33 Hotrod unfinished project for sale
9B1D7BE4-6B6F-4142-BDA7-D3DB3DB031E9.jpg8D0BC8BF-E24D-4DF9-B51E-009F162AB784.jpgB068A8B7-F061-4238-A158-B7706D156565.jpg0C8C410B-332E-4FD0-B2DC-38D7F6A71E04.jpgA5E86D74-A392-458C-85D9-59F2DA1DDD10.jpg
SOLD!!
Hey all,
Thanks for looking. I am putting my 33 Hotrod project up for sale. Unfortunately I don’t have the time to work on it and finish it. I have put a lot into it and have 99% of the parts needed to complete, just no time. No money was spared in the process along the way as you can see by the list below of most of the major components that will come with. I believe the only parts needed would be a driveshaft (I was going to have a custom carbon fiber driveshaft made) and the lines needed for the fuel and coolant system. Both fuel and coolant system lines are setup to be AN lines and I have all of the fittings I could think I would need. Here is a list of most of the major components for the project that will come with.
-Factory Five Racing ‘33 Hotrod complete kit w/ powdercoated frame
-3 link rear suspension
-Electric power steering
-Power windows
-Removable hard top
-Roadster windshield
-Grill powdercoated satin black
-Serial #F5R1000558HR
-Built to rolling chassis w/ engine & trans installed
-Suspension components powdercoated
-Ford Racing 363ci Boss short block Part #M-6009-363
-AFR Renegade Heads
-ARP Head Studs
-Jesel shaft mount roller rockers
-Trick Flow Track Heat intake manifold
-Trick Flow high flow fuel rails
-Ford Racing 47#/hr fuel injectors
-Ford Racing 90mm Mass Air Flow
-Ford ‘91 Mustang 5.0 ECM
-Canton road-racing oil pan (powdercoated)
-Energy Suspension urethane motor & trans mounts
-ATI Super Damper
-Meziere high flow 55gpm electric water pump
-MSD Pro-Billet distributor
-MSD Digital 6AL ignition
-MSD Blaster SS coil
-McLeod billet aluminum flywheel
-McLeod RXT twin disc clutch
-McLeod hydraulic clutch slave cylinder/throwout bearing
-Wilwood hydraulic clutch master cylinder
-Quick Time SFI bellhousing
-Tremec T56 Magnum 6 speed transmission
-Ford 8.8” rear axle w/ suspension brackets welded to axle & entire axle powder-coated
-Ford Racing/Torsen limited slip differential from Shelby GT350
-Ford Racing 3.73 gears
-Ford Racing differential cover with bearing cap supports
-Moser 31 spline axleshafts
-Baer Racing 6 piston caliper 13” 2 piece rotor front brakes
-Baer Racing 4 piston caliper 12” 2 piece rotor rear brakes w/ integrated drum parking brake
-Boyd aluminum fuel tank w/ higher fill neck & internal baffling for road racing
-Aeromotive A1000 in-tank pump w/ pump voltage regulator
-Earls AN fittings for fuel & cooling systems
-Lizard Skin ceramic & sound insulating
$55K invested just in parts at 8 years ago pricing
Asking $40K OBO I will listen to reasonable offers
Fastest response will be from texting me
Mike 602-717-1582
Phoenix, AZ
SOLD!!
Reason: Sold
