Likes Likes:  2
Results 1 to 10 of 10
Thread: ElSpanishGeek's MK4 Roadster Build
Threaded View
  1. #5
    Feb 2021
    Austin, TX
    Now that I'm all caught up, I can ask for clarification on where I am.
    I bolted (haven't torqued yet) the Lower Control Arms, which required a bit of elbow grease in the form of a plastic mallet. Also, the passenger side required a washer on the front tabs and not the driver side. I saw in other threads that this is all perfectly normal but just double-checking. You can see the washer here:
    I'm a bit confused with the manual where it says the locknuts on the ends of the pivot shafts of the UCAs should be tight enough for minimal endplay. I haven't torqued them yet, but how does this look?
    Currently, these locknuts are loose enough that the UCAs are very free to rotate up and down, but they don't stay upright, they droop down once I let them go. Oppositely, the LCAs don't droop, while they are very easy to rotate up or down, they stay fixed in that position. Is this all that the desired behavior?
