Thread: Alignment Specs MK4
    Mar 2018
    Alignment Specs MK4
    Can anyone help me with what the specs should be for the MK4 that I have at my alignment shop.
    The body is off but its time to cruse the neighborhood. After the body is on I will have it done again but I am sure I have a few months of local trips around the area.
    Thanks in advance!
    Jim
    Jul 2020
    Near Milwaukee, WI
    There are different alignment specs depending on what you have and what you plan on doing with the car.
    Some may already know your build, but many don't .
    To get the best response help us with answers:
    1) power / manual steering (higher castor with power steering)
    2) IRS / straight axel (IRS needs rear alignment specs)
    3) street, track use, or mixed (track use may benefit for high camber)
    In general for the front: camber -0.5 to -1.0, castor (power steering) 8, toe in 1/16".
    I don't know about rear alignment specs. I'm sure someone else will chime in.
    MkII: 408 Dart block dry sump, 750cfm carb, G-Force T-5, 8.8 rear with 3.55 gears, 3-link, Kirkey seats, black ceramic coated twister mufflers with shields and adjustable turn down tips, passenger roll bar, front and rear roll bars. 2020 GT500 Magnetic metallic, with white and lime green stripes.
    Mar 2018
    Thank you for the quick response.
    Power steering
    IRS
    Street use
    Got the specs for IRS
    Camber: -0.5to -0.75°
    Total Toe: 1/8” Toe in
    Cape Coral, FL
    Quote Originally Posted by JL1744 View Post
    Thanks in advance!
    Jim
    Be sure to set your ride height front and rear. Since your body is off get the alignment done this way. Once you put the body on and have all the body work done you will be a your final curb weight. Re-adjust your ride height to the original number and you do not need another alignment....it will all come back to the specs set during the initial alignment. I'm set 4" in the front and 4.5" in the rear. After I got the body on and all painted I was about a little over 3' in the front and 3.5" in the rear. Cranked up the ride height to 4 and 4.5 and I'm all good.
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print Sniper 2, 302 with 4R70w trans, and under car exhaust. McLaren Racing Green with saddle leather interior.
    Milton,DE
    You should specify which IRS. T-Bird center section or 2015-up Mustang. The Mark IV could have either one.
    With power steering on a street car I recommend 6 to 8 degrees positive caster, .5 to .75 degree negative camber and 3/32" total toe in. ILPBFoot is exactly correct regarding ride height; set it now, have the car aligned and then when all the weight is on it go back to the same ride height and all of the alignment specs will return to the same settings.
    Mar 2018
    Thank you Jeff. That is good info. Much appreciated.
    I have attached the specs I received from FF as well
