Can anyone help me identify the brake valve ports? I neglected to mark them when removing from donor car (2002 mustang).
I took a screen shot of your picture and added the port identification. Some/most do not use this component, and if it is required for inspection, then they modify it by removing the proportioning part of the valve. LMR offers a plug to replace the valve portion at the end. I did the mod to increase the pressure to the rear brakes. Instructions for this are available on the web.
HTH
Norm
Jaguar Engineer thanked for this post
