Hi Kpt112,
I scraped up the front underside of my Daytona ( Dumb fault of my own). The scrape was on the right and left underside in the front. I did not feel confident sanding and doing body filler, so I used blue and white touch up paint that had a small brush and pin point applicator (Dupli-Color).
I painted over each gouge .
This is the result. You can only see it if you get under the car.
