I am pretty sure you are just mocking up. But just in case. You are going to put a grommet in the firewall to protect the hoses? Not sure how you are going to get it to seal. Don't forget fire-wall is a literal term.
I think you were commenting on Toadster's setup. I am also concerned about the lines feeding the master cylinder. I am pretty sure Earl's super stock hose is not compatible with brake fluid. The lining could dissolve and contaminate the brake system. Please double check this.
Norm
