Hello community of wise experts - First off, I hope you all have a safe and enjoyable Fourth of July holiday with your families. Considering where the world was a year ago, we have much to be thankful for. Second, thank you to all who put the time and effort into this blog helping us first time builders along the way.
I need some wisdom from the group on how to connect up the caliper for my drive shaft ebrake set up. I will be running a 351 Windsor married to a one of the new TKX transmissions. I have an IRS rear, and wanted to stay with the classic look of 15" wheels. I've already worked through how to get the Wilwoods calipers on the rear brakes and the got Wilwood to paint the calipers in Gulf Livery orange (Wilwood calls it Competition Orange I've got the color code if anyone needs it). With the smaller 15" wheel I don't have room for the ebrake on the rear rotors like the assembly manual calls for.
So I installed a disk and caliper on the drive shaft. Anybody else done this before? I'm looking for clever ways to mount the spring/hardware to the chassis so that the cable goes OVER the round frame tube and can be connected to the stock ebrake handle.
Here are some photos of what I have so far. I just need to figure out how to connect the ebrake handle to the caliper while clearing the spinning disk on the drive shaft.
Thank you in advance for your time and expertise.
Current rear wheel w/ IRS
The caliper support bracket is mounted to the rear square cross-member (view from DS)
(view from PS facing forward).
(view from PS looking down)
