toadster
yup in tank pump, I got a piano hinge from McMaster and will configure a door and secure with rivnuts, if nothing else it will be an easy access panel
you might not need the hinge. I just used rivnuts to make the panel removable. I didn't carpet over the access panels and have the aluminum over the cut outs. I initially tried brushing the panels, but ended up spraying them black with truck bed liner.
