Results 1 to 17 of 17
Thread: Brakes | Whitby | Pedal goes to the floor
    Aug 2020
    All,
    I replaced the plastic reservoirs I got from Whibty because one was leaking. I got Jamar triple reservoirs, clutch/front/rear brakes.
    Clutch has been bled — works perfect.
    I’ve got the same problem as before — bled the master with the brake booster installed — pedal was hard as a rock.
    Now that I’ve bled the brakes — no bubbles, went through 2 bottles of brake fluid — pedal goes to the floor
    Thoughts?
    It’s the last hurdle before a test drive…
    You have to fix and adjust your rear brakes before you will get the pedal to firm up. The anti rattle spring on the pad on the piston side is not correctly installed. There is a gap between that pad and the rotor. There is no way you will get any brake pressure like that.
    The master cylinder is designed to move a small amount of fluid at high pressure and can't compensate for improperly installed or adjusted parts.
    After the parts are correctly installed, follow the rear brake adjusting procedure using the park brake to properly set the pad distance.
    HTH
    Norm
    Norm, we both have told the SAME story.
    Aug 2020
    HTH
    Norm
    Ok — how do I adjust the anti rattle spring on the pad or take it apart and reinstall it — I did not attached the spring — it was on the caliper when it came in the box — and there’s nothing in the instructions from factory five on how to adjust or that it needs to be adjusted — https://www.factoryfive.com/wp-conte...5in-BRAKES.pdf
    Dan at Factory Five said I needed to bled the brakes before the eBrake would work — I explained they’ve been bled repeatedly then I got silence
    Trust me, she’s neighing and ready to take a loop around the track — but she’s got four bad hooves - the Pony wants to shoot the boot
    Take it apart and re-:instal it. 1 should look like 2 in the picture.
    Norm
    Aug 2020
    Brakes | Whitby | Pedal goes to the floor Your Message
    Norm
    On it, that's two bolts... be back shortly
    Aug 2020
    Rear Caliper Spring Adjusted
    Quote Originally Posted by Padawan View Post
    Ok - taken apart and adjusted the spring and put back together — both rears are matching
    Foot still goes to the floor, what are the next steps…
    Thanks in advance
    Cycle the parking brake about 50 times full up to full down.
    Aug 2020
    Cycle eBrake 50 Times
    On it…
    Stay tuned…
    Aug 2020
    Cycled the parking brake 50 times full up to down on parking...
    Unfortunately the brake pedal still goes to the floor...no leaks anywhere...
    Try pumping the brake pedal to build pressure, hold the pedal down and then cycle the park brake. If that doesn't work you may have to take the rear callipers off again and turn the pistons out until you can just slide the assembly over the rotor.
    Norm
    PS What park brake handle are you using and are your cables properly adjusted? Can you check that pulling the park brake handle is actually moving the lever at the caliper.
    Dublin, OH
    just curious, what method did you use to bleed your brakes? do you have pics of your brake lines? It sounds like you still might have air in your line somewhere.
    Aug 2020
    I'm using the Factory Five ebrake handle.
    When I pull on the eBrake handle the spring moving...I got under car late last night car to review to ebrake cables and there is no additional slack to tighten.
    The last time, we used a pressure bleeder, motive brand, and was unable to get a firm pedal.
    On the pedal bleeding...it was all manual...foot down, hold, release value, tighten...we did this for over and hour...went around the car 3 times.
    Tried gravity bleeding last night after trying to set ebrake by pulling a full up and down 50 times.
    Factory Five said the ebrake would not work until the brakes have been bled, per Dan.
    I am not familiar with the FFR park brake handle and the available adjustment with it. At your caliper make sure the park brake lever is able to fully release. Hopefully someone experienced with this set up will contribute.
    Norm
    Aug 2020
    Brakes | Whitby
    Norm
    Dan at Factory Five thinks I didn't proper pressure bleed master cylinder correctly.
    I bleed the master cylinder on the car, replaced a brake line (don't ask , then re-bled the system....I was getting tiny bubbles out of the front right caliper so I tighten all the blots and connections to the front reservoir...then the little bubbles went away...no bubbles from any of the calipers...I think part of the noise in the rear brakes is they flex a little bit when you press on them.
    The pedal does now stop about 1 inch away from the floor, but the front brakes are working for sure...
    After everything was bled...I did pull the eBrake handle up and down 50 times as requested before.
    The rear brake are very tight against the rotor...
    We going to give it a 3 mile an hour test drive tomorrow morning to test the brakes...
    Does the parking brake work now?
    Aug 2020
    eBrake
    We still think there is something not right about the eBrake, but we were going to test it when we roll it down the driveway…
    The rear calipers are really tight…so not 100% sold on there performance
    How much braking power should be coming out of the rear brakes?
    The front takes the most of the braking load?
