Likes Likes:  10
Results 1 to 14 of 14
Thread: sliding seat with breeze mount?
    Folsom, CA
    Question sliding seat with breeze mount?
    Was thinking about adjustable sliding seats, my wife and are are both around 5'9" to 5'10" but her legs are longer so maybe an option to adjust?
    does this work with the breeze seat mounts? Don't want to feel like it's going to raise the seat 2" or something...
    thoughts? ideas? recomendations?
    found these online, not too bad for a pair for ~$50
    Universal Bucket Seat Slider Tracks
    Todd
    Feb 2019
    Greality, Colorado
    Todd, I'm not sure these play nice together? I'll wait for others to chime in to verify. I'm actually planning to be able to run both the roadster seats on the breeze mounts, and be able to swap out and put in a set of high-backs on different mounts depending on driving style or car shows. Either that, or I might add a headrest to the roadster seats too. My neck is in charge and has full say when it comes to the seating.
    Dj or Doug or TheLateDude
    ----- #19 of 25th Anniversary MKIV 9769 -----
    Build Link: https://thefactoryfiveforum.com/show...-Slow-Progress
    Ordered: Oct 07, 2019 / Production: Dec 28th, 2019 / Shipped: Jan 19th, 2019 First Start: In the future... / Graduation: Even further in the future...
  3. Likes toadster liked this post
    mburger's Avatar
    Punta Gorda FL
    I bought universal sliders from Summit. The kind with a hoop in front that you pull up on to disengage the seat to slide. I then sandwiched the slider between the Breeze floor mount plate and the angled seat mount plate. This way, I’m sliding the tilted seat forward and back. All holes lined up. Actually pretty easy or I lucked out! Raised the seat maybe an inch. Not noticeable.
    I’d post the link to the slider, but I can’t log into Summit. Site is down.
    EDIT: It wasn’t Summit. Got the sliders from Amazon.
    https://www.amazon.com/gp/aw/d/B0091...b_b_asin_title
    Mark
    Gone but not forgotten. Mk1, Frame #1929 Complete restoration/upgrade.
  5. Thanks WIS89 thanked for this post
    Likes Ted G liked this post
  6. #4
    Folsom, CA
    Quote Originally Posted by mburger View Post
    nice! I saw those, wondered if it would mess with the submarine belt though - any pics?
    Todd
  7. #5
    Aug 2021
    El Dorado Hills, CA
    I was thinking the same thing with my upcoming build. I'm pretty short at 5' 7" but my girlfriend is only 5'1".... we definitely need an adjustable seat if she is to drive. I would probably like the 1" lift as well.
  8. #6
    mburger's Avatar
    Punta Gorda FL
    My sub belt goes up through the seat straight up but you could put the belt behind or through the lever.
    I’ll get pics tomorrow.
    ALSO, the seat is up about 1.5”. Still not an issue.
    Mark
  9. Likes Ted G liked this post
  10. #7
    May 2020
    Centerview, MO
    I have the FFR sliders and added a 1” lift to the drivers seat and a 1.5” lift to the passenger seat since it does not have a slider. This way they are close to the same height. I just used a piece of aluminum tube and cut them to length.
    MK IV Base Kit #9370 w/ FFR Lower Control Arms, donor 1996 Cobra 4.6 L DOHC; stage 2 Comp Cams, Manley forged Pistons & Rods, IMRC Delete Plates, T-45 transmission HD extra build w/ single disconnect reverse mod, 3-link w/ Koni Coil Overs 3:73 rear end. Painted and re-assembled Jan 2022.
  11. #8
    Cobra Doc
    Oct 2017
    Newton, MA
    Following
    - Rob
    MkIV Roadster, Complete Kit #9624, Coyote 5.0, TKO600, IRS, Wilwood Brakes, 18" Halibrand Wheels
    Build Thread: https://thefactoryfiveforum.com/show...kIV-Bld-Thread
  12. Likes toadster liked this post
  13. #9
    mburger's Avatar
    Punta Gorda FL
    My apologies. I forgot to grab pictures today. I’ll do it tomorrow!
    Mark
  14. Likes toadster liked this post
  15. #10
    mburger's Avatar
    Punta Gorda FL
    Here is a picture of a slider between my seat and the breeze seatbelt. If you look on the right you can see how the seat is bolted to the angled or reclined bracket then there’s the slider and finally the bracket from breeze that mounts to the floor. Sorry it’s a bad picture but I honestly didn’t want to remove the seats again at least not now. One thing with this arrangement that doesn’t bother me because in the cobra there really isn’t much room to slide, but normally the handle that you pull up on slides with the seat but the handle on this set up is stationary. So as you slide forward the handle is a little further under the front of the seat. Again, it’s no big deal and it works.
    Mark
  16. Likes Ted G, Fman liked this post
  17. #11
    Apr 2019
    Dunlap Tenn
    I'm not sure if this helps. I have a 33 hot rod. I'm 6'3". I wanted to be able to adjust my seats for whatever. I bought the sliders from Amazon and the Breeze kits. Couldn't be happier. Plenty of adjustment, and the seats are inclined back a little giving more support to my legs.
    arrived July 18th 2019, first cart in Feb. 2020
    BluePrint Engines 383CI TKO600 GM Street&Strip
    Ridler wheels 17x 8 front 20 x 10 rear
    Toyo Proxes 245/35-17 front
    285/25-20 rear
    0mm offset finished Jan 2022
  18. Likes Ted G, toadster liked this post
  19. #12
    mburger's Avatar
    Punta Gorda FL
    Quote Originally Posted by Blade View Post
    I was going to mount it like that but I didn’t want to raise the seat when sliding forward. By sandwiching the slider between the breeze plates, it kept the recline but allows the seat to slide forward and back without changing the height of the seat.
    Mark
  20. Likes toadster liked this post
  21. #13
    Folsom, CA
    that's pretty smart!
    Todd
  22. #14
    Mar 2019
    Roseville, CA
    Todd, I used the Summit sliders as mentioned by another poster. They worked well with the Breese seat mounts. I think I had drilled one new hole on each side. Pretty minor. I'm 5'9" and short legs (30" inseam) and need the sliders. Mainly for the clutch pedal. They do raise the seat up at least 1". I find my line of sight to be a the top of the windshield. I wish the seats reclined a bit. Bottom line is if you need them they work well.
    Mk4 Complete Kit delivered 5/2019, Gen 2 Coyote, TKO 600, IRS, Wilwood F/R, Power steering, Halibrand 17” X 9” Front 17” X 10.5” Rear, Nitto NT555 G2 F/R
