Results 1 to 2 of 2
Thread: SN95 Spindle Swap.
    Jul 2020
    Western North Carolina, USA
    SN95 Spindle Swap.
    Got a chance to work on the project a little today. I'm in the home stretch of swapping my Fox body spindles for a set off of a 1995 Mustang GT on my MK1 Roadster. As with everything else it is more complicated that I expected it to be. For those who may have successfully accomplished this project I have a question. Since the strut mounting ear is about 1" lower on the SN95 spindles than the Fox ones did you use the lower holes on the FFR A arm?
    A few of the 'things' I learned along the way. The Fox lower ball joints can be used but you have to add washers to the top because the shaft is longer than the 1994/95 versions. The tie rods will have to be adjusted out a good 1/2" on each side because the mounting hole is moved forward and outward compared to the earlier versions. Pigeon toed isn't a good look on the Roadster. Here are a couple of other pictures from the project.
    Next up is converting the rear drums to Cobra discs with the adapter plates I got from North Race Cars and installing the new control arms and coil overs.
  2. Thanks BLUE KNIGHT thanked for this post
    Yes to the lower holes in the adapter
  4. Likes mabbott74 liked this post
