Coyote EFI Harness Fusel Panel Bracket - Logo Reversed???
Just wondering if anyone else has had this same 'cosmetic' problem. The Coyote Fitment instructions are simple enough: locate the fuse panel mounting bracket with the logo, and mount to the passenger side footbox:
Was this just a bending error with the bracket (i.e. bent it the wrong way), so now the logo is backwards? Or, did they intend that the bracket be turned 180° so that the panel mounts further back, like this?:
I have a heater at the firewall so I can only get the box so close. Don't want to start drilling until I know the harness will reach all the right spots.
Yes yours is bent backwards. I have one I’m not using, I mounted mine to the firewall. It has a light coat of black vht paint on it but you’re welcome to it for shipping. 197B3C3D-C33C-445A-9BB7-F0B55408B354.jpg
Yours was bent the wrong way, I had the same issue. I mounted the control box to the firewall and then modified the bracket as a mount for my brake/clutch reservoirs (Scott’s Hotrod Triple).
Here is how I repurposed my bracket:
Would you have a picture of where you mounted the Coyote fuse box? I have a wiper motor and heater as well. Thanks.
I mounted my fuse box on the firewall/driver's side. I attached it to the cross beam after tapping some holes. It seems to work well there, plenty of clearance and the cables are long enough to reach the PCM. I have wipers (Specialty Power Windows), but do not have a heater. I don't think this location would interfere with either. I am not using a master power cut off switch, but I think this location would work well if one did decided to use a switch.
Good luck,
