Likes Likes:  2
Results 1 to 8 of 8
Thread: Anyone Else Cut Lower Steering Shaft for MKIV with Coyote?
    Dec 2018
    Sherwood Park, AB
    Question Anyone Else Cut Lower Steering Shaft for MKIV with Coyote?
    Just wondering if anyone with an MKIV and Coyote has had to cut the lower steering shaft, in order to make sure it sits flush with the inside bore of the u-joint. In my mock fit-up, the closest I can get it leaves about 1/4" proud, but it doesn't look like it will bind with the opposing knuckle as it goes 360° around.
    32J
    Sep 2018
    SF Bay Area, CA
    I've never heard of anyone cutting the steering shaft. Many folks (myself included) have had to mount the footbox pillow bearing on the inside of the footbox rather than the outside as shown on the instructions to have enough room for the shaft to fit properly.
    Edit: Not a great picture, but you can see how I mounted the pillow bearing on the footbox.
  3. Thanks 32J thanked for this post
    Likes dbo_texas liked this post
    Dec 2018
    Sherwood Park, AB
    Great idea, thanks. That may do the trick. I'll give it a try.
    32J
    2nd for the inside mount. That was how everyone was doing it when I built mine.
    Dec 2018
    Sherwood Park, AB
    Unfortunately the bearing top fange will interfere with the pedal box front mount. I exchanged messages with Dan G. and what I'll do is just split the difference between the two u-joints.
    32J
    Jun 2020
    Rising Sun , Md.
    I had the same issue and mouunted the pillow block bearing inside and outside the firewall ending up on the outside and cut about 1/4" off my lower shaft just as yours shows. Worked out good.
  8. Likes toadster liked this post
  9. #7
    Sep 2011
    Minneapolis, MN
    Quote Originally Posted by ggunter View Post
    You can do that but you'll introduce excess slop in the pillow block, which you don't really want. And I really only needed that little bit more represented by getting the 'outside' 1/2 'inside' with the rest of the block.
    It does interfere when placed inside the footbox but that's easily addressed by grinding off the top of the flange which isn't structurally vital.
    Untitled by John Ibele, on Flickr
  10. #8
    Sep 2018
    SF Bay Area, CA
    Agreed - the interference is pretty easily addressed, either from the bearing flange or from the pedal box brace like this. Either way works fine.
