Thanks Thanks:  2
Likes Likes:  49
Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
Thread: New Life For An 'Old' MK1 Roadster.
    Jul 2020
    Western North Carolina, USA
    Quote Originally Posted by NiceGuyEddie View Post
    I said this years ago and I can't believe I'm saying it again, but I had no idea there were still unfinished MK1's out there!
    The pedals are very even - nice job. Consider bumping out the left side of the driver's footbox and adding sort of a recessed dead pedal - there is room between the footwell and the body.
    Any suggestions for a dead pedal? Also it looks like I'll need to fab up some type of stop for the throttle pedal. Any ideas?
    Jul 2020
    Got a chance to work on my seats today. I installed the seat heaters and started the layout for the mounts. I plan to use sliders for the driver's seat and a small riser on the passenger to match the height. A quick question... Are 1/4" rivnuts sufficient to attach the seats to the frame?
    Mar 2021
    SE WI Kettle Moraine
    mabbot74, Pick an OEM brand that you respect and inspect their seat mount engineering.
    I predict you will see M8 or 5/16 minimum with through bolts or weld studs, nuts and washers, grade five or eight, which rivnuts are not.
    jim
  4. Likes mabbott74, WIS89 liked this post
  5. #44
    Right Around Canton Ohio
    Quote Originally Posted by mabbott74 View Post
    I tried a couple of dead pedals from production cars but they were all too big and interfered with the clutch pedal. I ended up using a piece of 1 1/2" angle iron covered with non-slip tape. It's not too pretty but it's functional and one of the better additions I’ve made. I installed it after the body was on for a few years so I used some hefty sheet metal screws to attach it to the foot box aluminum. I was concerned about the aluminum being strong enough to support it without additional backing but it has held up well. I use it all the time and it’s still solid after many years.
    Not sure about the throttle pedal. I also used one of Russ's pedals but I don't believe it needed a stop.
    I did install a stop to keep the brake pedal rod from backing out. Factory Five fixed this at some point but I remember reading about someone with a Mark 1 that caught their toe on the brake pedal and pulled the brake rod out of the master cylinder. That could make for a bad day so if your frame doesn't already have a stop I'd recommend installing one.
    __________________
    John / FFR 1827,
    John's Mark I Roadster Build Site
  6. Likes mabbott74 liked this post
  7. #45
    Jul 2020
    That was easy! I upgraded my brakes to SN95 Cobra spec calipers & rotors. I had a local shop make brake hoses for the front. The first set was the wrong size (3/8" instead of 10mm). The second set was the right size but one side leaked. You know what they say, "Fifth times a charm."
    Got some help from a friend and my pit crew. Brakes are bled, pedal is firm and no leaks detected. I'd say it was a good shift!
  8. Likes mburger liked this post
  9. #46
    Husband/father/son
    Greenville, SC
    There is an early, sub 1,100 (IE: one of the first 100 sold to the public) MK I kit sitting in a garage in Maywood, NJ, 2nd owner has it, and is slowly working on it as time and funds allow.
    Bill S.
    PS: yes, I'm still lurking about
    Instead of being part of the problem, be part of a successful solution.
    HOW TO BUY A USED COBRA
  10. Likes mabbott74 liked this post
  11. #47
    Mar 2014
    Crossville, TN & Punta Gorda, FL
    I bought mine in 1999 an d it is only about 1/2 done.
  12. Likes mabbott74 liked this post
