Thanks Thanks:  11
Likes Likes:  28
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 83
Thread: Battery location doubts
    Jan 2021
    Memphis, TN
    Quote Originally Posted by Ducky2009 View Post
    The front battery box is a great option, but remember it's a smaller battery. Suggest you add a battery tender to keep the charge up if it's going to sit for an extended time.
    I recommend a battery tender no matter what battery you have. It will extend the life.
    Forte's Axle
  2. Likes WIS89 liked this post
  3. #42
    May 2020
    Quote Originally Posted by zee View Post
    I don't know how I missed that. That battery is so small, it can go anywhere!
    I remember you posting once that you put the battery on top of the pax footbox. Do you have a picture? Thanks.
    Here is one without the body on
  4. Thanks zee thanked for this post
  5. #43
    Jax Beach, FL
    You guys can spend all you want, but my Odyssey PC 680 is 6 yrs old has never needed maintenance or charging. It's only $173. Why would you want to spend up to a grand?
    But the expensive ones are faster!
  6. Likes CaptB liked this post
  7. #44
    O'Fallon, MO
    I'm sure you believe that, as your wallet is so much lighter.
  8. Likes CaptB liked this post
  9. #45
    Oct 2018
    When I build mine I will move the battery to the engine compartment. At the build school in February another student connected the cables to the wrong terminals, he could not see the top of the battery under the body. Fried the fuel injection. We did not have a car that could drive at the end of the class.
  10. #46
    May 2020
    Nobody has suggested a $1k battery
  11. #47
    May 2020
    Centerview, MO
    I have the FFMetal box that was mounted in the center of the trunk with a 4 link. Just moved the battery box today so I could mount the 3 link frame in position. This was all done with the car complete and I was able to get my #34 battery in. I still need to do an aluminum patch but it is all covered with carpet so it will not be seen. I like the trunk mount for several reason; it’s in the trunk, it’s hidden and it’s not under my hood. Did I mention, I don’t want my battery under the hood?
    MK IV Base Kit #9370 w/ FFR Lower Control Arms, donor 1996 Cobra 4.6 L DOHC; stage 2 Comp Cams, Manley forged Pistons & Rods, IMRC Delete Plates, T-45 transmission HD extra build w/ single disconnect reverse mod, 3-link w/ Koni Coil Overs 3:73 rear end. Painted and re-assembled Jan 2022.
  12. Likes WIS89 liked this post
  13. #48
    Aug 2021
    El Dorado Hills, CA
    Has anyone done a battery box behind the rear wheel on the driver's side of an MK4? There is a a lot of real estate there for a battery, extra storage, etc. As I am contemplating my build, I am envious of this space and making it useful.
    #10333 Complete Kit, Carbed 427w, TKX, IRS and many other upgrades
    • Order Date: September 11, 2021 - 20th Anniversary of 9/11
    • Delivery Day: April 1, 2022 - April Fool's Day
    • First Start and Go-Kart: January 20th, 2023
    • Graduation Date: July 4th, 2023 - Independence Day!!
    • Legal Registration Date: October 4, 2023 - My Birthday!!
    Visit my MKIV Build Thread (#10333)
  14. #49
    May 2020
    Centerview, MO
    There is a guy out in So Cal who does it. His first name is Frank I believe and if you go on to YouTube he is i.e. 427 Garage. I know he has done it on a MKIII, I assume he also does a MKIV.
  15. #50
    Here is how I did my dropped trunk. Made the panels myself. It is a VERY worthwhile change.
  16. #51
    Dec 2021
    Quote Originally Posted by Ted G View Post
    https://youtu.be/rr_Z2N0ErQk?t=152
    This video will start at the right point. Even if not doing the battery box there, it's very useful to add it as an extra storage for small items.
    Complete novice who doesn't know what he's doing.
    MKIV with BPE 347 & TKX. IRS. A crap ton of mods.
    Build thread
  17. #52
    Aug 2012
    Grand Rapids, MI
    Just to offer a point that I haven't seen discussed.
    Battery weight and placement might matter to you. Many talk about corner balance and adjusting coilovers to adjust the balance. A good plan from what I've seen. Moving a 40# battery around will change things, good or bad that's up to you and your scales to determine. Perhaps not real important on a street car but more important on a track car.
    In a past life and different car the battery was on the driver's side behind the rear wheel. Corner balance wasn't great, way heavy to the left rear. We pulled the battery and placed it over the passenger side headers about 10" in from the outer body. Most of the corner balance issues were resolved or got significantly better. For those cars the left rear was the heavy point, the front right the light. All this was checked on properly used scales.
    Another thought about lightweight batteries is securing Mass. It's a whole lot easier to tie down a smaller / lighter item than a larger / heavier piece. I've seen what a 40# battery does in an instantaneous stop.
    BTW, I'm regrouping and looking at the ATX20-HD as an option as Hooper has mentioned. Just over 5# and $399 MSRP. Opens up options for placement while reducing concerns for balance.
    https://antigravitybatteries.com/pro...-oem/atx20-hd/
    Jim
  18. #53
    Jul 2020
    Birmingham, AL
    Another happy customer using the FF metal drop battery mod. It is tucked away and opens up the trunk.
    FFR MK4 Roadster (9945) complete kit, delivered 12/4/2020, First start and go kart 5/7/2021. Legal 8/14/2021, Paint finished 7/18/2022 (Viking Blue). 347BPE CI, TKO600, Moser 8.8 3link 3.55, Halibrand 17x9 17x10.5, power steering. Carbon Fiber Dash. Carbon Fiber trans tunnel, adjustable Kirkey Lowback Vintage seats, Vintage gauges, RT drop trunk mod, FFmetal drop battery mod and trans tunnel, Forte front sway bar. Forte mechanical throttle linkage, RT gas pedal. www.covespringsfarm.com
  19. #54
    Aug 2021
    Moyock, NC (OBX/Hampton Roads)
    Quote Originally Posted by PaulRSchmidt View Post
    Ah, fair point. I had been thinking of fatigue, not an accident.
    If I decide I don’t need a heater (TX), the point becomes moot, as I’ll install a glove box in the traditional location.
    Do it all! Heater+Glove Box+Wipers+Breeze Cubby in the back, all with a Coyote. It'll fit with a little creativity.
    MK4 Complete Kit #10315 / Coyote G3 / TKX / 427 HardTop
    Build Thread Production Date: 2/26/22, Registered 5/19/22, Graduated 3/1/2023
  20. Thanks PaulRSchmidt thanked for this post
  21. #55
    Dec 2021
    Quote Originally Posted by JeffP View Post
    Very nice!! Where is the glovebox from?
    Build thread
  22. #56
    Jan 2021
    Memphis, TN
    Quote Originally Posted by I want a coupe View Post
    You have to make an access panel to the battery. Use rivenuts. Who would put a permanent panel over a battery box?
    Forte's Axle
  23. #57
    May 2020
    Centerview, MO
    I don’t think anyone said they put a permanent panel over a battery box or at least I didn’t read it that way. Mine has a cover over it with screws to have access to the battery.
  24. #58
    Jan 2021
    Memphis, TN
    I was just responding to someone's comment:
    "At the build school in February another student connected the cables to the wrong terminals, he could not see the top of the battery under the body."
    No harm, no foul, just responding to what I had read, perhaps it was different than how I read it :-)
    Forte's Axle
  25. #59
    Quote Originally Posted by swwebb View Post
    Until you need to replace the battery!!
    I have the FFmetal battery box in my MK2 IRS build. I replaced the battery very easily, no struggle at all.
  26. Likes CaptB liked this post
  27. #60
    Aug 2021
    Its the prefab vinyl dash w/glove box from ff.
  28. Likes zee liked this post
  29. #61
    Feb 2020
    Tucson, AZ
    All,
    Thanks for the great responses to this post. I decided to fabricate my own drop box in the rear similar to some of what was shown here.
  30. Likes CaptB liked this post
  31. #62
    Jax Beach, FL
    It's all about power to weight ratio!
  32. #63
    Jax Beach, FL
    They didn't think to look at the battery first? Or have a mirror, or a phone to have a look?
  33. #64
    League City, Texas
    I have the Breeze battery mount (https://www.breezeautomotive.com/sho...-1-4-roadster/). It's a well-made part and I highly recommend it.
    I fabbed a spare tire mount for my trunk (for a donut spare), so putting the battery below the trunk floor was no bueno for me.
    My Saving Grace: John 3:16
    FFR6687, Graduate #39 in the Class of 2009
    The Factory Five Forum March 2012 POM
  34. #65
    O'Fallon, MO
  35. Likes nucjd19 liked this post
  36. #66
    For those of you using the Breeze kit, the site says it’s made to fit MK 3 and newer. Anyone see any issues with it fitting a MK II?
  37. #67
    Aug 2020
    Kwajalein, Marshall Islands
    Mine is behind the rear wheel on the passenger side. Plenty of room there too.
    MK3 Challenge Car, Boss 347, Sniper 2 EFI
  38. #68
    520 Speedworks did it in their salvage 427 build featured on YouTube.
  39. #69
    Nov 2016
    "The i.e." SoCal
    No offence to Greg, but we've got him beat on the rear, fender mount battery by about 10 years. I'll see if I can dig up the original thread posted on the forum but here's a link to answer one of the questions about it on our fb page dated April of 2016. By far my favorite spot to mount a battery.
    https://www.facebook.com/IE427-89165...90926444277008
    Found it. August 2010
    https://www.ffcars.com/threads/new-b.../#post-2303541
  40. #70
    Oct 2020
    Albany, NY
    I put mine up front. It’s clean, easy and very accessible.
    Build 1 MK4 #10008 - Delivered 03/03/21, Graduated 7/20/22 - Sold 6/6/24 Build Thread #1 https://shorturl.at/K9fuy
    Build 2 MK4 #11061- Delivered 08/24/24 Build Thread #2 https://shorturl.at/OZowi
    Build 3 35 Pickup #329 - Delivered 10/28/25 Build Thread #3 https://shorturl.at/Ty4QQ
  41. #71
    Elk Grove, NorCal
    If using the FFmetal trunk mount kit with solid rear axle:
    I have the 289 kit with solid rear axle. I used the FFmetal kit and it initially interfered with the travel of the rear differential. FFmetal is an awesome, well built unit, but I had to modify it by raising it up 2 inches to clear the diff travel.
    build thread: http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
    Build School: July 14-16, 2017
    Kit purchased: July 25, 2017
    Kit delivered: September 13, 2017
    First Start: December 22, 2018
    Body painted and kit completed and drivable: July 2019 (but still not done)
    CA SB100 Registration: January 2020
    Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
  42. #72
    Manassas, VA
    FYI, that's what the big hole in the bottom of the box is for. Just put a 4x4 under the battery and use your floor jack to lift it up. Or enlist a friend to get underneath the back of the car and push up. In 17 years, I've removed my battery 3 times by myself and it just lifts right up and out - it's not easy, but totally worth it. The weight in the back in good, the space it frees up is great, I have remote battery terminals in the trunk so I can charge the battery. There's really no negative to having it back there.
    Tip: Leave the handle on the battery and use it to lift the battery out in 5-7 years.
    Non-donor - Engine Factory 351w/400hp - TKO500 - 3-Link - Cobra brakes - FFmetal - Wilwood pedals - FR500 wheels - NCPainter
    Owner of FFmetal.com
  43. Likes Railroad liked this post
  44. #73
    South Australia
    X2 on Bills experience. To the naysayers It is an urban myth that the battery is difficult to remove. It really is time to move on.
    Gen1 Coyote / TKO600 / IRS
  45. #74
    Jul 2024
    BC, Canada
    On the FFMetals box. Anyone happen to have a couple pictures of the clearances we are left with on the 3-link cross bar and diff cover when using this box?
  46. #75
    Manassas, VA
    There's not a ton of clearance, but just enough. I even had an aluminum rear diff cover. Never had an issue in 18 years.
    BTW, I own ffmetal.com. Ask me anything.
  47. #76
    That's not original!
    May 2024
    Crossville, TN
    Front mount battery
    Unconventional.
  48. #77
    Jul 2024
    BC, Canada
    Quote Originally Posted by Bill_VA View Post
    Nice
    I ordered it today I guess given how tight it is I didn’t think to ask if it will fit with the Ford GT500 finned cover?
    My setup is same as yours with the exception of the diff cover.
    Hopefully my finned cover does sit back any further than yours
  49. #78
    Dec 2021
    Flower Mound TX
    I did that once, everything was fine except the horn sucked and the radio listened.
  50. #79
    Jax Beach, FL
    My argument for a rear battery.
    1. These cars need all the weight in the rear that you can get.
    2. Batteries don't like heat.
    3. Engine compartment looks better without it.
    4. You will likely not need to touch the battery for 7 - 10 years, so it doesn't need to be very serviceable.
    5. If you do need to remove it, the FFmetals box has a hole in the bottom. Use a piece of wood and a jack and it pushes it up for easy removal.
  51. Likes Nigel Allen, Doc76 liked this post
  52. #80
    Jul 2024
    BC, Canada
    FF Metals box will not fit if you’re running a GT500 finned cover on a Ford 8.8 solid axle 3-link. It hits.
    I will add this is a super nice piece however and Id like to find a smaller battery that may allow me to notch the box and still use it. Very well made, worth the mod and changing a battery if there’s a sufficiently smaller one.
    Any suggestions on battery options would be appreciated.
