Results 1 to 5 of 5
Thread: installing solid motor mounts in factory five mark 2
    My pipes were bouncing way to much, so after 20,000 miles, I *finally* decided to swap out my rubber motor mounts for solid mounts.
    I expected it to be a pain, and I was not disappointed.
    I made a video of the process and the lessons we learned!!
    https://youtu.be/mhMqgu89oxc
    The heated garage, donuts and coffee made it all great.
    Thanks Phil for helping out!!
    Mike Davis
    Pepper Gray Metallic with black metallic stripes ("Eleanor" colors) Mark 2 FFR
    351 Windsor, tremec 3550 5 spd, 3 link rear end
    http://cobra.prairieroad.com/
    1982 Honda Goldwing Aspencade restored in 2008
    Make sure you keep a flexible trans mount. Unless you want a cracked bell housing or trans case. Ask me how I know, LOL.
    16+ FFR kits and counting!
    Seasoned Citizen
    Good advice.
    Grand Rapids, MI
    I'd bet that Energy Suspension has mounts that would better control the movement while still offering some vibration isolation. I believe that it is an Energy mount that is included as the trans mount.
    It's also possible that your current mounts are just worn out and a direct replacement would solve most of the problem.
    Jim
    Jan 2020
    State of Jefferson
    Nice video, thanks for sharing.
    I am also running fixed mounts from Gordon Levy. So far after 2200 miles and a track day they have been great. Zero vibrations in the car. I do have the flexible energy mounts on the transmission. Gordon told me he has been selling these for years with no issues, I definitely trust his word seeing as he builds these cars for a living along with racing them.
    How did it help with your side pipe movement?
