Likes Likes:  12
Results 1 to 13 of 13
Thread: Rob's MKIV Roadster Build #10098
    Nov 2019
    Dublin, OH
    Hello all! I just want to document the journey through my MKIV Roadster build. It starts with my order being placed on 02/22/2021, the kit was ready on 06/19/2021, and was delivered by Stewart on 06/27/2021. I also attended the build school at Mott Community College from 04/30/2021 - 05/02/2021 in Flint MI.
    My order included:
    MKIV Roadster Complete Kit
    Powdercoated Chassis
    351W Stainless Headers
    302/351 Engine/Trans Mount
    Hydraulic Clutch Master Cylinder Kit
    31 Spline 2015 IRS 8.375" Driveshaft
    Body Cutouts
    Black Vinyl Seats
    Power Steering Components
    Front Lower Arms - Standard Width
    IRS
    FFR GPS Gauge Set
    Front Swaybar
    Rear Swaybar
    Center Dash Support
    IRS Center Section w/ 3.55 Gears & Spindles
    Wind Wings
    Sun Visors
    Brake Duct Wire Mesh
    1.50" Rollbar Grommet Set
    Assembled Side Louver Set
    FFR Electric Oil Temp Gauge
    Brake Reservoir
    Power Steering Reservoir
    Blank Dash
    17" Halibrand Wheel/Tire Package
    Roadster 13" IRS Brake Kit
    Trunk Gas Strut Kit
    14" Leather Steering Wheel Upgrade
    1 Yard of Raw Carpet Material
    Additionally, as of 10/20/2021, I have also purchased:
    Ford Racing Boss 427 Short Block
    Ford Racing Z2 Aluminum Heads
    Tremec TKX Transmission
    Quicktime Bellhousing
    Heater/Defroster
    Driveshaft Safety Loop
    Various Engine Components and Tools
    I look forward to posting updates and looking to all of you veteran builders for guidance.
    FFR 10098, MK4 Roadster Complete Kit, IRS, 427ci, TKX, etc.
  2. Likes toadster, CaptB liked this post
    Nov 2018
    Centennial, CO
    Welcome. We’ll be watching for the updates.
    Bradley
  4. Likes Rob Adkins liked this post
  5. #3
    Jul 2021
    West Grove, PA
    Good luck Rob! Build School should be a big help.
    How are you progressing since June?
  6. Likes Rob Adkins liked this post
  7. #4
    Nov 2019
    Dublin, OH
    It is not going as quickly as I had hoped. There were several parts missing from the kit I had to wait on as well as a TON of backordered parts. As of today, I have a very detailed inventory, all of the panels that were attached are labeled and removed, I have the coilovers built, the front upper and lower control arms mounted, front coilovers installed, and the spindles mounted with the steering arms attached. I can't mount the hubs yet as I don't have the hub nuts. Also, I just got the door check straps so I dyed them black. Going to work on the rear end this weekend hopefully.
    Apr 2020
    Virginia
    Welcome aboard, Rob! Looks like it's going to be a great project.
    MKIV Complete Kit #9822 l BluePrint 347 EFI l TKO600 l Power Steering l Heater/Defrost l Build Thread
  9. Likes Rob Adkins liked this post
  10. #6
    Welcome Aboard But More Importantly, Welcome To The Family!
  11. Likes Rob Adkins liked this post
  12. #7
    Sep 2011
    Minneapolis, MN
    Hey Rob, welcome to the 'build thread' portion of the forum, and to all of the fun. I think you've got a nice build plan. I think a build thread is a great way to record progress and get helpful advice and encouragement along the way.
    That 427 short block is a great way to start ... lot of cubic inches in a small package! You can find solid motor mounts to get your block 3/4" lower if you want a bit more room on top with the 9.5" deck.
    -- John
  13. Likes Rob Adkins liked this post
  14. #8
    Nov 2019
    Dublin, OH
    Quote Originally Posted by John Ibele View Post
    -- John
    Thank you, I did not know that was an option. Now to figure out what intake to run if I get that extra space...
    Nov 2019
    Dublin, OH
    So I got some additional thing completed over the past 2 days. I got my IRS differential installed, along with most of the IRS components. I had a lot of cussing and persuading to get the passenger spindle into the lower control arm, but I got it finally. I didn't realize before getting into this that so much "tweaking" and "fitting" would be required. Not complaining, still enjoying it tremendously.
    Sep 2011
    Minneapolis, MN
    Quote Originally Posted by Rob Adkins View Post
    Yep, I have an older kit but some things never change. For me a stout piece of threaded rod, along with two nuts and beefy washers made a nice spreader / compressor tool to get the ends of the control arms moved either in or out slightly.
  17. Likes Rob Adkins liked this post
  18. #11
    Jan 2020
    State of Jefferson
    Nice work, looking really good!
  19. Likes Rob Adkins liked this post
  20. #12
    Jan 2021
    Memphis, TN
    -- John
    Do you have a part number/source for the solid motor mounts?
    Forte's Axle
  21. Likes Rob Adkins liked this post
  22. #13
    Sep 2011
    Minneapolis, MN
    Quote Originally Posted by CaptB View Post
    Check with Gordon Levy, one of the vendors on the forum.
    You'll buy yourself more room up top, but keep in mind that you'll be reducing your oil pan ground clearance as well. You'll want to make sure that vibration and driveline setup issues are factors you can manage - either not an issue, or worth the tradeoff. Not trying to steer you toward or away from solid mounts by any means - but as with all the choices related to the build, know what problem you're trying to solve and do your research. A lot of choices with these cars are a balance of factors instead of a black / white selection. My $0.02 for today
    Good luck!
  23. Likes Rob Adkins, CaptB liked this post
