which has been working good.
  58. #80
    May 2020
    St. Johns, FL
    I was intending to put the insulation and carpet down first and then install the gate on top of that. I am concerned that the thickness of the insulation/carpet would be such that I can’t get enough thread engagement and/or enough engagement for the 3’’ hose clamps to get a good grip on the gate. I’ll probably put the insulation down first and punch through for the 4 attachment studs and the 3” lip. Then, I’ll cut the carpet around the most of gate assembly as you mention above. Thanks for the input.
    I have the vent pull knobs and cables from Period Correct that I’ll attach.
    Jack
