Thanks Thanks:  10
Likes Likes:  2
Results 1 to 20 of 20
Thread: Battery Charger/Tender
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Ok I may be showing my ignorance here but I have a simple question. I was looking at ordering a battery charger/tender. Following others I was planning on having a dash socket that I could plug the charger/tender into. I know the charger/tender is for a 12volt battery but I am unclear what amperage is required.
    Scott Pregont
    My Albums
  2. Thanks Derald Rice thanked for this post
    For a battery maintainer, 1 to 1.25 Amps is fine. I prefer the Deltran battery tender + for lead acid batteries. For AGM, look for an AGM specialized maintainer.
    Jan 2020
    State of Jefferson
    I have also had good luck with Pro Mariner, use them on my boat batteries and they have always held a good charge over the winter.
    https://www.amazon.com/ProMariner-Pr...s%2C119&sr=8-3
  5. Thanks Namrups thanked for this post
  6. #4
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thanks Papa! Just what I was looking for.
    Scott Pregont
    My Albums
  7. #5
    Mar 2021
    SE WI Kettle Moraine
    You should not overheat a battery with a high charge rate (110F). There is a risk of plate warping and shorting. (Arizona?) 10% of the battery amps is safe, not hard with car batteries, bike batteries should not get more than 2amps.
    I have multi-battery type selections on my chargers and desulfating mode for storage. Northern Tool has a good selection, but not cheap:
    https://www.northerntool.com/shop/to...ry-maintainers
    You would need to buy the cigarette lighter socket adaptor, but that will not work if that port is wired to IGN not BATT.
    jim
  8. #6
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by J R Jones View Post
    jim
    Thanks Jim. Wiring as always hot noted.
    Scott Pregont
    My Albums
  9. #7
    I've been very happy with my CTEK 7002 charger. https://smartercharger.com/products/ctek-multi-us-7002. Consistently gets high ratings and has worked well for me. Handles regular plus AGM batteries. I hit my cars with it about once a month during winter storage. Keeps them topped off plus gives a maintenance check. A CTEK 56-263 pigtail, sold as an accessory, connects directly to the 7002 charger wires and plugs into the aux (cigarette) outlet. Works great.
  10. #8
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Having followed your thread extensively I was cruising the CTEK web site which I found to be somewhat confusing. That's the reason for asking about required amperage. I ended up with the same part numbers as you just posted so thank you for confirming that for me.
    Scott Pregont
    My Albums
  11. #9
    Jun 2018
    North Vancouver, BC, Canada
    Just another tidbit of info.
    Batteries have a self discharge characteristic with lead acid being one of the worse. Left unattended for long periods of time they will go dead which, even if they can be revived, takes significant life out of the battery. So the purpose of the maintainer is to "trickle charge" the battery to offset the self discharge. As such, the trickle charge is on the order of milliamps (well under an amp). That said, many buy a battery charger not only capable of trickle charging but also regular charging as highlighted by many above....
    Gen 1 '33 Hot Rod #1104
  12. Thanks Namrups thanked for this post
  13. #10
    Brent
    Mar 2020
    Topeka, KS
    Deltran Battery Tender 800 mA for a float charger.
    For charging, I prefer a charger with both manual & automatic features. A battery that is low on voltage will often not be detected and charged by a straight up automatic charger. In that case, put the charger on manual and push the amps into the battery. Don't forget the charger on the battery because it'll blow up the battery. Get the battery up to ~12 volts and switch over to automatic charging.
    My favorite and most used charger (I have several Ive accumulated over the years for RV/Boat batteries, power sports & automotive), is made by Century Tool & Equipment. They used to be made in USA. That may have changed.
    https://www.centurytool.net/K3153_1_..._p/k3153-1.htm
  14. Thanks Namrups thanked for this post
  15. #11
    Mar 2021
    I have had an auto battery so discharged that it lost polarity and would not take a charge. The remedy was to slam a high amp charge into it to re-establish polarity. Then charging could be done normally.
    I prefer trickle charge but it can require 24 hours or more. If left discharged too long sulfating ruins the ability to hold a charge. IMO the microprocessor based chargers maintain better and prolong battery life.
    BTW if the case sides are bulged, sulfating has ruined the battery, trade it in.
    jim
  16. Thanks Namrups thanked for this post
  17. #12
    Tool Baron
    "The I.E." SoCal
    Just so there is no confusion. The Battery Tender Plus from Deltrans is suitable for most types of automotive style batteries, including AGM. Specs are here.
    https://www.batterytender.com/plus
    I have a number of these on all different vehicles and they work great. You can pay more for a battery maintainer/charger. I choose not to. These are in the middle of the price range and do go on sale from time to time. All my stored vehicles get stored with a Battery Tender attached.
    __________________________
  18. Thanks Namrups thanked for this post
    Likes flyingfarley liked this post
  19. #13
    Quote Originally Posted by frankeeski View Post
    Ditto. Good product, reliable. I charge my cobra, motorcycle and seadoo batteries with the same device.
  20. Thanks Namrups thanked for this post
  21. #14
    Good info, Frank. Is that true for Optima AGMs? My experience when connecting my Deltran Battery Tender (may have been a junior, not a +) was that the unit didn't like the Optima. I ended up getting an Optima charger and it works great.
  22. #15
    Tool Baron
    "The I.E." SoCal
    It depends on the discharge of the battery. If an AGM drops to low, it's a lot harder to bring it back. One trick to bring back a discharged AGM is to charge it in parallel with a known good battery (using jump cables) and a battery charger.
    I use a Junior on an Optima Redtop I have stored in the shop. Seems to keep it topped off just fine.
  23. Likes Papa liked this post
  24. #16
    Mar 2013
    Fort Collins, Colorado
    I have 4 optima red tops in the shop, out of the cars, each one on Battery Tender Juniors(750ma).
    And I rotate the others into the bank of chargers every month or so.
    Have been using this system for a couple of years now with no problem
    MK2 #3319.... On the road since 2002 with a lot of upgrades
  25. Thanks Namrups thanked for this post
  26. #17
    Sep 2021
    I have been using the Battery Tender system for 12 years with 2 Costco marine lead-acid batteries. The boat is located in BigBear CA at 6700 ft. elevation. I had to replace 1 battery in spring 2021. I don't use it during the summer season, no power at the marina. I paid $25 cash at a motorcycle dealer tradeshow. Great purchase.
    FYI first post. I'm preparing to move forward with a build.
  27. Thanks Namrups thanked for this post
  28. #18
    Mar 2018
    I've had my car a few years now and haven't had any issues with the battery dying on me. I like the under car setup if I ever needed one though.
  29. #19
    Curmudgeon
    Costco has a good deal right now on a Battery Tender 4.5 amp that does AGM, Lead Acid, and Lithium. That's tough to beat on a multi battery capable charger.
    https://www.costco.com/battery-tende...100679769.html
  30. Thanks Namrups thanked for this post
  31. #20
    Murrieta, Ca
    I use a Deltron Battery Tender Jr. Having it connected when in the garage, I was able to get 10 1/4 years out of my original Duralast Autozone lead acid battery. The employees were amazed it lasted that long.
    Mk3.1 Complete kit #6846 Delv. 12/20/08-- Finished 2/11/11, 89 302 EFI,T-5, 3-Link, 17" Halibrands, Nitto 555 245-315 tires, widened drivers footbox w/ dead pedal, extended passengers footbox,Sapphire Blue Met & Wimbledon White stripes,radiator stone guard shield, Build blog http://jimsffrcobrabuild.blogspot.com/
