Thanks Thanks:  11
Likes Likes:  72
Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 281 to 320 of 416
Thread: Street Rod Jim's 33 Hot Rod V2 #1143 Build - The Journey Begins
  1. #281
    Arizona
    Finalizing the Hood, Side Panels and Valance of the 33 Hot Rod V2 - Part 2
    33 Hot Rod V2 Coupe, Extra Clearance Hood, Bike Fenders, Rear Exhaust, LS Engine
  2. #282
    Arizona
    Finalizing the Hood, Side Panels and Valance of the 33 Hot Rod V2 - Part 3
  3. #283
    Arizona
    Finalizing the Hood, Side Panels and Valance of the 33 Hot Rod V2 - Part 4
  4. Likes Salty Chief 35, Oldguy33 liked this post
  5. #284
    Aug 2021
    Nice work Jim. Watch all your videos.
  6. #285
    Arizona
    Quote Originally Posted by Oldguy33 View Post
  7. #286
    Jul 2021
    Fuquay Varina, NC
    We're waiting for delivery, delayed by the snow storm. What did you use for removing the tape residue on the body?
    33’ Hot Rod - Gen 2. BluePrint Engine Small Block Chevy 383, carbureted, 700R4 automatic transmission
  8. #287
    May 2018
    Pinckney, MI
    Quote Originally Posted by andyw View Post
    Buy a gallon of acetone and a bunch of rags and microfiber cloth’s. A spray bottle for the acetone will help too. Be careful of the fumes, but you’ll use a lot for cleaning stuff. Buy boxes of gloves as well.
    - Peterh226
    35 Hot Rod Truck (Ext) Delivered 11/21/24
    33 Hot Rod Gen 2 #1134 ~1400 miles
    54 Pontiac Star Chief
    05 F-150
  9. #288
    Jun 2018
    North Vancouver, BC, Canada
    Lacquer Thinner is another good way to go, less aggressive than the acetone....
    Gen 1 '33 Hot Rod #1104
  10. #289
    Arizona
    I used acetone, but Lacquer thinner I think works better.
  11. #290
    Arizona
    Finalizing the Hood, Side Panels and Valance of the 33 Hot Rod V2 - Part 45
  12. #291
    Arizona
    Fixing the curvature of the 33 Hot Rod Trunk
  13. #292
    Arizona
    Sanding the gel coat - Preparing for paint
  14. #293
    Arizona
    Sanding the gel coat - Preparing for paint Part 2
  15. Thanks Salty Chief 35 thanked for this post
  16. #294
    Arizona
    Adding after market inserts to form the curvature of the 33 Hot Rod Trunk
  17. #295
    Arizona
    Adding after market inserts to form the curvature of the 33 Hot Rod Trunk Part 2
  18. #296
    Arizona
    Adding after market inserts to form the curvature of the 33 Hot Rod Trunk Part 3
  19. #297
    Arizona
    Trimming and sanding the front side panels (Engine Covers) of the 33 Hot Rod V2
  20. #298
    Arizona
    Extending fiberglass on the lower valance of the 33 Hot Rod V2
  21. #299
    Arizona
    Installing the two piece valance of the 33 Hot Rod V2
  22. #300
    Arizona
    Jim gets an body work evaluation from his mentor Greg
  23. Likes Salty Chief 35 liked this post
  24. #301
    Arizona
    Jim works out all the nuances of the hard top and gets it ready for the real body work.
  25. Likes Salty Chief 35 liked this post
  26. #302
    Arizona
    Starting the process of build primer and sanding.
  27. #303
    Arizona
    Getting the hood to align on my 33 Hot Rod V2
  28. #304
    Arizona
    Installing the 818 trunk latch on a 33 hot rod.
  29. #305
    Arizona
    Still working on build primer to get to that car show finish
  30. #306
    Arizona
    I am shocked but still getting the waves out with more build primer.
  31. #307
    Arizona
    Aligning the doors one last time
  32. #308
    Arizona
    Finalizing the build primer on the rear fenders
  33. #309
    Apr 2019
    Hang in there Jim. You’re making steady progress. Really enjoy your videos.
    Respectfully
    Jeremie
  34. #310
    Catonsville, Maryland
    Hey Jim,
    Looking over your prime videos and I noticed that It looks like your not using guide coat before you do any sanding?
    If I missed it I apologize, but if your not using a guide coat I strongly suggest that you incorporate it into your paint prep process, especially before you start in on the hood.
    Ron
  35. #311
    Arizona
    Quote Originally Posted by Presto51 View Post
    Hey Jim,
    Ron
    Yes, I use a dry coat with everything when needed.
  36. #312
    Arizona
    Dealing with the Factory Five 33 Hot Rod V2 Hood Fitment.
  37. #313
    Arizona
    Installing Door Lock Solenoids on the Factory Five 33 Hot Rod V2
  38. #314
    Arizona
    Test drive - Factory Five 33 Hot Rod V2
  39. #315
    Arizona
    Working out my custom reverse lights on the Factory Five 33 Hot Rod V2
  40. #316
    Arizona
    Working out my custom reverse lights #2 on the Factory Five 33 Hot Rod V2
  41. #317
    Arizona
    Kit Car Talk #5 with Street Rod Jim - Factory Five 33 Hot Rod V2
  42. #318
    Arizona
    Fixing the leaks on the new Factory Five 33 Hot Rod V2 build
  43. #319
    Arizona
    Fixing a valve cover leak on the new Factory Five 33 Hot Rod V2 build
  44. #320
    Arizona
    Dropping off the Factory Five 33 Hot Rod V2 for body work.
