Results 1 to 11 of 11
Thread: Chin Rash
    Bucks County PA
    Chin Rash
    Good Day,
    I have a bit of an issue. A while back I bottomed my car out on a very bumpy road. As a result i have some scrapes on the front chin of the car.
    I would like to clean this up. You can't see the scrapes unless you lay on the ground. I bought some touch up paint in aerosol cans. I want to get some pointers on how to fix this without taking it to a paint shop. As I said you can't see when walking around the car. It just bothers me.
    Any help or pointers would be appreciated
    Kevin
    FFR 8553
    May 2021
    I did the same thing on a Lotus Elise. You can “fix” it yourself, but it will take some serious sanding, body filler, primer and paint. You can use rattle can, but an observer would see the difference if they got down on their knees. The stripes make it more complicated. It would take some serious time and effort, and if you’re like me, it will still bug you, even if no one else notices.
    Or you can get the guy who painted it or some other pro to fix it. Probably could be fixed for $1000-1500. Maybe less.
    If you think it bugs you now, it will really bug you if you’re less than satisfied with the results.
    Well Used Member
    So. Bay (So. Calif.)
    Quote Originally Posted by drewr View Post
    And If that doesn't bug you, after you do the same thing again after "fixing" it, surely will.
    Or You Could:
    Wear It As A Badge Of Honor!
  5. Likes cnutting liked this post
    Aug 2021
    El Dorado Hills, CA
    Automotive Touch Up can get you an exact match in a rattle can. They are great and I've used them for years. Make sure you buy their base coat in both colors and use their clear coat. You'll also need to sand in between each coat of base and clear. Not cheap paint, but worth it.
    https://www.automotivetouchup.com/
    Good luck
    #10333 Complete Kit, Carbed 427w, TKX, IRS and many other upgrades
    • Order Date: September 11, 2021 - 20th Anniversary of 9/11
    • Delivery Day: April 1, 2022 - April Fool's Day
    • First Start and Go-Kart: January 20th, 2023
    • Graduation Date: July 4th, 2023 - Independence Day!!
    • Legal Registration Date: October 4, 2023 - My Birthday!!
    Visit my MKIV Build Thread (#10333)
    Nov 2018
    Centennial, CO
    I’m guessing the majority of us have this to some degree - I did it pulling out of my driveway straight instead of at an angle. I don’t like it and it bothers me too, but only when I’m under the car.
    Bradley
    Jan 2021
    Fort Lauderdale, FL
    Or You Could:
    Slap an SCCA or NASA sticker next to it
    Hi Kpt112,
    I scraped up the front underside of my Daytona ( Dumb fault of my own). The scrape was on the right and left underside in the front. I did not feel confident sanding and doing body filler, so I used blue and white touch up paint that had a small brush and pin point applicator (Dupli-Color).
    I painted over each gouge .
    This is the result. You can only see it if you get under the car.
  10. #9
    Ottawa Ontario
    I feel your pain. The bulk of the scratches appear to be on the LH stripe. If it was me I would sand, fill, tape, and paint (with the aerosol you have ordered) that portion of the stripe below the cooler. I would then clear, color-sand and buff that area. For the blue area, I would use Bob-STL's trick, then color-sand, and buff. Make sure you tape off/cover/bag the car well as the overspray gets everywhere. I usually set a fan(s) up at the end of the garage to blow any overspray out the door, make sure you move your DD's as well. Good luck. Scott
    FFR #3870 MK II, Spectra Blue/Arctic White, 1974 414W, 10:1, Eagle 4340 crank and rods, KB Pistons, Ported Performer RPM 2.02 heads & intake, QFT SS-650, Comp XR282HR, Quality Roadsters pan, Crane ignition, TKO600, 3.55 gears, 3 link, SA QA1's, Breeze LCA's, Heim joints & VPM F/R bars, Power steering with Hiedts valve, Power brakes, Fortes bump steer kit, 5 bolt axels, SSBC rear brakes, Oil cooler, Pusher fans, Halibrand Cobra III's with Nitto NT555 G2 245/285/17
  11. #10
    Bucks County PA
    Thanks for the kind words, It is good to know I am not alone in getting battle scars. I contact a paint guy and he will most likely happy some filler and sand. I told him i wanted to use rattle can paint since it is so hard to see. I will post pictures once I have it done.
    Kevin
  12. #11
    You got that damage from a bumpy road?
    You mean, like it had very large speed bumps, or were you jumping curbs ?
    Maybe time for a 4x4..lol
