Likes Likes:  8
Results 1 to 14 of 14
Thread: how did you stuff all your electronics, etc behind your dash?
    Folsom, CA
    Question how did you stuff all your electronics, etc behind your dash?
    I'm at the stage where I need to start getting the dash mounted and determine how to mount/stash everything behind there.
    share some pics, ideas, tips & tricks
    I will have some extra relays, etc from power seats, pushbuttons, etc.
    I don't think everyone drills mounts into the firewall, but maybe I'm wrong?
    here's a great example of what I aspire the wiring to look like
    http://fraserscobrabuild.blogspot.co...g-5-hours.html
    unfortunately mounting anything through the CF dash just won't work...!
    Todd
    Colorado
    Mine is a rats nest back there... we are planning on removing the dash to clean it up a bit. Initially it looked fine, but after adding "just one more wire" multiple times it got out of hand.
    Mk4 Roadster with BluePrint 347 with Holley EFI and solid axle rear end.
    Build thread
    Body work and paint thread
  3. Likes toadster, MisterAdam liked this post
    Folsom, CA
    Quote Originally Posted by hineas View Post
    yep! that's what I'm concerned with! same thing happens in my garage LOL
    major props to those who can make it look like artwork!!
    I've been watching some youtube and getting ideas... I like this guy's work on setting up a relay/fuse panel
    Todd
    Sep 2018
    SF Bay Area, CA
    Hey Todd,
    Here are a couple ideas. I have under dash filler panels that run nearly the full length of the dash, which I'm going to use to mount stuff that I need to access but don't want to see (USB chargers, buttons for the gauges, footwell lights... you get the idea). I also made a vertical partition wall that will sit behind the glove box that I've mounted some of the bulkier items (DGD and E-Stopp control boxes) to, and will also mount the relays for the heated seats and other items I don't need to access on a regular basis.
    This isn't a very good shot of the under dash filler, but you can see it in the glove box opening:
    And here are a couple shots of the mount that will sit behind the glove box. I still need to make a little L bracket to support it at the top, which will attach to one of the bolts that mount the wiper motor.
    Hopefully this gives you some ideas.
    -John
  6. Likes toadster liked this post
  7. #5
    Jun 2017
    It was a lot of work. Prob 50 lbs. of zipties. I really like the flat type instead of the 90 degree ones. A few places I used hangers to hold bundles up and out of the way. My amp is riveted to the firewall. I also have full length under dash support I made. I used terminal blocks for the Russ Thompson turn signal but that could have just been hard wired bc it takes up room. I also have a ground distribution block behind the dash.
    I wouldn't be too worried about drilling into the firewall, its not that noticeable. You could make some kind of bracket to attach stuff to behind the dash so its only a couple holes in the firewall, just rivet in from the engine bay side in so its more appealing. I used the backside of the hoop in a couple places. The angled dash support bracket I made (with holes in it) also helped wire management.
    20201231_121043.jpg 20201231_121138.jpg 20201231_121149.jpg 20201231_121100.jpg
    Michael aka @my_cobra_build on Instagram
    Base MK IV Roadster with several options. Body is Lamborghini Grigio Lynx w/ Audi Vesuvius Gray stripes. 25th Anniversary FFR wheels. Seats and interior by Intatrim.
    Gen1 Coyote w/ Comp Cams & Cobrajet manifold. Tremec TKO 600 w/ a midshift kit. 2015 IRS w/ 3.73 Torsen diff. FFR Headers, Gas N Pipes, Power steering & power brakes.
  8. Likes toadster liked this post
  9. #6
    Oct 2020
    Albany, NY
    This was my base setup. Really just a lot of consolidation and zip ties
    Once installed there was plenty of room for extras.
    With vents
    Build 1 MK4 #10008 - Delivered 03/03/21, Graduated 7/20/22 - Sold 6/6/24 Build Thread #1 https://shorturl.at/K9fuy
    Build 2 MK4 #11061- Delivered 08/24/24 Build Thread #2 https://shorturl.at/OZowi
    Build 3 35 Pickup #329 - Delivered 10/28/25 Build Thread #3 https://shorturl.at/Ty4QQ
  10. Likes toadster liked this post
  11. #7
    Nov 2016
    "The i.e." SoCal
    The Decora wall plate is a nice touch.......................
    I think I'd look elsewhere for inspiration
  12. #8
    Brute Force. Someday might make it neat.
    Kevin
    MKIV #8234
    NITTO NT01 275X40XZR17 - 315X35ZRX17
  13. Likes toadster liked this post
  14. #9
    Santa Clarita, CA.
    Here is mine. Added some brackets for relays and the throttle body computer.
    Just take your time and keep it tidy. It all fits eventually.
    And here it is all finished up.
    F5R #7841: 15th Anniversary Edition MK4, Ford Racing Z427, Holley Terminator X Stealth EFI, Gas-N Pipes, Stainless Headers, Liberty's Gears TKO600, 3.31 Moser 3-Link, 17" Halibrands
  15. Thanks toadster thanked for this post
  16. #10
    Jun 2018
    Newcastle WA
    Quote Originally Posted by CDXXVII View Post
    This is very clean, nicely done!
  17. #11
    Jan 2021
    Memphis, TN
    Anyone ever have 520 Speedworks wire your dash? They advertise starting at $250, but thought I'd ask:
    https://520speedworks.com/shop/ols/p...wiring-service
    Forte's Axle
  18. Likes toadster liked this post
  19. #12
    Feb 2021
    London, Ont. Canada
    Wow! there is some nice work posted in the previous pictures! I just used a bunch of sticky squares and zip ties and it all turned out ok. Nothing like the previous pics though. At least it looks better than what the previous guy did. I also cleaned out a quarter pound of bondo dust when I took the dash off.
    Before and after pics...
  20. #13
    I moved the fuse panel to the passenger side of the car and flipped the blinkers from left to right.
    https://thefactoryfiveforum.com/albu...chmentid=51773
    https://thefactoryfiveforum.com/albu...chmentid=51762
    It's what you do when you are from "The Dark Side!" plus it uncluttered the foot box.
  21. Likes toadster liked this post
  22. #14
    Folsom, CA
    awesome stuff guys!!!
    Todd
