Results 1 to 3 of 3
Thread: Body buck dash support?
    Aug 2020
    Greetings,
    I got my kit from Stewart last week and I’ve been busy inventory’ing and getting everything reasonably organized. I’m really through the roof about this project I really don’t have the words to express how awesome it is to finally be getting started. Pre-delivery I built a body buck using a combination of the schematics in the manual as well as some resources here and everything fits very nicely. However, I noticed in the manual they give you the “store on the ground” instructions that include putting a piece under the dash area to support it. Also if you look at the picture of a body buck in the manual it has one too. My buck just has the front and rear profiles right now. It’s going to be stored for quite a while so I’m wondering if I should incorporate that dash support with buck. Thanks in advance!
    Dublin, OH
    you can just stick a 2x4 between the front and rear cowl to prevent sagging of the mid portion of the body.
    Sep 2018
    SF Bay Area, CA
    I needed to transport mine to an offsite storage unit and it was too bouncy without supporting the dash so I cut a section of a foam roller to support the dash.
  4. Thanks IV_Joe thanked for this post
    Likes IV_Joe liked this post
