Results 1 to 14 of 14
Thread: Valve cover question
    Jul 2017
    Wilson NC
    I am updating my valve covers and bought a nice finned aluminum Shelby cover from Drake automotive (via SummitRacing). When they arrived - it wasn’t quite what I expected. The passenger side was normal with hole & grommet ready for the PCV but the drivers side had 3 inch tube (I’ve been calling it a snorkel). I called SummitRacing and they had no idea about the snorkel. They thought both sides were the same - got their picture from Drake and only showed passenger side.
    Their is a cap available for the snorkel but I wanted a clean look like I have now with PCV on both covers.
    Any ideas on this snorkel? Is this an old holdover from the 60’s?
    Jun 2020
    Rising Sun , Md.
    In the old days there was no positive crancase ventillation. You had a breather on the valve cover which also served as an oil fill and a road draft tube which came somewhere out of the crankcase usually in the cam chest area, which ran down below the car and was cut on an angle to create a slight vacuum to pull air through the breather and out the road draft tube as the car went down the road. In the old days 60s and 70s there were always black strips on every concrete road where oil just dripped out of the road draft tube onto the highway. The good old days.....
    Jul 2017
    Wilson NC
    Just added a pic of the tube to my post
    O'Fallon, MO
    That's were you put oil in the engine.
  5. Likes CobraboyDR liked this post
    CobraboyDR's Avatar
    Jun 2017
    Yup.
    My "COBRA powered by ford" came the same way. I am using a PCV system so I don't need the long fill/breather tube to reduce oil misting out the breather so I cut it off for a cleaner look. You have to hold the funnel correctly to add oil but I like the look much better.
    HTH
    Norm
    Cape Coral, FL
    Another option is to go with a breather filter in that hole (once you remove the tube). I got this one from Summit.
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print Sniper 2, 302 with 4R70w trans, and under car exhaust. McLaren Racing Green with saddle leather interior.
    Aug 2020
    This is what I'm currently using, first start this weekend...
    https://www.summitracing.com/parts/SDK-B6AZ-6766-B
  10. #9
    Jul 2017
    Wilson NC
    How did you cut the tube? Did the breather filter just fit right over the hole or did you have to do some customization?
  11. #10
    Jul 2017
    Wilson NC
    Quote Originally Posted by ILPBFoot View Post
  12. #11
    Cape Coral, FL
    Quote Originally Posted by Scowally View Post
    The Ford Performance Cobra covers did not have a tube, just the hole. Sorry I'm no help here.
  13. #12
    I cut the tube with a hacksaw. Cut it a little long and then finish it off with a good flat file or sander to get a flat smooth end to the tube. The grommet fits right over the cut end with no problem.
    HTH
    Norm
  14. #13
    Grand Rapids, MI
    The reason for the long neck is help keep oil (oil mist) in the motor. Short breathers tend to nose bleed oil over the exhaust as the motor loosens up. This is why you see tall ones on drag and old ace cars. It’s common to use a K&N type filter that clamps over it. Other breathers may fit over it too. You can cut the tube but you’ll notice it will oil up the covers and headers.
  15. #14
    Quote Originally Posted by GFX2043mtu View Post
    True but, these cars aren't running a PCV system like the OP mentioned in his first post. Here is a screen shot of a basic PCV system. The long tube side serves as an oil fill point and an air inlet to allow filtered air into the crankcase when used with a PCV valve on the opposite valve cover. Only occasionally (WOT, plugged PCV valve or an extremely worn engine) will it serve as a vent.
    The long tube is left over from the days when a breather was the only source of venting for the crankcase or to make in easier to add oil in the case of an engine where the valve cover access is limited.
    HTH
    Norm
