Here is a picture of the flasher unit (does both signals as well as hazards).
On the ’89 Probe this was located with several other components on the firewall just to the left of the steering shaft (mounted so that the connector end pointed into the firewall. From what I understand this particular unit may have only been available on the ‘89’s. I think Mazda 626’s also may have used them.
Here's a mock up of the horn buttons. In the final version they will be mounted futher out towards the rim.
I did a little more searching and found some more info on the flasher module. You can get it (just the module, not the switch) off the following cars:
'89 Ford Probe
'94-'96 Ford Escort
'94-'96 Mercury Tracer
It is $70 new so a scrap yard is the way to go. We picked up a couple of units for $20 each for the whole setup (removed ourselves).
Just got back from the scrap yard and thought I would let you know that I confirmed that the flasher unit is the same on the '94-'96 Escorts. It is actually a better source since, on the Escort, the flasher is connected by a connector and harness which you can splice into your existing harness. On the Probe it plugged into some sort of block so, as you can see above, you have to use 1/4" female spade connectors to hook it up. I will be swapping out mine to put in the connector from the Escort.
Where they connect to the copper ring.
Here you go. Looking at the back of the switch.
And here's the connector.
hazards are activated by grounding one of the wires on the flasher unit. A dash toggle or rocker switch is all that's required. Works like a charm.
As for the flash-to-pass, I tried to figure that on out and fried one of the switches. So no I don't know how it would hook up and I don't plan on trying again. I always run with my head lights on anyway for safety (even more so with this car) and a simple pull will toggle the high/low anyway. I assume that feature was for if you had your lights in the off position and pulled for flash to pass.
The main thing from the other post is the wiring diagram the original guy was kind enough to post. Wish I knew who it was to give credit.
Just had to bring that over didnt you
Kidding.
Show your parking Brake mod as well.
Oh, and dont forget the booster too.
I'm using the turn signal and the booster mods. Thanks for the work you've done on those and sharing.
Final product with a custom billet handle.
Cheers, Rod
Have a safe day,
Lew Poberezny
Wauwatosa, WI
____________________________________
MKIV ordered Sept. 02nd 2010
Stewert Delivered Oct. 11th 2010
Order Forte's Magic Dec. 02nd 2010
Roller Dec. 04th 2010
Vredestin 245/45R17 Front 315/35R17 Rear
See build details at my Blog
http://ffr7347build.blogspot.com/
Thanks for ALL the great info and the great pictures, I really appreciate the new ideas.
Great Read!!!!!
Will look into for sure!!
Rod, Thanks for bringing this over. I did this mod early in my build and really couldn't appreciate all that little switch did until I got my car on the road. The Probe turn signal switches are still plentiful at the wrecking yards and I try to pick one or two up each time I go to try and help out other builder. Your in-depth, step by step account of how you did this really has helped many builders, we all Thank You.
I do wish however that when someone (like yourself) goes to all the trouble of posting something like this, that others would not jump on the thread and say "Hey, I did this instead" and post a link to another product and ruin the thread you put so much time into creating. I wish they would just start their own thread. Oh well, off my soapbox
Hey!! Nice pic's ,info and tech on this mod!! Thank you for shareing this with all of us on the forum. This is why I spend most of my time here! Great idea on the ext for the horn.
I have an extra cancel ring and switch with harness if anyone needs them. I'm not on here a lot so you can e-mail my if interested, richschppratyahoodotcom
Confidence: The feeling you have before you truly understand the situation. FFR 7652 Mk IV Base Kit w/IRS: ordered 10/19/2011; Arrived 11/19/2011. Coyote, Trans & headers Installed 9/11/17. First Start 12/19/17, First Go-cart 3/2/18. Aligned and go-karting. Working the interior now. Happy customer of FFR, North RaceCars, Forte's, and Breeze.
Chris Lewis
Where did you get the beautiful clock turn switches? I love them and have to get some, Thank you.............Adam
