All,
I replaced the plastic reservoirs I got from Whibty because one was leaking. I got Jamar triple reservoirs, clutch/front/rear brakes.
Clutch has been bled — works perfect.
I’ve got the same problem as before — bled the master with the brake booster installed — pedal was hard as a rock.
Now that I’ve bled the brakes — no bubbles, went through 2 bottles of brake fluid — pedal goes to the floor
Thoughts?
It’s the last hurdle before a test drive…
