Thanks Thanks:  7
Likes Likes:  15
Results 1 to 10 of 10
Thread: Video of Installing Painted Body
    Dec 2018
    Sherwood Park, AB
    Question Video of Installing Painted Body
    Wondering if anyone has a video of installing a painted body on the roadster. I've read different opinions on whether to paint the body on, or off, the frame. I'm on my first build, and I've never really worked with fiberglass, let alone painted fiberglass. When I first removed the body from the frame, I remember the body flexing quite a bit, especially at the bottom of the door jamb. How do you know the finished paint won't wrinkle or crack when the body flexes as you put it back on the frame?
    32J
    because 7000 (?) bodies have been done that way
  3. Likes abdw-wcw liked this post
    It is a very valid question for those of us who have no experience with it. Honestly that is not a very helpful answer at all. Wish I had something to offer but I had the painter install my body and have no idea what the process is.
  5. Thanks nucjd19 thanked for this post
    Likes nucjd19, cnutting liked this post
  6. #4
    Dublin, OH
    Jkleiner has posted pics in the past of the body installation process and he does this solo with ropes/pulleys. Try to find some of his posted pics on this forum or the other.
  7. Thanks 32J thanked for this post
    Likes RSCamaro liked this post
  8. #5
    ...Honestly that is not a very helpful answer at all. Wish I had something to offer but I had the painter install my body and have no idea what the process is.
    And your comment is helpful?
  9. #6
    My reply was concerning damage to the paint and fiberglass
  10. #7
    May 2020
    Centerview, MO
    Rich,
    I love ya man, but if a guy asks a question, it’s because he doesn’t know. Just like every single one of us did not know/doesn’t know till they have done it.
    Ed
    MK IV Base Kit #9370 w/ FFR Lower Control Arms, donor 1996 Cobra 4.6 L DOHC; stage 2 Comp Cams, Manley forged Pistons & Rods, IMRC Delete Plates, T-45 transmission HD extra build w/ single disconnect reverse mod, 3-link w/ Koni Coil Overs 3:73 rear end. Painted and re-assembled Jan 2022.
  11. Likes 32J liked this post
  12. #8
    I've never done video of the body going on but have done this one taking a body off:
    https://www.facebook.com/jeff.kleine...1380806317944/
    Going back on is pretty much the reverse, I just go a little slower with smaller changes and keep a close eye to be sure it's not hanging on weatherstrip, door hinges and such. Honestly, for me I find it easier to go on and off solo than with a helper. Here's a photo of one ready to be lowered into place...
    And (according to the time stamp on the photos) here it is about 10 minutes later...
    If the flexing from installation causes cracking or delamination you've got bigger problems.
  13. Thanks nucjd19, johnnybgoode, 32J thanked for this post
  14. #9
    North CT
    I like the use of PVC piping to hold the sides out as you slide the body down. nice idea
  15. Likes CaptB, 32J liked this post
  16. #10
    I use the 2x4 like Jeff shows and then I use a ratchet strap w/ lots of padding from the hood opening to the trunk opening. This way the 2x4 keeps the body from collapsing together and the strap keeps it from expanding. I was always helping someone who had never done it before and usually any extra helpers also had never done it before. So my extra caution was a good thing in a couple of cases where someone said to move in some direction and that was misunderstood and the move went the wrong way. This is one of those deals where all the worry beforehand is a good thing so your are prepared, but you find it takes maybe 5 minutes total and was really pretty easy to do.
  17. Thanks johnnybgoode, RSCamaro thanked for this post
    Likes johnnybgoode, 32J, RSCamaro liked this post
